Author Topic: Does the body's ketones cause keycap shine?  (Read 4275 times)
Offline Joebeazelman
« on: Wed, 01 January 2020, 18:46:17 »
I've seen horrific photos of keycap shine: https://geekhack.org/index.php?topic=74285.0 and I wonder what could be the cause. Some of them look like they were doused with nail polish. Body oils from the fingers' are often pointed to as the culprit, but is there any scientific basis for this? Could there be a more likely the cause?
From my limited layperson's understanding, there's always small amounts of ketones present in the human blood, but much larger quantities are present when fatty acids in the liver are broken down in a process called ketosis. It often occurs as a result of dieting, exercising, but it can be a side effect of a serious medical illness.
Acetone is the simplest and smallest of ketones and a very aggressive ABS solvent.  Could the shine on keycaps be a result of ketones released through the pores of the skin?  Furthermore, is it possible your keyboard has a health function the iWatch doesn't have, the ability to warn the user of progressive metabolic acidosis?  Just a weird thought.
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Does the body's ketones cause keycap shine?
« Reply #1 on: Wed, 01 January 2020, 18:57:32 »
Lol no.
It's just finger oil and heavy usage that wears down the sandblasted-like texture of ABS keycaps.
You can achieve the same effect with a polishing tool. When you wear the texture down, the shine is much more apparent.
Offline wholypantalones
  • text and icon mods plz.
« Reply #2 on: Wed, 01 January 2020, 19:04:11 »
Can confirm, I sandblast used caps and it's just the texture being worn down. They look new once they are blasted and the texture is put back. Not very scientific, sorry.
https://imgur.com/a/Jf8qyFx
