Author Topic: [IC] Infinikey PBT WoB/BoW Standard  (Read 40721 times)
Offline ref
Re: [IC] Infinikey PBT WoB/BoW Standard
« Reply #50 on: Sun, 03 November 2019, 09:52:20 »
black apple cool. From minila user,  is that possible put 3u spacebar in non-standard kit? ;)
Offline piit79
« Reply #51 on: Mon, 04 November 2019, 09:03:17 »
Any chance you could add an R1 1u backspace for full Preonic support? It's not very nice having to use the numpad "minus" key... Thanks!
Offline eniigma
    • Storefront:
« Reply #52 on: Mon, 04 November 2019, 13:16:54 »
definitely a fan! good luck!
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
« Reply #53 on: Mon, 04 November 2019, 17:13:00 »
This is one large kit.
Offline jagger27
  • ne 1.5U supers???
« Reply #54 on: Tue, 05 November 2019, 02:12:02 »
Will the 40s spacebars actually fit? My Katakana ones don't stay attached to the stabs. It's not my keeb because GMK ones fit fine. An improvement to the darkness of the reverse dyesub is very much welcomed. Glad to see you're working on it.
I'd like to see some different Escape options in the Mac kit. I like the Power icon thing from Extended 2048, because that's the actual correct legend. The X is subtle and quite nice, but not very Apple. See "Force Quit" below.
Besides that I'd probably be in for at least one reverse dyesubs and one of the normal white ones.  :thumb:
Offline geewiz
« Reply #55 on: Tue, 05 November 2019, 03:47:01 »
If I’m not just suffering from lack of coffee, the Apple kits are missing a second 1u Option/Alt key. A HHKB/Tsangan bottom row in true Apple fashion (Command next to space bar) would require two 1.5u Command and two 1u Option caps.
Never mind, they’re just in different groups. Getting coffee now.
« Last Edit: Tue, 05 November 2019, 03:53:29 by geewiz »
Offline vsrnth
« Reply #56 on: Tue, 05 November 2019, 15:05:46 »
Any chance for a colevrak/colevrak+ kit?
Offline KingOfMemes
« Reply #57 on: Tue, 05 November 2019, 15:08:18 »
A price tag of ~60-70USD was mentioned for colevrak earlier in this thread
Offline speaktobrett
« Reply #58 on: Tue, 05 November 2019, 18:49:46 »
Very excited to see this!
I'll buy both sets, I love ePBT :)
Offline Ensaum
« Reply #59 on: Tue, 05 November 2019, 20:38:11 »
You seriously just made my whole week. I'm in for BoW Apple and probably WoB Standard too.
« Last Edit: Tue, 05 November 2019, 20:42:54 by Ensaum »
Offline Rayndalf
« Reply #60 on: Tue, 05 November 2019, 23:32:54 »
Any chance for a second 1U shift key?
Offline zakatak
  • no cash
« Reply #61 on: Wed, 06 November 2019, 00:44:01 »
Do you have official price quotes now?
Offline stoffelduss
« Reply #62 on: Wed, 06 November 2019, 04:22:02 »
This!
But for me to buy it I would need a colevrak+ add-on!
Offline Loztredditor
  • Linears.
« Reply #63 on: Wed, 06 November 2019, 04:57:00 »
in for all
Offline Datastream
« Reply #64 on: Wed, 06 November 2019, 05:55:35 »
I'm in on this probably very likely because PBT
Offline xenotropic
« Reply #65 on: Thu, 07 November 2019, 18:41:23 »
I have Katakana, and the one thing that kit didn't have that I would love to see in this is r3/r4 pgup/pgdn. With that said I'm in for a BoW kit, and possibly a WoB kit if it's price like katakana.
Offline bball2
« Reply #66 on: Thu, 07 November 2019, 21:07:35 »
Great compatibility! Depending on price would be down to pick up one of each apple sets  :thumb:
Offline AlcoholEnthusiast
« Reply #67 on: Thu, 07 November 2019, 22:19:46 »
What is the projected price per set?
Are there any sample caps (ideally next to GMK WoB or GMK Minimal/ePBT BoW) to see how the colors are going to come out?
Offline The Equals D
« Reply #68 on: Fri, 08 November 2019, 09:12:24 »
I've been hoping for this since I saw the katakana set. For sure picking up a set or two. Good to see the extra B key as well.
Offline ywcsam
« Reply #69 on: Fri, 08 November 2019, 11:06:08 »
I own a set of katakana WOB, here are a few things that I notice:
- The black is more like a dark navy instead of true black. It doesn't look bad at all, but it's definitely not 100% black.
- Longer keys have very slight warp to them. 1 key (6.25U Space) was unusable due to warping. I know this is common in PBT key caps, but other manufacturers have proved it is avoidable (maybe just better QC?) .
- Thickness of the key caps seem to be slightly thinner than EBPT.
- I don't know if it's just me, but I feel like the typing surface of these caps is ever so slightly less than GMK's.
Other than these few short comings, the set are nice to the touch, sounds decent, and definitely very affordable. Hopefully the Infinikey will improve on those!
I kind of want to see Katakana legends alphas as a separate kit. That would allow people to mix and match with their GMKs.  ;)
« Reply #70 on: Fri, 08 November 2019, 14:55:00 »
So many keys but no R3/R4 PgUp/PgDn :(
Offline ProlificPanda
« Reply #71 on: Sun, 10 November 2019, 23:03:16 »
R1 1U Backspace please! For split BS that don't like using pipe.
Offline jrs
« Reply #72 on: Wed, 13 November 2019, 13:25:27 »
I hope the black will be dark enough this time for it to go well with the wilba thermal.
