Author Topic: Aergo - Design and Build Log  (Read 70003 times)
Offline Acereconkeys
  • Happiness = life - expectations
« on: Thu, 05 December 2019, 00:51:59 »
Hello,
I am sure a decent number of you on this forum know me but my name is Acerecon and I've been a fan of custom keyboards for a few years now. Today i am going to be sharing and discussing the design and build process for the first custom keyboard I designed and assembled... the Aergo.
Background:
My brother and I are both pretty active keyboard users. He's a computer scientist who works on robots and I'm a biomedical engineer who writes hundreds of emails, presentations, and reports every year. My brother recently had wrist pain and he's improved that by using a more ergonomic keyboard. At the time I had only owned a few custom keyboards but I learnt a lot from those as far as how a keyboard is designed so I figured what the hell maybe i should start trying to experiment with designing and manufacturing a keyboard that’s easier on the wrists while also being a high quality, well designed case. My aspirations were high as the two customs I had owned so far were both very high quality: the QXP and the TMO50.
Design Goals:
I did a lot of research into ergonomics when designing this keyboard. I noticed that a lot of users really loved the Alice. The alice reduces the strain on your wrists by angling the alpha row towards each hand independently. This in theory reduces the amount of twisting, known as pronation, that your wrists have to experience while typing.
Additionally, I noticed that a lot of the more ergonomically focused keyboards had more keys closer to the fingers so you don't have to as much wrist movement up, down and around the keyboard to type. I loved this on the TMO50 so I wanted this too. However, I am a pretty avid gamer (why does saying that somehow feel cringe...) so I personally needed more keys around the home row. Perfect for those moments where you need quick access and don't have the time to enter a layer and press a key. Things like buying an item or casting a rare but timing crucial spell in an MMO. Put all this information together and I identified a few key design goals.
Ergonomic spacing of the keys that puts all the alphas in positions that are closer to the fingers that are intended to use them.
Enough keys that I could still be able to play Mobas and FPS games.
Enough bottom row keys that I could have more flexibility with using multiple layers. I wanted enough keys near the thumbs you could have multiple layers for easier access to numbers and arrow keys without having to move my hands. This is the setup I have for TMO50 and I love it.
Tenting. I had tried this a few times with other keyboards and I just loved the way it reduced strain on the tendons. However, I do not like the aesthetics and usability of split keyboards, so I decided to try and build a keyboard that had tenting built in.
High quality, high profile, top mounted construction with a tightly spaced interior for good aesthetics and sound.
Now, I will be completely upfront here a huge inspiration for my design is the Esrille Nisse. I found that this design hit most of my goals described above. A lot of reviews online said this keyboard was really great so I knew I wanted to do something similar. However, from the Nisse I changed a few things to better meet my goals. In my opinion the nisse has a less pleasing aesthetic and I wanted to change that. Additionally, I have found that any bottom row key less than 2u is very unpleasant to use as a spacebar so I took the bottom row from Alice and adapted that to the Aergo.
Plates:
I’m an engineer by trade and if my CAD teacher drilled into my head anything it’s that you need to define all your sketches. This posed a really big challenge for designing the plate for Aergo. I got a rough estimate of the location of the keys from the Nisse, but I had to actually define it myself. Here’s what I ended up with.
The main jist of plate layout is this. Instead of each row being staggered on a normal keyboard, each column is staggered. This is accomplished by sequentially increasing the angle to the horizontal each column is at. The alphas begin at 0, then 5, then 11, then 12, then 14 degrees. This very closely follows the natural spacing of your fingers if you were to just lay your hands out at rest on a piece of paper and draw where each finger laid. (I did this to create the angles). Finally, there’s one additional column used by the 3 and 0 keys that’s angled at 7 degrees to rest in between the W and E column angles. The angle of the bottom row is chosen to most closely match the column in the middle of where the key is spaced. This looked the most natural to me. Here’s a photo of the plate with each angle marked.
Finally, the mods. I chose to use really small modifier keys on this layout for a few reasons. First is that full size mods is a waste. No one needs that much space, especially when you no longer have to twist my wrists to reach keys like you have to on a normal keyboard. Second is that the more columns there are, the taller the center of the keyboard is due to the tenting. I originally had wider 1.5u mods but cut it down due to how tall the height was getting in the middle. It was starting to look ridiculous.
The last weird thing about this layout is the additional keys on the inside. The reason for this is simple. When you have a normal keyboard, the position of the home rows is a little too close together to be comfortable in my opinion. By adding two additional keys on the inside between the halfs, this spaces the home rows out to a position that’s much more natural. If you have a normal keyboard, imagine instead of resting your hands on F and J, you instead rested them on F and L. Much more comfortable, huh?
