Author Topic: Are all these parts for my keyboard compatible?  (Read 2878 times)
Offline eric424
« on: Sun, 17 November 2019, 22:49:58 »
Offline yui
Re: Are all these parts for my keyboard compatible?
« Reply #1 on: Mon, 18 November 2019, 02:01:15 »
i dunno about that paintbrush though, does not seem mkb grade. :)
For the rest it seems to my eyes fairly compatible, you will need to cut the 2 extra plastic legs from your pcb mount switches switches though as like most hs pcb this one does not have the holes for them, so keep that in mind or try to find plate mount switches
Offline Leslieann
« Reply #2 on: Mon, 18 November 2019, 04:51:12 »
Not sure what you think you need dielectric grease for.
As for the brushes, dollar store bargain, you aren't doing artwork.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline yui
« Reply #3 on: Mon, 18 November 2019, 05:22:29 »
what are you talking about, only the best brushes will do for keyboard lubing, applying the absolute perfect amount of lube is paramount to the whole experience.
(only joking, do what Leslieanne said, much better use of your money)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #4 on: Mon, 18 November 2019, 12:08:40 »
Just splat all over it like those "ghost" MM10 mods
Just my thoughts
