Author Topic: [IC] Canvas: 65% Left Hand NumPad Keyboard (UPDATE:Order forms Up)  (Read 53584 times)
Offline Umio1
Re: [IC] Canvas: 65% Left Hand NumPad Keyboard (UPDATE: Design finalized)
« Reply #100 on: Wed, 19 February 2020, 22:35:58 »
I'm pretty new to the keyboard world and so is still unfamiliar with lots of things. For keyboard GBs like this, does it come as a kit and we need to build it ourselves? I really like this but worried I'll destroy it if I have to build it myself
The only thing that needs assembly with this are the sockets on the PCB ; even though they're "surface mount" they're a relatively easy component to solder and comparable to through hole components. That being said you should definitely practice some soldering, watch some YouTube videos on how to solder, do some through hole soldering, and you should be good enough to build a keyboard.
Offline jchw
« Reply #101 on: Wed, 19 February 2020, 23:00:11 »
Usually these offer the ability to buy an extra PCB and/or plate, which I ALWAYS recommend.
On top of that, there are other kits you can get which will be much cheaper which allow you to practice soldering. I'd highly recommend a through-hole board to get the most experience.
https://keycapsss.com/diy-kits/104/plaid-pad-4x4-numpad?c=17
A numpad is always a good start.
I never thought of using numpad kit to practice. It's a great idea, I'll definitely look into getting some. Thanks for the suggestion!
Offline Mtalbert
« Reply #102 on: Wed, 19 February 2020, 23:45:41 »
What does the Chinese on the back of those keyboards mean?
Big fan of Daeru
Offline Umio1
« Reply #103 on: Thu, 20 February 2020, 00:51:27 »
Center reads"International Thick Boi" with "Boi" being phonetic, bottom left is my name. It's just something extra I did for myself cause I have some access to a laser engraver.
Offline Mtalbert
« Reply #104 on: Thu, 20 February 2020, 01:01:33 »
I see...TBH, im a Chinese, I was just confused what does that mean, because it looks weird in Chinese.
Big fan of Daeru
Offline bananasplit_00
« Reply #105 on: Thu, 20 February 2020, 01:26:01 »
Hawt but id really want some other layout options, solder PCB for next run perhaps? So we can have options for ISO, flipped numpads, split backspace, split space and all that fun stuff people love :) Best of luck on the GB  :thumb:
Offline SekaiJutsu
    • GeekHack
« Reply #106 on: Sat, 22 February 2020, 17:50:44 »
Will the pcb and plate support pcb-mounted/screw-in stabs?
Offline lakeboredom
« Reply #107 on: Sat, 22 February 2020, 18:49:33 »
Plate mounted stabs right? Or is there something supporting the pcb so we can use screw ins?
Offline Umio1
« Reply #108 on: Sun, 23 February 2020, 01:46:09 »
The stableizers are plate mounted, they're not attached to the pcb/use screws.
Offline zakatak
  • no cash
« Reply #109 on: Mon, 24 February 2020, 10:11:46 »
Oh, that's quite dissapointing. Do you think you could still make the change to pcb-mount stabs?
Offline SekaiJutsu
    • GeekHack
« Reply #110 on: Mon, 24 February 2020, 13:09:25 »
seconded the idea! Is it still possible to integrate the stab holes on the pcb and make the plate slightly more open? C3 stabs look very promising!
Offline Zeelobby
« Reply #111 on: Mon, 24 February 2020, 13:27:17 »
I'm a big fan of PCB mount as well. Plate mount is just so stab limiting.
Offline Umio1
« Reply #112 on: Tue, 25 February 2020, 09:16:39 »
I'm trying to refrain from making any big changes to the design as moving to PCB mounted will change both the Plate and PCB designs.
Stabilizers will be plate mounted.
Offline pegasus21
« Reply #113 on: Tue, 25 February 2020, 09:19:09 »
Maybe consider running a poll to see which type of stab most people want?
Personally, I would prefer PCB mount stabs
Offline carbs
« Reply #114 on: Tue, 25 February 2020, 17:37:38 »
I'm literally brand new to the keyboard hobby but damn this is exactly what I have wanted since I first started to watch and learn about mech keyboards  ;D
RIP Lola 12/15/19
Offline Umio1
(3/1/20) Going to start the group buy next weekend 3/7/20; all the final details will be on that post. I'll also try to have all the files put up on Github next weekend.
50 Hi-Pro for the first round and going to get quotes to see how many I will do for the Low-pro
« Last Edit: Mon, 02 March 2020, 08:36:16 by Umio1 »
Offline SekaiJutsu
    • GeekHack
LETS GOOO! Hyped!
Sent from my SAMSUNG-SM-N920A using Tapatalk
Offline fooddoof
Will you post the time for it in the days before? Really don’t wanna miss out on this because I wasn’t awake ;-;
Offline Agpatel
Hope to get in on thie GB once its live this week!