Finally, I put some alignment pins and cutouts to position it in the top housing and slapped some cutouts on the mofo cause everyone else seems to be doing it, and it affects sound… or flexibility.. Or something. I think. Here’s the end result:
Angles:
This board uses a few angles on it. I chose 10 degrees for the tenting angle because it was a middle ground between significant enough to notice, but not significant enough it made the board look really really tall and ugly. Also, among users of tenting, it polled the most common tenting angle. Finally, I angled the board traditionally at 6.9 degrees because I like that angle.
Engraving
I chose an engraving of the house because the Kb-Kustoms community made fun of the keyboard by saying the back design looked like a monopoly house. Of course I thought that was hilarious, so I put a house on there. It’s modeled the same as the front of a monopoly house!!
Mounting Structure:
For this keyboard I chose top mount construction. I'd used the QXP, a sandwich mount keyboard, but i found that harsher and less comfortable to type on. Whether that was the build, the switches, or the mounting system, it's hard to know for sure, but it made me not want to experiment with sandwich for my first design. On the other hand, my favorite keyboard of mine I've typed on is my TMO50 which is top mounted, with 8 mounting points. Other than that I have only done a bit of typing at meetups and on friends' boards for isolation, gasket, or integrated plate mount. For these reasons, combined with the fact that top mount is the easiest to implement, I chose top mount.
Here’s a shot of the internals that shows how Aergo is mounted. It used a pretty normal 8 point mounting system, one in each corner of the two plates.
PCBs:
As there are two distinct angles, there can’t be one PCB (unless it were a flexible one, but i looked into that and it’s not really practical or feasible at this size). Therefore I chose to go with two pcbs. I learnt afterwards I could have connected the internals using some smart protocol like master/slave on with multiple MCUs or with some other kind of protocol. However, this meant that I would have to solder multiple controllers, and I didn’t want to do that, so I chose instead to just use a 15 pin JST connector to directly connect the halfs. Take this, months of staring at kicad, rereading AI’s guide a million times, asking tons of questions throughout discord I ended up with the following PCB design. For the daughterboard I used AI03’s universal daughterboard design.
Final Assembly:
I feel like I’ve written way more text than anyone would care to read, so I'll leave with some photos of the assembly process I took along the way. And the final result.
https://imgur.com/a/QWveqdI
Typing Test: https://www.youtube.com/watch?v=15XBXmr-gkQ
Thanks for reading and a huge thanks to everyone who helped make this keyboard a reality. I absolutely love it not only for the object, but for all of the amazing people I’ve spoken to along the way.
Special Mentions:
Xondat, thanks for all of your help with design. Your feedback on my initial drawings was extensive and hugely helped. Thank you for taking the time to review it. Also thanks for supplying me the daughterboards (even if they took months to arrive, in typical Xondat fashion).
AI03, For all of your help with pcb and case design, as well as creating your discord channel which was a really great resource for getting feedback on pcb and case design.
Bisoromi, President of the dent gang, for all your design tips and assistance.
Duckboi, you acted as a constant springboard for ideas and thoughts and for that I am super thankful.
The entire kb-kustoms community for all their hilarity and friendship along the way. While I know many think that kb-kustoms is a group of bitter mocking *******s, I’ve learnt a great deal and enjoyed sharing a lot of this keyboard with you all.
Funderburker, for your design of TMO50 and friendship. I used a lot of the internals of TMO50 to help me understand how keyboards are made on the inside.
Reallaugh, for all of your help designing/building the pcb!!
And really a ton more I can’t think of right now.
« Last Edit: Fri, 13 December 2019, 17:26:10 by Acereconkeys »
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline SirShakes
Re: Aergo - Design and Build Log
« Reply #1 on: Thu, 05 December 2019, 00:57:44 »
Watching this all unfold in discord was an amazing sight.  Glad it's finally here!
Offline Jaxxstatic
  • Haptic Recon
« Reply #2 on: Thu, 05 December 2019, 01:28:53 »
Aergo is....pretty.
Offline dingusxmcgee
« Reply #3 on: Thu, 05 December 2019, 05:23:57 »
Very cool! Thanks for sharing!
Offline funderburker
« Reply #4 on: Thu, 05 December 2019, 05:56:50 »
Finally, it's official! Massive congratulations on this project.
It's wonderful to see Aergo becoming a reality and reading (I read it all!) your story about how it came to be!
I'd like to try it out someday and feel the ergonomics in action so to say. Have you thought about making some custom wrist rest for it?
Keyboard design by Skepur
Offline mrpetrov
« Reply #5 on: Thu, 05 December 2019, 07:34:10 »
What an awesome build and design log! Congratulations Ace and thanks so much for sharing all your insights through this blog. It’s awesome and I hope this board goes to GB!
