Author Topic: [GB] GMK Umbra | Completed | Nov. 1 - Dec. 16, 2019  (Read 116391 times)
Offline Pach
Re: [GB] GMK Umbra | Samples Have Arrived! | Nov. 1 - Dec. 16, 2019
« Reply #50 on: Tue, 25 February 2020, 08:16:07 »
Samples look good! When do you think the sets will be ready for shipping?
My prediction is around June, but GMK is pretty backed up right now with all the group buys that have happened, so I can’t say for sure.
« Last Edit: Tue, 25 February 2020, 08:20:57 by Pachriksu »
Offline Pach
« Reply #51 on: Wed, 11 March 2020, 17:04:34 »
New Update Posted.
Offline Pach
Re: [GB] GMK Umbra | In Production, RAMA Updates | Nov. 1 - Dec. 16, 2019
« Reply #52 on: Thu, 09 April 2020, 10:28:49 »
Updayt
Offline bobfrink
« Reply #53 on: Mon, 25 May 2020, 08:10:22 »
I'm late to this group buy. How are the extra sets planning to be distributed? I am interested in a Hiragana set and potentially also a base set.
Offline DukeEsquire
« Reply #54 on: Mon, 25 May 2020, 11:38:41 »
Extras will be sold by the vendors. You'll need to check with them.
Offline Bpendragon
    • The Horse Stable
« Reply #55 on: Wed, 27 May 2020, 12:28:31 »
Just creating a GH account and chiming in to say that I love this set and can't wait till I get mine in hand. (I found out through Kono).
My quarantine project has been designing and buying the materials for an endgame built around this set. So thank you for bringing this to fruition.
Layout (note media key cluster, '00' key, and status LED location): http://www.keyboard-layout-editor.com/#/gists/7abe0f9944f72517c9f9f7b989548eb5
Case design: 243641-0
Shiny Umbreon is my favorite pokemon design of all time, I am definitely dedicated to this one.
243643-1
243645-2
Offline Pach
Re: [GB] GMK Umbra | Shipping to Vendors | Nov. 1 - Dec. 16, 2019
« Reply #56 on: Fri, 26 June 2020, 08:07:23 »
Update Bump!
Offline sevenseacat
« Reply #57 on: Fri, 26 June 2020, 08:18:33 »
awesome!!
Offline Tyson
« Reply #58 on: Fri, 26 June 2020, 08:30:56 »
Nice update, glad to see the set shipping. As for the renders, I went back and grabbed my RAL Deck and looked at the Colors IRL, they do not match the board renders. The alpha color is drastically darker irl and in your pic than in the renders. I also noticed that in your Feb 2nd update you mentioned that Abec went back and re-rendered the set with the new colors. So are the old colors the ones used for the set, or was there just a miscommunication with the renders from Abec using the wrong alpha color? The render from GMK looks more accurate then the board renders.
Offline Pach
« Reply #59 on: Fri, 26 June 2020, 08:51:49 »
The renders from Abec on the thread match the colors of the actual set. The alpha color isn't darker, if you're referring to the newest pictures, I said that they were undersaturated and the samples I have on hand do match the RAL colors.
Edit: Look at the March 11th update for sample comparison to RAL deck
« Last Edit: Fri, 26 June 2020, 08:56:10 by Pachriksu »
Offline Dave_Lister
« Reply #60 on: Fri, 26 June 2020, 10:02:48 »
I'd have to agree that the alphas look significantly darker than expected. Blue looks great though and I'm excited to recive the set soon. Can't believe I'm going to end up getting this before Dracula!
