Author Topic: A UK equivalent to Krytox 205g0? Or Tribosys 3204?  (Read 19099 times)
Offline benfrain
    • benfrain.com
« on: Sun, 01 December 2019, 16:07:38 »
Anyone from the UK know of an easy to source equivalent to Krytox 205g0? Or even Tribosys 3204?
No where in the UK seems to stock either of those; surely an equivalent exists? Seems crazy to have to import a few ml of lubricant!
Offline treeleaf64
    • treeleaf64
Re: A UK equivalent to Krytox 205g0? Or Tribosys 3204?
« Reply #1 on: Mon, 02 December 2019, 15:40:16 »
If you can't find Krytox or Trybosis, I have tried using PTFE powder as a lubricant for MX switches. It is supposed to be better than both grease lubricants, but it is pretty messy. It wasn't a problem for me. I lubed around 100 vintage blacks with the powder, and used around 1/3 of the entire thing, so I'm not sure that it is equivalent to Krytox or Trybosis on price per switch.
Everyone must pay the cat tax
Offline benfrain
    • benfrain.com
« Reply #2 on: Mon, 02 December 2019, 15:46:05 »
Thanks, to be honest I might just have to take the hit and order some (there's an 'offer' on Drop currently).
I did think about trying to find something similar. Did a little googling to find out exactly what Krytox was and uncovered this:
Krytox fluorinated oils are a series of low molecular weight, fluorine end-capped, homopolymers of hexafluoropropylene epoxide with the following chemical structure:
F-(CF-CF2-O)n-CF2CF3
| where n=10 to 60
CF3
The polymer chain is completely saturated and contains only the elements carbon, oxygen, and fluorine; hydrogen is not present. On a weight basis, typical Krytox oil contains 21.6% carbon, 9.4% oxygen, and 69.0% fluorine.
And thought, yes, maybe I'll just order some instead of trying to find something the same ;)
Offline lolafineday
« Reply #3 on: Wed, 04 December 2019, 00:51:14 »
Go on switchmod.net or mykeyboard.eu if mykeyboard doesnt bave then switchmod will have for sure.
Sent from my SM-G975F using Tapatalk
Offline phinix
« Reply #4 on: Fri, 13 December 2019, 03:06:44 »
Scotland here - I've ordered Krytox 205g0 for myself from mykeyboard.eu
I've ordered stuff from them in the past as I couldn't find it anywhere in UK's shops.
Offline benfrain
    • benfrain.com
« Reply #5 on: Fri, 13 December 2019, 05:21:11 »
Brilliant. They were out of stock when I looked originally. Just ordered some 👍
Offline phinix
« Reply #6 on: Fri, 13 December 2019, 05:45:30 »
Ha, just looked in there again and all are out of stock.
Make sure you will get order confirmation from them and invoice as I ordered mine week ago and they forgot about it. Chased them yesterday and today and finally got an answer from them today that it will be posted today.
Offline benfrain
    • benfrain.com
« Reply #7 on: Fri, 13 December 2019, 06:18:36 »
Yes got the confirmation but that’s useful info, thanks 🙏
Offline eightbitraptor
« Reply #8 on: Fri, 13 December 2019, 14:56:51 »
I use something called Slug Slime Ultra - weirdly it's available on eBay (https://www.ebay.co.uk/itm/Bike-Grease-Ultra-15g-Fluorinated-PFPE-syringe-MTB-BMX-chain-gear-repair-cycle/254197722972), but not their actual website - it's about £12 for 15g and when I emailed them to ask about the composition (I explained I was looking for an alternative to Krytox 205g0 and what I needed it for) they sent me this:
This is a fully synthetic, fluorinated grease based on a mid-range viscosity PFPE fluid. It is a white grease, with PTFE thickener, NLGI grade 2 and is totally inert both chemically and physically. It has a wide operating temperature range of -40 to 200 C and is suitable for the lubrication of all plastics and elastomers, however it does not mix with other non-fluorinated greases.
Which sounds an awful lot like the formulation of Krytox to me. I've only done a few Gat blacks with it so far, but it goes on nicely and hasn't resulted in any visible damage to the switches, and it makes a noticeable difference to the feel and the sound.
Offline benfrain
    • benfrain.com
« Reply #9 on: Fri, 13 December 2019, 15:54:35 »
Hmmm, that sounds like a definite possibilty if the Krytox doesn't turn up!
Offline treeleaf64
    • treeleaf64
« Reply #10 on: Mon, 16 December 2019, 20:44:27 »
I was talking to some people the other day, and found 50g of Krytox on Taobao.
https://item.taobao.com/item.htm?spm=a230r.1.14.1.41672dd2y9jLxF&id=592352669241&ns=1&abbucket=8#detail
Offline keyboardfreak
« Reply #11 on: Wed, 19 February 2020, 10:28:25 »
Hi all, there should be some stock available on Keys.me
« Last Edit: Tue, 09 February 2021, 09:05:09 by keyboardfreak »
« Reply #12 on: Wed, 19 February 2020, 10:29:20 »
« Last Edit: Tue, 09 February 2021, 09:05:51 by keyboardfreak »
