Author Topic: KEMOVE , kickstarter from $59 + shipping $10  (Read 4797 times)
Offline rjohn
« on: Tue, 26 November 2019, 23:44:24 »
Offline rjohn
Re: KEMOVE , kickstarter from $59 + shipping $10
« Reply #1 on: Fri, 29 November 2019, 05:20:46 »
Offline powwu
    • Discord
« Reply #2 on: Sun, 01 December 2019, 16:34:47 »
Interestingly, this board seems to use the same driver as the GK61. Possibly it uses the same pcb?
Offline rjohn
« Reply #3 on: Tue, 03 December 2019, 11:05:39 »
might be
they already reached their goal and double it
if they hit $30,000, there will be one Key Switch Puller and one Keycap Puller along with each keyboard for FREE!
« Last Edit: Tue, 03 December 2019, 11:07:46 by rjohn »
Offline treeleaf64
    • treeleaf64
« Reply #4 on: Tue, 03 December 2019, 11:37:34 »
If I get the 61 key version (the 60% board), will I be able to swap the spacebar out for two keys? Or do I have to buy the more expensive version for that to work. The board itself seems quite interesting, of higher quality than most of the prebuilts that you can buy for that price range.
Everyone must pay the cat tax
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #5 on: Tue, 03 December 2019, 12:00:04 »
Is this hotswap
Just my thoughts
Offline rjohn
« Reply #6 on: Tue, 03 December 2019, 14:06:21 »
Is this hotswap
from their description :
KEMOVE 61-key boasts simple and minimal design and dazzling backlight effects. It is a fully customizable mechanical keyboard for it is compatible with almost all the key switches and keycaps in the market. You can take pleasure in the process of DIY your very own KEMOVE anytime, anywhere you want by replacing the hot-swappable switches and keycaps hassle-free. At an unbeatable price of only $59, KEMOVE 61-key is without a doubt, the best amongst all personalized keyboards.
about the space bar i dont think its the same pcb
Offline Sup
« Reply #7 on: Tue, 03 December 2019, 15:57:56 »
it looks suspiciously like the GK64, but from what i see is that it uses 2 space bars and Bluetooth. But still why the 2U left shift  :(
current
Coming soon
Offline Sintpinty
    • My Roblox Profile
« Reply #8 on: Fri, 06 December 2019, 11:17:41 »
Is this hotswap
I want a hotswap board so badly but again it isn't a need...
Just my thoughts
Offline rjohn
« Reply #9 on: Fri, 06 December 2019, 14:05:27 »
$30.000 goal reached.
Offline kobusestas
« Reply #10 on: Fri, 06 March 2020, 14:56:10 »
I received my two Kemove 61's with Gateron Brown switches. I like the board for the most part however their "Software Driver" isn't compatible for it yet so no remapping or RGB customizations can be done outside of the out of the box ones which are rather limited, which is unfortunate. I'm unsure what PCB they're using, it might be custom, i see it's labeled Turing_KB-11U35-V1.2 but I can't find much online for that. I see it has these chips: NXP LPC11U35F/401 chip and a CYW20730A2KML.