« Reply #73 on: Wed, 13 November 2019, 16:27:24 »
Any idea when the groupbuy will be taking place?
Offline nasp
« Reply #74 on: Wed, 13 November 2019, 21:01:45 »
+1 for Colevrak
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #75 on: Wed, 13 November 2019, 21:59:03 »
If you are considering adding a Colevrak+ kit, I recommend this.
<-- Which layouts use which keycaps.
Offline RominRonin
« Reply #76 on: Sat, 16 November 2019, 12:02:23 »
Offline Ryuzumei
« Reply #77 on: Sat, 23 November 2019, 18:03:14 »
Is the BoW color around the same white as GMK Minimal?
Offline Vireca
« Reply #78 on: Sun, 24 November 2019, 04:45:01 »
Regarding warped large keys, to fix it you should make the keys thicker. Its the only way to fix it with PBT keys
« Reply #79 on: Tue, 26 November 2019, 02:43:42 »
Offline jf908
« Reply #80 on: Tue, 26 November 2019, 06:37:23 »
The Apple WoB set might be my favourite keycap set I've ever seen.
There are few changes I would wish for to make it perfect:
  • Most importantly I was hoping there would be a R3 |\ key like on UK Apple keyboards.
  • I think I would prefer the arrow in the centre of the ISO enter key rather than at the bottom.
I agree with this about the escape key.
Offline Skarekrow
« Reply #81 on: Sat, 30 November 2019, 21:45:41 »
Definitely gonna grab one set of each white and black for Windows :)
Offline Datastream
« Reply #82 on: Mon, 09 December 2019, 09:22:45 »
I'll probably buy that WoB
Offline Funkzilla
« Reply #83 on: Mon, 09 December 2019, 14:38:54 »
Icon mods need to be a kit.. I'm sure they'd sell so goddamn fast. There are literally no options outside of the GMK Wob/Bow icon mod kits that I've found to be viable with good quality. I would die for one.
Offline modeseven
« Reply #84 on: Mon, 09 December 2019, 15:31:31 »
Don't know how I am only seeing this now.
This is most certainly a day 1 buy for me.
Offline h.parks
« Reply #85 on: Mon, 09 December 2019, 16:44:48 »
given all the e-white boards lately, i would love a super-bright WS2-style white in this set to match (like with gmk monochrome or metaverse i think?)
Bottom-Mount Alps Dactyl | Ergodox | PLA75 | SA Penumbra | DSA Blanks | GMK First Love
Offline kaisn
« Reply #86 on: Wed, 11 December 2019, 05:39:25 »
Yes, please. Let me buy it. The sooner the better.
Offline Vireca
« Reply #87 on: Fri, 13 December 2019, 05:33:19 »
Any way to add another 1,5u spacebar? This way we can cover ergos like corne or kyria
I think the kits need some tweaks
« Last Edit: Tue, 17 December 2019, 08:44:11 by Vireca »
Offline backbang
« Reply #88 on: Sat, 14 December 2019, 02:45:20 »
can i get an exact color code for the PANTONE white? i'm looking for a tint that matches my case
Offline badchad
« Reply #89 on: Tue, 17 December 2019, 06:18:34 »
When will these be available to buy / shipped?
BAD
« Reply #90 on: Tue, 17 December 2019, 10:43:21 »
Pantone books dont typically include white chips. Sorry.
Offline suparnemo
« Reply #91 on: Fri, 20 December 2019, 19:25:01 »
Insta story said tonight?  :eek:
Offline SwitchKeys
    • SwitchKeys
« Reply #92 on: Fri, 20 December 2019, 19:44:39 »
GB is live with us guys for those from Oceania.
https://www.switchkeys.com.au/products/infinikey-white-on-black-black-on-white-group-buy
We've tried to price these as affordable as possible as we know they'll be popular.
Offline modeseven
« Reply #93 on: Fri, 20 December 2019, 19:52:07 »
Why are the black more expensive than white? New to the scene, honest question. Either way excited to see this launch. ;D
Offline Ensaum
« Reply #94 on: Fri, 20 December 2019, 20:05:21 »
Reverse dye sub. Harder and thus more expensive.
Offline js
« Reply #95 on: Fri, 20 December 2019, 21:05:56 »
Are the small spacebars (1u, 1.25u, 1.75u, 2u, 2.25u, and 2.75u) convex?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #96 on: Fri, 20 December 2019, 22:14:23 »
Still a great price at around $125 USD for the size of the kit though. I'm in on Sanctuary Rebirth, so if that turns out good I might bite on a WoB kit. Been tempted by Drops GMK WoB set since I don't have a WoB set yet, but with all the keys in this set I'd rather grab this if Infinikey can get the reverse dye sub right.
Offline rockydbull
« Reply #97 on: Fri, 20 December 2019, 22:28:39 »
Description says apple kit has 195 keys while standard has 185. What are the 10 extra keys?
Offline modeseven
« Reply #98 on: Fri, 20 December 2019, 23:07:52 »
What are your guys opinion on Infinikey? I am not familiar with this manufacturer.
Offline Rob27shred
« Reply #99 on: Fri, 20 December 2019, 23:14:14 »
Personally I can't speak to their quality yet as Sanctuary Rebirth will be my first set from them, but they did run the Katakana sets from TKCs GB awhile back. Hopefully some people who got those sets can chime in, but otherwise I'd check the GB thread for that. AFAIK the only major complaint on those sets was the black dye wasn't a true black, more like a very dark gray. I have also heard of some people getting warped stabilized keys too (particularly the 2.75u Shift & spacebars), although I don't think it was a widespread issue & that is par for the course with PBT caps.
