Author Topic: IBM 5251 Spacebar broke...Need a fix  (Read 3152 times)
Offline FRANCO
« on: Wed, 27 November 2019, 12:33:43 »
The hole that holds the stabilizer broke (pics below) while I was cleaning the keyboard. I actually removed the spacebar with no fuss. But when I went to remove the stabilizer, I literally just touched it and it popped the plastic holder clean off. Anyone know of a fix? Unfortunately, spares are hard to come by =/
https://imgur.com/2wCLuvc
https://imgur.com/HrKmHCO
« Last Edit: Wed, 27 November 2019, 12:42:43 by FRANCO »
Offline gipetto
Re: IBM 5251 Spacebar broke...Need a fix
« Reply #1 on: Wed, 27 November 2019, 14:03:13 »
I've repaired plastic before by cutting out a piece of perspex sheet, filing it to shape and supergluing it in place. In your case, depending on the length of the stab wire, you could glue it to the side of the remaining piece.
a different approach would be to melt two holes through the remaining piece, and push some stiff wire through one hole, then over the top of the remaining piece and in to the other hole. you can taper the wire into a point over the damaged area to prevent any movement.
Offline FRANCO
« Reply #2 on: Wed, 27 November 2019, 15:07:06 »
Thanks! I think I'll try the perspex sheet.
edit, in looking up perspex, I found moldable plastic...Thanks again man!
« Last Edit: Wed, 27 November 2019, 15:10:01 by FRANCO »
