Author Topic: AEKISO60: A AEK ISO 60% PCB  (Read 47120 times)
Offline Pulsing Penguin
Re: AEKISO60: A AEK ISO 60% PCB
« Reply #50 on: Fri, 04 December 2020, 10:44:16 »
one over the moon owner of an AEKISO60 board  ;D
« Reply #51 on: Fri, 04 December 2020, 10:52:26 »
this was the board when i picked it up, so happy to have given it a new lease of life :)
Offline Applet
« Reply #52 on: Fri, 04 December 2020, 13:29:06 »
Cool, looks good! Thanks for sharing! ;D
« Reply #53 on: Sat, 12 December 2020, 17:40:54 »
I know it's not 100% related to the PCB, but I just retrobrighted my spacebar and I think it made the build come together fully
PS: USE THIS PCB!
Offline siggie0815
« Reply #54 on: Sat, 09 January 2021, 07:32:30 »
Hey, thanks a lot for taking the effort to make ISO users happy. I'm planning to build sth. like that as soon as I can get some ALPS Orange switches.
So my question is, if this board is available or if I have to order my own "Prototype" somewhere. This would mean, I have to solder all the parts by myself? Or is there any service that produces the PCB and does the SMT soldering for me?
Another question is if it is possible to switch the "Alt" (1.25) and "Gui" (1.5) keys in the bottom row. Which would result in "|  1.5  |  1.5  | 1.25 |     6.5     | 1.25 |  1.5  |  1.5  |". I guess this feature might be appreciated by many PC users (but I might be the only one building my own AEK ISO keyboard :D).
Offline Applet
« Reply #55 on: Mon, 11 January 2021, 06:48:31 »
The idea is to make them relatively easy to order and build yourself using the releases at github from services like JLCPCB. They can assemble almost everything. Currently you'll need to solder the MCU, USB-C connector and/or the daughter board connector.
Currently not supported to do a "|  1.5  |  1.5  | 1.25 |     6.5     | 1.25 |  1.5  |  1.5  |" bottom row, but you can assign alt/gui to whatever you want in firmware. I will consider this for future releases.
I do have a few of the first prototype PCB's left, I'll drop you a PM regarding that.
Offline ThomasK68
« Reply #56 on: Sat, 13 February 2021, 04:24:38 »
Hi ! Thank you for your work it's amazing !
Do you have any pcb left ? I would like to buy you one for a friends' birthday present !
Thank you  :)
Offline Genericusername56
« Reply #57 on: Tue, 13 April 2021, 03:31:33 »
Do you still have any of those PCBs left or are there any plans of manufacturing more of them?
Offline Applet
« Reply #58 on: Mon, 26 April 2021, 05:39:23 »
The last two protos sold to the people above.  :cool:
Offline Applet
« Reply #59 on: Wed, 18 August 2021, 04:51:34 »
Latest release (A4) is now uploaded to github and added to releases.
Changes:
- Moved daughter board connector for better fit in bakeneko and added cutout in PCB outline for bakeneko V3 (untested).
- Added two different BOM's for easier assembly of either use with tray mount or use with a case using daughter board.
- Minor tweaks and fixes
A bakeneko with AEK curvature would fit this project so nice :D
Offline Applet
Offline ideus
  • Björkö.
« Reply #61 on: Fri, 20 August 2021, 06:57:01 »
Most AEK vintage sets have space bars that do not match the other keys in them; therefore, it is interesting to see that yours does. Why is that? Did you retro-bright it?
Offline Applet
« Reply #62 on: Fri, 20 August 2021, 14:11:27 »
The picture above is not my board, so I'm not sure. I would assume it has been retro-brighted.
Offline bigapplepietart
  • Topre Convert
« Reply #63 on: Mon, 27 December 2021, 22:53:25 »
Looks sweet, will consider picking one up in the near future.
Current:
Heavy Grail (Purple DES V1) | hiney tkl one PC (Orange SKCM Alps) | Lunar II (Green SKCL Alps) | Sho S60 V2 (Purple DES V1) | HHKB Hybrid Type-S (45g Stock Domes)
Past:
Razer Blackwidow (MX Blues) | FC660M (MX Blues) | GH60 (Ergo Clears) | 8x mkI (Vintage Blacks) | Klippe (Sakurios) | Equinox (Sakurios) | MGA (Silent Alpacas) | Kei (Creamsicles) | KFE CE (Alpacas) | Rukia R1 (Durock L7) | H60 (Silent Blacks) | E80-1800 (MX Blacks) | Ottantaquattro (Vintage Blacks) | hbcp (Vintage Blacks) | HHKB Pro 2 (45g Aged Domes) | ADK64 (Blue SKCM Alps) | Palmetto (Ultraglides)
Offline Applet
« Reply #64 on: Sat, 01 January 2022, 14:57:44 »
I'm glad you like the project :D
I will try to keep these in stock, for people who don't want to DIY: https://4pplet.com/products/aekiso60
I also have a compatible plate: https://4pplet.com/products/iso-aek-60-plate
They'll always be available open source also for DIY
