Author Topic: [IC] JetVan PCB (MiniVan case compatible)  (Read 12595 times)
Offline evangs
  • TheVan
« on: Tue, 19 November 2019, 23:32:15 »
JetVan is a minivan case compatible pcb the supports a single layout. The pcb requires soldering the switches.
All smd components are pre soldered. The pcb has 10 rgb leds for underglow. The price will be ~$40 + shipping ($4 USA, $20 INT).
The production run will be black with white silkscreen.
The name JetVan comes from this layout originally being proposed by Jetpacktuxedo.
IC Form
https://forms.gle/eysJ1tC4Db4eov618
Offline psxndc
Re: [IC] JetVan PCB (MiniVan case compatible)
« Reply #1 on: Wed, 20 November 2019, 00:09:20 »
I'm so confused. I thought you were peacing out of the community.
Ortho. Always.
Offline mononokay
« Reply #2 on: Wed, 20 November 2019, 00:19:43 »
Yes please
Offline evangs
  • TheVan
« Reply #3 on: Wed, 20 November 2019, 00:28:23 »
peacing out as a vendor. I still want to do projects and create stuff. I just don't want to manage a storefront etc.
Offline psxndc
« Reply #4 on: Wed, 20 November 2019, 00:30:22 »
Got it. Well this looks like a cool little continuation, and I have an extra minivan case sitting around, so I'm in.
Ortho. Always.
Offline txclack
« Reply #5 on: Wed, 20 November 2019, 00:36:50 »
Offline psxndc
« Reply #6 on: Wed, 20 November 2019, 02:10:36 »
Is the only layout difference between this and an MV44 the bottom row?
Ortho. Always.
Offline Visionaire
« Reply #7 on: Wed, 20 November 2019, 07:08:47 »
Doesn't support split space =(
Offline sickbabies
« Reply #8 on: Wed, 20 November 2019, 07:10:47 »
This also has underglow LEDs instead of indicators
Offline funderburker
« Reply #9 on: Wed, 20 November 2019, 07:48:50 »
I just gotta ask why you are offering a new PCB with a single layout when you had various iterations of the PCB already with things that people were asking before? Is it really that big of a difference in pricing?
Keyboard design by Skepur
Offline Hedgey
« Reply #10 on: Wed, 20 November 2019, 09:30:03 »
Very much looking forward to this and using that extra minivan case you sent me for it.
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline Robosculpts
« Reply #11 on: Wed, 20 November 2019, 09:39:29 »
I knew I should got in on the mini van!
Offline evangs
  • TheVan
« Reply #12 on: Wed, 20 November 2019, 10:04:30 »
bottom row, RGB underglow instead of indicators, not hotswap
if you want split space use minivan pcb (more will be available in the future)
This pcb has different features than the minivan pcb. I don't like swiss cheese pcbs.
Offline psxndc
« Reply #13 on: Wed, 20 November 2019, 10:19:15 »
Thanks for the replies, all. I was specifically asking about LAYOUT differences so I could plan when scoping keycaps. ;D
Ortho. Always.
Offline tominabox1
« Reply #14 on: Wed, 20 November 2019, 10:29:22 »
Only difference is big spacebar.
Offline evangs
  • TheVan
« Reply #15 on: Wed, 20 November 2019, 10:55:09 »
I guess you could say it's a "big" difference
Offline kennardsmith
« Reply #16 on: Wed, 20 November 2019, 13:25:49 »
This isn't my chosen minivan layout, but i am so happy to see new minivan stuff still happening.
GLWGB
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline rowie
« Reply #17 on: Wed, 20 November 2019, 14:12:27 »
Wonder if this will fit the older minivans like my turquoise from Massdrop. Otherwise I知 in since I have a Kumo I can put this in.  :thumb:
Offline evangs
  • TheVan
« Reply #18 on: Wed, 20 November 2019, 14:18:02 »
This PCB is compatible with any minivan case EXCEPT for R1 cases, called TheVan 44,  due to different mounting pattern.
potentially compatible cases (may have an issue with the stabilizer)
nickel plated
silver/black
white power coat
all painted cases
compatible cases include
Massdrop minivan
all plastic cases
« Last Edit: Wed, 20 November 2019, 14:25:45 by evangs »
Offline rowie
« Reply #19 on: Wed, 20 November 2019, 15:33:42 »
nickel plated
silver/black
white power coat
all painted cases
Massdrop minivan
all plastic cases
Nice! Now I値l have to get two if this becomes a reality. Thanks.
Offline MikeTheTiger
« Reply #20 on: Wed, 20 November 2019, 16:14:21 »
I知 just wondering how you guys type numbers.
"all the numbers or none of them cmon man" -Kokaloo
Offline evangs
  • TheVan
« Reply #21 on: Wed, 20 November 2019, 19:52:33 »
One, two, three, four.... easy
nickel plated
silver/black
white power coat
all painted cases
Massdrop minivan
all plastic cases
Thank you! 95% this gonna happen, maybe higher
Offline psxndc
« Reply #22 on: Wed, 20 November 2019, 23:56:51 »
They're in a second layer, but which key maps to which number depends on the person's preference.  For me, I prefer them in the same place, i.e., across the top. So if I hold down FN and then hit Q, it's 1, W is 2, E is 3, etc. Some people lay them out like a numpad in the second layer, so FN and M is 1, comma, is 2, period is 3, J is 4, K is 5, etc up to O ("oh") being 9.
Ortho. Always.
Offline thornkin
« Reply #23 on: Thu, 21 November 2019, 01:57:18 »
Not sure I want a 40% without a split space, but it is great to see you remaining active Evan!
Offline evangs
  • TheVan
« Reply #24 on: Thu, 21 November 2019, 05:40:52 »
I do the numpad approach
Offline h9n9n3
« Reply #25 on: Thu, 21 November 2019, 13:26:20 »
im in  :-X
Offline evangs
  • TheVan
« Reply #26 on: Tue, 26 November 2019, 08:37:38 »
The IC form has been slowing receiving positive entries. My next question for the IC is December launch or hold off until the new year?
Offline Jampot_298
« Reply #27 on: Tue, 31 December 2019, 04:10:15 »
I'd love to see this beauty come out in January! Please proxy with mykeyboard.eu though for people in the eu
Sent from my ONEPLUS A6003 using Tapatalk