« Reply #6 on: Thu, 05 December 2019, 12:12:00 »
Thank you for the comment I am glad you enjoyed it. If anyone is at the socal meetup this weekend it'll be available to try. A custom wrist rest is definitely happening. I have one modeled, and originally reached out to some of the community members who are involved in wood working but got the feedback that the design is only really practical for a CNC to cut. So, given that knowledge, I'll have to get something machined I guess. Not sure.
Thank you! I am glad you enjoyed it.
Thanks for your comment and for reading the post. I am glad you enjoyed it.
Aergo is....pretty.
Means a lot coming from you thank you man :)
Woot woot!! I've been sharing progress for so long also kind of crazy it's finally done.
Thank you thank you! I don't know about a group buy yet we'll see.
Offline MrDongblaster
  • Dr. Pepper Zero Sugar Enthusiast
« Reply #7 on: Thu, 05 December 2019, 12:17:18 »
U did it!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #8 on: Thu, 05 December 2019, 12:27:44 »
Been following this since I first entered the hobby because of how often you post about it on discord LMAO. It was really nice to see the progress and you post about how passionate you are about your creation for the past few months. It helped me want to eventually create something of my own for this hobby. Thanks Ace, excited to see you at socal and to try out the Aergo!  :-*
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #9 on: Thu, 05 December 2019, 12:35:48 »
Awesome work Ace!!! :D
(credits to Kokaloo)
Offline pngu
  • send noots
« Reply #10 on: Thu, 05 December 2019, 12:46:32 »
Can I be your roomie, I don't throw parties and shower regularly
edit: I also like keyboards
« Last Edit: Thu, 05 December 2019, 12:48:36 by pngu »
Offline sleepy
« Reply #11 on: Thu, 05 December 2019, 12:58:18 »
A really nice writeup. I've enjoyed seeing snippets of your keyboard around and its great to see it officially posted so others can see. Keep up the great work :)
Offline mta
« Reply #12 on: Thu, 05 December 2019, 19:34:29 »
Really appreciate the detailed writeup, and the board itself looks/sounds great -- really inspiring stuff. Makes me want to consider designing/making one of my own someday... oof.
Offline NRbigfoot
« Reply #13 on: Fri, 06 December 2019, 07:05:30 »
Congrats on finishing your acergo! Caught bits and pieces of your design process on discord and was a cool read.
HBCP | FLX Virgo | aanzee | Mira SE | Leaf 80 | HHKB pro 1 | qxp | Rukia | IDB60 | equinox | No1Rev1 | Whale | Montage | 268.2 | Anniversary Whale | Jer80 | Evolv
« Reply #14 on: Wed, 11 December 2019, 15:33:53 »
U did it!
I did it!! Took me long enough :D
Ye anytime bby. Come to California we have all the good **** like weed and me.
I'm so glad you enjoyed it thanks for reading it all! And ah man that's so great to hear I hope you do! And make another post about it here i'd love to read it :) My personal favorite part of this hobby is seeing all the creativity and individuality people are able to express through their keyboard! Good luck on your journey and don't hesitate to reach out if you have any questions or want to spitball ideas. I'm certainly no pro, but I love talking about this stuff :)
Yeah I've been spamming it a bit thanks for reading the post/enjoying it! See above comment all about creating stuff, it's dope, do it. Ignore the feeling of being overwhelmed just try ****. Worst that happens is it it sucks and you learn.
Thank you for reading it Alice!!!
Thanks Biso! Good luck with all your keyboard design endeavors too i'm sure they'll be great.
Ah thank you for taking the time to read and comment means a lot!
Offline RealLaugh
« Reply #15 on: Fri, 13 December 2019, 17:35:53 »
You did something amazing and I hope lots of people like it so you can share the memes
Offline xondat
  • i'm not a star
« Reply #16 on: Mon, 06 January 2020, 20:19:33 »
I can't believe I missed this post :'(
Offline NotBing
« Reply #17 on: Mon, 06 January 2020, 23:39:23 »
One of the most unique keyboards I've seen to date. Great job, looks and sounds great!
Collection: Yohane, RS, RS60, MC65
Soon: GSKT-00
« Reply #18 on: Mon, 06 January 2020, 23:52:47 »
Yeah man you're the first name on the post :) Glad you found it.
Thank you for your kind words!
Offline keygod
« Reply #19 on: Thu, 12 March 2020, 07:02:24 »
incredibly fantastic work, just no words. well done!
Offline hangul
« Reply #20 on: Sat, 27 June 2020, 15:18:32 »
I found a local man that would cnc mill my case, but it seems like that I would have to make a pcb myself. I will try to follow the road of pain you walked on :)
Nice work!
Offline controller-works
    • Controller.works
« Reply #21 on: Fri, 15 July 2022, 21:05:43 »
Did you have any signal quality issues routing the USB from the daughter board at the top to the microcontroller at the bottom?
