Author Topic: How to know which one is which? Zeal 62 & 65?  (Read 1752 times)
Offline Pavilions
« on: Thu, 16 January 2020, 17:50:32 »
I'm having an issue right now, I bought two weights of zealous switches 62 and 65, and installed them on two boards. The only issue that I'm facing I don't know which one is which? i mixed them up and and don't know how to find each one. I have tried to distinguish them by weight however, I couldn't it's hard. Can I know the difference by color? because I think one of them has lighter switches than the other but I'm not sure about that.
Thanks,
Offline monstargear
    • Monstargear
Re: How to know which one is which? Zeal 62 & 65?
« Reply #1 on: Thu, 16 January 2020, 19:54:30 »
you can find out with stem color. 65 is little bit more purple.
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Thu, 16 January 2020, 20:44:51 »
The numbers are based off the weighting. 62 stands for 62g, and 65 stands for 65g. 62 are a little lighter, and are a little more tactile, but as monstargear said, the 65g one should be a bit more purple.
Everyone must pay the cat tax
Offline Pavilions
« Reply #3 on: Fri, 17 January 2020, 02:36:19 »
Thanks, I will have to check it and see
