Author Topic: 7 Cherry G80-8113HRBUS-2  (Read 3199 times)
Offline lmnop
« on: Thu, 10 June 2010, 14:04:43 »
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=CHERRY+D-91275
$15 + $8 shipping /ea.
Cherry MX Brown or Clear PCB Mounted, US Layout, Double Shot Keycaps, NKRO.
nice starter or Filco owners interested in harvesting Double Shot Keycaps.
« Last Edit: Thu, 10 June 2010, 15:53:22 by lmnop »
Offline roadblock2thesun
« Reply #1 on: Thu, 10 June 2010, 21:48:57 »
Can anyone confirm browns? I though the R signified blacks or clears?
Offline Nonmouse
« Reply #2 on: Thu, 10 June 2010, 22:00:00 »
I've got a couple of G80-8113HRBUS-2 with browns, but I've seen them with brown, black or white (clear) switches.  Only way to know for sure is to pull a keycap.
Offline 1839cc
« Reply #3 on: Thu, 10 June 2010, 23:22:17 »
I just got one with clears. I'm typing on it right now.
Not from that seller though.
« Last Edit: Thu, 10 June 2010, 23:24:53 by 1839cc »
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline ricercar
  • mostly abides
« Reply #4 on: Fri, 11 June 2010, 03:06:03 »
HPBUS was browns for me.
Offline kwang2009
« Reply #5 on: Fri, 18 June 2010, 23:03:43 »
bah.. The left control is BUSTED on the PCB level. :(
This thing is ok otherwise. I'll wait on another one. How often do these come up on auction?
« Last Edit: Fri, 18 June 2010, 23:06:28 by kwang2009 »
Offline Nonmouse
« Reply #6 on: Fri, 18 June 2010, 23:18:49 »
Pretty frequently.  They're usually listed as MX-8100's.  Laser keys are more common than double-shots, so if you care, make sure to check that it's a G80-8113Hxxxx.
Offline kwang2009
« Reply #7 on: Sun, 20 June 2010, 07:59:58 »
The B the V and the Num Lock are also problematic and I've seen more than one instance of green 'rust'. I guess $23.00 wasn't too much to pay for double shot caps. How do they fit on the filcos? I remember someone saying that they were a bit squattier than the ones on the filco.
I never really thought how good it would be to to go back to the Eclipse until I let its wrist rest to work its magic. I also never knew how heavy the keys on the clears were until owning the G80-8113HRBU-2 for a little while (though its still in one piece, its just not plugged in).
« Last Edit: Sun, 20 June 2010, 09:20:17 by kwang2009 »