Offline Tyson
« Reply #61 on: Sun, 26 July 2020, 11:34:16 »
After seeing the set on r/mk I knew I had to try to get the set in extras! Instead I got inpatient and bought the set on Mechmarket. I'm super excited to get it in! There might be a chance that it'll arrive before the set ships to everyone in the US too! :)
Offline Anthixious
« Reply #62 on: Sun, 26 July 2020, 12:19:24 »
Case design: (Attachment Link)
I would LOVE a full-size aluminum case and PCB like this  :(
Offline Tyson
« Reply #63 on: Tue, 11 August 2020, 00:30:17 »
Just got my set in from the person in the EU, the set is definitely darker than the pic I saw on reddit. No worries though, it's still turned out looking nice. The main issue that I have with this set is that there are NO SCOOPED HOMING KEYS.... IDK how this was left out, there are only barred F,J,5 and flat F,J,5 keys. My Spacebars are also warped, but I'm still using the 7u just fine, so it's not bothering me, but it will definitely bother others if their spacebars don't work. Other than those two things the set turned out just fine. I plan on using it on my Bauer for a while!
Offline Pach
« Reply #64 on: Tue, 11 August 2020, 15:00:14 »
I'm glad you like the set! No scooped homing keys were actually my decision, as I at the time was not aware that scooped keys were standard (as shown in the renders). I really hope GMK sorts out their QC issues, especially with the spacebars these days.
Offline Pach
« Reply #65 on: Tue, 11 August 2020, 15:00:57 »
double post
Offline Rayndalf
« Reply #66 on: Tue, 11 August 2020, 16:56:21 »
So it's no homing and bar homing instead of scoop homing and bar homing? That's actually pretty funny. Bars arent too bad though.
Offline Tyson
« Reply #67 on: Tue, 11 August 2020, 21:42:01 »
Yeah, I'm used to both, but prefer using scooped for a cleaner asthetic. I think this might be the first set that does not have scooped caps lol.
Offline Rayndalf
« Reply #68 on: Tue, 11 August 2020, 23:09:21 »
This is the first GMK set I've seen with normal (non homing) F and J, but it was a thing on some vintage terminal boards including those manufactured by Cherry. Scoop/dish are best, but bar >>> scoop and bar so I think we'll be ok.
Offline Clay333
Re: [GB] GMK Umbra | Shipping to Customers | Nov. 1 - Dec. 16, 2019
« Reply #69 on: Wed, 23 September 2020, 06:17:12 »
Anyone know if there will be extras sold? I missed this kit and really want to try my luck at getting extras.
Offline ljyel
  • gamecube
« Reply #70 on: Wed, 23 September 2020, 16:59:52 »
I know deskhero already sold their extras a while ago and I think other vendors sold theirs as well :(
Keyboards: Think6.5v2 | Plume65 | Aurora Input Series 65 | Vega | Vertigo
Offline cpt-nic
« Reply #71 on: Thu, 24 September 2020, 02:38:45 »
mykeyboard.eu as well
Offline Morgan3Wheeler
« Reply #72 on: Tue, 29 September 2020, 17:00:49 »
The two keys of the Hiragana Kit were printed differently from the rendering.
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline Contrakey
    • Contrakey
« Reply #73 on: Wed, 30 September 2020, 16:50:36 »
If this had blue alpha lettering it would have been perfect for me. Still one of my favorite sets though.
Offline SuddenlyDonkey
« Reply #74 on: Thu, 01 October 2020, 21:16:46 »
Scared to look. Here's how my Hiragana arrived...
252856-0
Kono need to get their sh*t together.
Offline Pach
« Reply #75 on: Thu, 01 October 2020, 22:13:40 »
Yes, I addressed this in one of my early updates on the thread.
Sorry your kit came like that... It's GMK's job to make the packaging secure enough for rough shipping; personally I like their old packaging better.
« Reply #76 on: Fri, 02 October 2020, 22:29:03 »
Thank you. I certainly don't blame you and agree about GMK's new packaging; however, I think this is a Kono shipping issue. NK_ for example, boxes what they ship as well as wrap deskmats in protective covers. Everything in this pic was shipped from Kono. It included multiple deskmats, Umbra, and RAMA artisans.
