Author Topic: [IC] KAT Space Cadet - Opening April 1st, new Yellow Accents  (Read 102106 times)
Offline tominabox1
Re: [IC] KAT Space Cadet - Opening April 1st, new Yellow Accents
« Reply #200 on: Mon, 16 March 2020, 08:10:35 »
Is there no estimate for accents kit yet?
Correct.
Offline umberts
Offline piit79
« Reply #202 on: Wed, 18 March 2020, 15:17:03 »
The kitting/pricing is absolutely awesome! I could get full ortho set for $55. But obviously I will have to get the novelties too ;) And possibly a few other kits.
Can't wait for April!
Offline equalunique
« Reply #203 on: Thu, 19 March 2020, 19:56:24 »
I *love* that so many of the small spacebars come convex. I wish more keycap profile offerings had that.
Offline harlekein
« Reply #204 on: Fri, 20 March 2020, 05:22:13 »
Any chance of adding 1.5u bars to the accent kit?
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #205 on: Fri, 20 March 2020, 21:47:17 »
Are all the blanks in the Spacebars kit convex?
Offline tominabox1
« Reply #206 on: Fri, 20 March 2020, 22:47:13 »
Yes!
Offline rondg
« Reply #207 on: Fri, 20 March 2020, 23:22:17 »
Please consider adding R5 Del key on the 60%+ Mods kit. It's the only key needed for it to support the most common 75% layout.
Offline umberts
« Reply #208 on: Thu, 26 March 2020, 05:24:27 »
Less than a week away from the supposed start of the GB and we are still missing complete kit renders, yellow accent kits prices and prices in other currencies.
Is everything still happening?  Please I need a good news :D
Offline riterdando
« Reply #209 on: Thu, 26 March 2020, 05:34:55 »
Is there a way to purchase a Hyper7, PCB and case?
Love that board, would like to get one.
Gesendet von iPad mit Tapatalk
Offline catbus
« Reply #210 on: Thu, 26 March 2020, 06:59:59 »
Not for sale at the moment, but mechboards.co.uk is going to be running an R3 soon. You can sign up for a notification here: https://groupbuys.mechboards.co.uk/shop/hyper-7-keyboard-r3-coming-soon/
Offline nasp
« Reply #211 on: Mon, 30 March 2020, 10:38:06 »
What are sizes of bars on the accent kit?
Offline tominabox1
« Reply #212 on: Mon, 30 March 2020, 10:39:33 »
6.25, 7u, 2x2u and 1.75u
Edit- looks like our shots for the accent kit actually have all 3 small bars as 2u. I will look into what those should be.
Wednesday is almost here!
« Last Edit: Mon, 30 March 2020, 11:01:48 by tominabox1 »
Offline tominabox1
« Reply #213 on: Mon, 30 March 2020, 21:38:05 »
We've revised the yellow kit for more useful small bars... 2 days left!
Offline outerspace
« Reply #214 on: Mon, 30 March 2020, 21:49:46 »
Any last minute chance for a yellow R5 ESC?
Offline konstantin
  • Formerly constexpr
« Reply #215 on: Tue, 31 March 2020, 05:21:48 »
You might want to drop the 1.75u spacebar, seeing as it's only used on three boards (Vortex Core, Daisy, JD40), one of which actually requires two such spacebars. This would save you three keys in total across the set.
Offline tominabox1
« Reply #216 on: Tue, 31 March 2020, 11:07:11 »
Fixed that for ya bud.
Offline fatmcgav
« Reply #217 on: Tue, 31 March 2020, 12:29:15 »
So am I right in thinking that for a Corne (helidox / crkbd) build, I'd need an alpha's set and an ortho's set?
And as I'm UK based a UK ISO set?
Cheers
Sent from my LYA-L09 using Tapatalk
Offline tominabox1
« Reply #218 on: Tue, 31 March 2020, 12:32:10 »
Cheers
Yes, alpha and ortho should cover you. As far as ISO goes, I'm not sure it applies to a corne but it might depending on how you have your board set up.
Offline fatmcgav
« Reply #219 on: Tue, 31 March 2020, 12:42:16 »
Cheers
Ah, that's a good point... No num row to worry about etc...
Sorry, still new to this whole ortho keyboard thing...
Offline tominabox1
« Reply #220 on: Tue, 31 March 2020, 17:08:09 »
GB is live in Asia! Lets move discussion to the gb thread: https://geekhack.org/index.php?topic=105375.0
Offline Gert Fischer
« Reply #221 on: Sun, 05 April 2020, 13:51:09 »
the 2u keycaps on the top row of the hyper7 kit, are do they mount on a stabiliser and one switch, or on two switches without a stab?
Offline eskimojo
    • KeycapLendar
« Reply #222 on: Sun, 05 April 2020, 14:35:52 »
They use a stabiliser for each  ;)
