Author Topic: usb 3.0 connector will it work ?  (Read 5062 times)
Offline rjohn
« on: Sun, 24 November 2019, 14:22:41 »
hello i have a question
building a usb keyboard cable will it work with usb 3.0 connector (i will connect only the four cables)?
https://www.ebay.com/itm/5PCS-DIY-USB-3-0-Male-Connector-USB-Jack-Soldering-Type-Line-Tail-Socket-3-in-1/333202161711?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Offline Leslieann
Re: usb 3.0 connector will it work ?
« Reply #1 on: Sun, 24 November 2019, 14:35:07 »
Yes, USB 3 is backwards compatible, as is type C.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline rjohn
« Reply #2 on: Sun, 24 November 2019, 15:19:25 »
that i thought as well but
just build 2 cables and does not work ,with usb 2 connector works.
« Reply #3 on: Sun, 24 November 2019, 20:48:30 »
I would use only a USB 2 connector for USB 2 cables. The colour of the plastic piece is used to see which kind of cable it is.
While cables are backwards-compatible, it is not always straightforward: There are some rules for making adapter cables between Type C and Type A.
Also, if you make a very long cable you may need to use a cable with thicker wires, especially for USB 3.
Offline rjohn
« Reply #4 on: Sun, 24 November 2019, 23:37:32 »
ok ,thanks for your comments.
Offline Leslieann
« Reply #5 on: Mon, 25 November 2019, 04:07:13 »
C is different because of the amperage C allows will melt the type A connector.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