252887-0
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #77 on: Sat, 03 October 2020, 12:22:12 »
The GMK kit renders visible by expanding the 12 March update in the OP (see below) exactly match the kits that were made, right?
If so, consider making these GMK renders visible by default, and moving the currently-displayed kit renders into the expandable portion of the March update.  This would help minimize future misunderstandings.
Update: 12 March 2020
{MORE}
GMK Final Renders. Made a couple of small changes: "Lock" and "Num Lock" changed to "Scroll" and "Num" for consistency. Dakuten on Hiragana "modernized."
New estimated shipping: August - GMK gives a rough 23-25 week estimate from the invoice date for projects now, and that's what I'm basing this off of.
Offline mr_foggy
  • neue = nope
Re: [GB] GMK Umbra | Completed | Nov. 1 - Dec. 16, 2019
« Reply #78 on: Thu, 02 September 2021, 07:47:32 »
any chance we could ever see a R2 of this set? too good to not run again.
Offline AstralYT
« Reply #79 on: Thu, 02 September 2021, 09:27:02 »
Just doing my duty, echoing R2.
Offline Nexy
« Reply #80 on: Sun, 05 September 2021, 04:02:29 »
Really love this set but the prices on used market are ridiculous. Hoping for r2.
Offline OmegaZero55
« Reply #81 on: Fri, 04 February 2022, 14:51:49 »
Yeah, I always wanted this set, but it wasn't in the budget at the time. I'm hoping for an R2 sometime as well.
Offline YoungTerror
« Reply #82 on: Fri, 04 February 2022, 21:49:39 »
+1 for R2, but I could see the reasoning for waiting for things to settle down .
Offline tngpq
« Reply #83 on: Fri, 04 February 2022, 22:09:03 »
One of my favorite sets indeed but for R2 please no dixie mod.
Offline Esperianterra
« Reply #84 on: Sun, 01 May 2022, 10:48:50 »
Adding my voice for a r2, this is impossible to find even on the used market :(
Offline Dmitri
« Reply #85 on: Tue, 28 March 2023, 22:16:08 »
R2
Offline hyperfix8
« Reply #86 on: Wed, 29 March 2023, 18:16:01 »
R2 equivalent is happening with PBTFans
Offline mr_foggy
  • neue = nope
Offline Ranker2
« Reply #88 on: Sat, 01 April 2023, 05:15:05 »
Will the set have the same name? Haven't seen it pop up on any IC
Offline CaesarAZealad
  • Racc
« Reply #89 on: Sat, 01 April 2023, 10:49:13 »
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline CircuitHero
« Reply #90 on: Sat, 23 March 2024, 14:40:59 »
R2 ask. Not in the hobby when this set came out and it looks awesome in person.
Offline AMZ
« Reply #91 on: Sat, 23 March 2024, 23:59:12 »
R2 please.
Offline tactilesbad
« Reply #92 on: Tue, 26 March 2024, 05:13:10 »
seconding the R2 request. pbtfans version unsurprisingly ****ed the colors up and the set looks nothing like the og
Offline OmegaZero55
« Reply #93 on: Mon, 03 March 2025, 01:48:56 »
I would love an R2 as well. The PBTFans version just isn't as good as the original. I really regret not having the money to buy this set when it was in group buy.
Offline cht1821
« Reply #94 on: Tue, 11 March 2025, 15:07:48 »
+1 for r2 with gmk. Bought pbtfans before but didnt like it and sold it.
Offline FoxandFoundry
« Reply #95 on: Mon, 17 March 2025, 14:57:58 »
For those asking for an R2, this set pretty much already exists...as GMK 80082 BL00 + GMK Dracula....both still available to purchase right now from many places.
Offline Aspire
« Reply #96 on: Sat, 22 March 2025, 04:20:28 »
Dracula alphas are lighter, 80082 Bloo is a different blue. Not really the same. Also buying 2 keysets instead of one? In this economy?
