Author Topic: Need some help troubleshooting my first build  (Read 3148 times)
Offline SCWes
« on: Thu, 26 December 2019, 06:29:45 »
I posted this question on the reddit forum yesterday, but for some reason got downvoted a number of times, but I'm stuck.
https://imgur.com/a/tHcGSIp
Used the following layout from keyboard-layour-editor.com:
[{a:7},"","","","","","","","","",""],
threw it into thrKBfirmware with the following settings
Board: Teensy ++ 2.0
10 Columns (C0, E1, E0, D7, D6, D5, D4, D3, D2, D0) <-- Yes I skipped D1 because I got one of the wires too short,  8 Rows (F0-F7)
Controller: AT90USB1286
Bootloader Size: 2048
Column to Row
After populating some of the keyboard, downloading the hex file, and uploading it to the teensy it will spit out something like this when I plug the keyboard in: mk5edc then a quick pause, ccccccccccccccccccccccccccccccccccccccccc... All of these keys are on the same column (D6 Pin). There are no shorts that I can see, the only thing that is possibly connecting these to cause a short is perhaps a trail of hot glue, but I doubt that would actually cause it.
Offline nevin
Re: Need some help troubleshooting my first build
« Reply #1 on: Thu, 26 December 2019, 11:03:26 »
1. make sure you don't have a stuck switch (it is outputting a character)
2. if still having issues, change some of the pins being used,  D6 can be problematic as it can function as multiple things (including LEDs) attached to that pin.
Offline SCWes
« Reply #2 on: Thu, 26 December 2019, 12:08:02 »
Call yourself Santa, because you just gave me the best Christmas present! I switched it off of D6 and now it works. I had a feeling that there could have been some sort of pin restriction that I wasn't aware of. I was actually thinking that the entire F area may have been off-limits or something. Thanks so much dude!
Offline nevin
« Reply #3 on: Thu, 26 December 2019, 12:18:16 »
no problem. glad you got it working.
happy holidays bud.