Offline StanleyLelnats
Also, will this be a google form or will it run through some storefront?
Offline Umio1
Yes, ill make sure to do that.
Offline Umio1
Will be done using a google form.
Offline Danimals97
Stoked for this GB! Hope you end up offering that sapphire blue, it speaks to me.
Offline AznCuber5
For the High Profile keyboard, is there only one color option?
Offline Umio1
Offline kioskhill45
No grey for Hipro?
Offline Umio1
No grey for Hipro?
I will be keeping it to 5 standard color options to keep price down. Leaving the case uncolored is an option (just have it smoothed/bead blasted [or apply your own finish afterwards]).
If you are really set on a specific color I can see if they will quote it; there would be a price increase due to them having to mix a new color for 1 part.
Offline Umio1
Offline kioskhill45
Are the 5 colors glossy or matte? Also, can I get a different top and bottom color, like in the renders? Thanks
Offline fooddoof
Re: [IC] Canvas: 65% Left Hand NumPad Keyboard (UPDATE: Files now on GitHub)
« Reply #129 on: Tue, 03 March 2020, 07:25:46 »
BTW, what’s the prod time look like? Standard 2-3 months minimum?
Offline Umio1
I was thinking a satin/semi-gloss for the powder coats, and yes both top and bottom can be different colors.
Offline Umio1
« Reply #131 on: Tue, 03 March 2020, 09:04:20 »
Here are the estimates I was given from the quotes for the parts shipped to me:
PCB: 80-96 days
Case: 35 days
I wish these were a lot less but the Corona Virus ramping up right after the Chinese new year break really slowed a lot of manufacturing down.
« Reply #132 on: Tue, 03 March 2020, 09:28:51 »
So is the only option for the PCB to solder the hotswap sockets on or will you be able to use it as a regular solderable pcb?
Offline fooddoof
« Reply #133 on: Tue, 03 March 2020, 10:42:40 »
PCB: 80-96 days
Case: 35 days
Thanks for the info! I have no problem with these timelines at all. People gotta make sure they’re healthy, that’s the important part. Thanks and looking forward to the GB!
Offline Umio1
« Reply #134 on: Tue, 03 March 2020, 17:46:12 »
yes, hotswap only unless you wanted to solder the switches into the hotswap sockets.
Offline kioskhill45
« Reply #135 on: Tue, 03 March 2020, 18:30:35 »
One more thing, can we get multiple tops or bottoms for the case? I was thinking of getting one black bottom and then one black and one white top. Thanks again
Offline Umio1
« Reply #136 on: Wed, 04 March 2020, 00:38:18 »
Yes, I will put in an option to order more than 1 of each part.
Offline kioskhill45
« Reply #137 on: Wed, 04 March 2020, 00:45:08 »
Great, thanks!
Offline Navalyn
« Reply #138 on: Thu, 05 March 2020, 16:03:57 »
What would be the est. time until the second GB for the low profile case? Looking at your pics, that seems like the way to go for me
« Last Edit: Thu, 05 March 2020, 16:24:28 by Navalyn »
Offline Snakeboat
« Reply #139 on: Fri, 06 March 2020, 03:55:54 »
Are there any recent images of the low profile?
Offline Umio1
« Reply #140 on: Fri, 06 March 2020, 08:40:09 »
Second group buy all depends on how well this one works out, but a good estimate might be around August.
All the pictures for the low-profile are on the initial post.
« Reply #141 on: Fri, 06 March 2020, 09:34:46 »
Will future rounds potentially include a solderable pcb?
Offline productkun
« Reply #142 on: Fri, 06 March 2020, 10:00:13 »
Oh want one!
Offline fooddoof
« Reply #143 on: Fri, 06 March 2020, 16:25:57 »
Any info for launch time tomorrow?
Offline Umio1
« Reply #144 on: Fri, 06 March 2020, 20:30:29 »
I'll put the group buy up tomorrow but won't put the google form up till Sunday just to give people a day's notice; more info on exact time when i post.
Offline Umio1
« Reply #145 on: Fri, 06 March 2020, 20:32:01 »
I'll do a second poll after the first buy to see if it's a popular choice.
Offline fooddoof
« Reply #146 on: Fri, 06 March 2020, 20:45:35 »
Nice, thanks! Really hoping it won’t be Sunday morning now tho :-[
Offline Umio1
« Reply #147 on: Sat, 07 March 2020, 21:49:22 »
looks like im going to release the order forms Monday evening; I submitted the Group Buy page for approval so that should be up Sunday hopefully.
Offline fooddoof
« Reply #148 on: Sat, 07 March 2020, 22:02:53 »
Thanks for the update! Lookin forward to it  :D
Offline SekaiJutsu
    • GeekHack
« Reply #149 on: Sat, 07 March 2020, 22:15:19 »
Can't wait!!!
Did you get a quote for the boards? There are a few artisans doing buys rn, would be dope to get an estimate!
