Author Topic: Hello  (Read 4544 times)
Offline kangnguyen
Hello
« on: Wed, 04 December 2019, 02:40:36 »
Corded & cordless, what’s the best vacuum?
Vacuum cleaners have become an indispensable part of our life. However, you will see thousands of different vacuums from different brands. All the vacuums are created similarly. Thus, we might be confused about the differences between corded and cordless vacuum cleaners. Hence, to find the best vacuum cleaners, it is better to research well every type.
Firstly, we would like to show you the difference between corded and cordless vacuum cleaners.
❉❉❉ Selected For You: Top 10 vacuum cleaners
Corded vacuums
This vacuum is the traditional model. It is simple to use; we just plug it in and then run it. However, there are some advantages and limitations with this vacuum.
Corded vacuum’s advantages
It has excellent suction power, which is performed by its more potent motor compared to the cordless device. This model has the electric input of 1000 up to 2000 watts, which are powerful for suctioning out even the hardest dust.
This model also does not need a battery or recharge so you can use it as long as you want. You don’t have to worry about the charge or battery life. Especially, it is easy to reach most of the spots in your house. It comes with the wires of 6 to 8 meters long.
Notably, the corded vacuums are more significant than the others. Hence, it has a larger storage for dust. You can use for a longer time without worrying about emptying the vacuum too frequently. Moreover, it costs a low price. It is cheaper than the cordless vacuum.
Corded vacuum’s disadvantages
Because of being a corded vacuum, you are restricted by the cord. If you use it, you can only move around the area that the cord allows. When you need to go further than the wire, you need to unplug it and then plug it in another place that is closer to where you want to clean. Sometimes, it can be a little annoying.
Especially, the weight is a big consideration. It is heavy, around 7kg; it is heavier than the cordless vacuum. Thus, it is not convenient to push around if someone is a little weak.
If you can handle some disadvantages from the corded vacuum, you should consider finding precisely what is your best vacuum cleaner; you can choose some of Best vacuum cleaners on the market like the Shark Duoclean HV390UK, which is easy for storage. The Hoover Whirlwind has a reasonable price.
Cordless vacuum cleaners
Cordless vacuum’s advantages
As we mentioned, the cordless is lightweight compared to the corded models. It weighs around 3 kg, just half of a corded one. Thus, it can be easier to carry around your house and convenient to clean the hard-to-reach areas.
The corded model is designed for indoor use. However, the cordless can be used outside, in your car or anywhere it can reach. It can help you to clean even the smallest corners. You don’t need to worry about pushing a heavy vacuum and plugging in and out sometimes like the corded one.
Cordless vacuum’s limitation
Because it is so small, its dust capacity is also tiny compared to the corded model. Most corded cleaners can store around 2-3l of dust while the cordless can hold the only 0.6l. Hence, the cordless model needs to be emptied much more often. The filter should be cleaned frequently lest the dust and dirt create a blockage and causes it to stop working.
The battery life is one of its tiny limitations. You have to focus on how long the battery lasts. You have to consider when the battery needs to be charged. If you intend to buy for cleaning a larger surface of the house, it is better to go for the corded one. Besides, this model is quite expensive, almost double the corded model.
Some models of cordless you could buy are the Shark Douclean Truepet (which is flexible) or the Hoover Freedom (which is great because of the battery life), or the Dyson V7 for a reasonable price.
Verdict
Finishing our task in sharing some ideas about corded and cordless vacuums, it is time for you to make your own decision for Good vacuum cleaner brands in the world!
« Last Edit: Thu, 21 March 2024, 22:54:30 by kangnguyen »
Offline JinTea
Re: Hello
« Reply #1 on: Wed, 04 December 2019, 21:19:42 »
Welcome in!
How has it been getting into the hobby so far? Is there anything you need help with?
