Author Topic: Failed build - please help  (Read 1888 times)
Offline guyga
« on: Sun, 29 December 2019, 21:51:53 »
I built a keyboard and it worked fine until I put it back in the case, after which it stopped working. I suspect the cable got squeezed. The cable is connected to the PCB at a point that’s hard to reach without desoldering the whole thing. Is there a way to debug this and possibly replace the cable without reaching the connector to the board? Perhaps by cutting the cable and soldering a new cable to each of the USB 5 wires?
Offline powwu
    • Discord
Re: Failed build - please help
« Reply #1 on: Sun, 29 December 2019, 21:59:55 »
What PCB did you build with? I assume the cable isn't removable from your description?
Offline guyga
« Reply #2 on: Mon, 30 December 2019, 02:47:13 »
I used this DM87 kit which includes a PCB and cable:
https://www.amazon.com/dp/B07WHG4CDJ?ref=ppx_pop_mob_ap_share
The cable is removable in principle, but its connected to the PCB between the plate and the PCB, so in practice I can not remove it without desoldering the switches and separating the plate from the PCB.
Offline Leslieann
« Reply #3 on: Mon, 30 December 2019, 03:29:41 »
If you can reach the smashed part you may be able to just remove the coating and re-wrap each wire without even cutting them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline guyga
« Reply #4 on: Mon, 30 December 2019, 03:54:03 »
Interesting idea. Thanks!
