Author Topic: Northgate Omnikey 102 with Converter  (Read 6989 times)
Offline zbaylin
« on: Wed, 22 January 2020, 17:55:37 »
Hey everyone,
I just got a Northgate Omnikey 102 in the mail. I bought it on eBay for around ~$45. The problem is I can't seem to get it to work with either a Soarer's PS/2 adapter or a TMK PS/2 adapter, both flashed onto a Pro Micro.
Every time I plug in the board, the lock lights flash for a second then go off (which I think is to be expected, since it happens on my Model M as well). However, once plugged in, the board only recognizes the lock keys (i.e. I hit Caps Lock and the respective light on the keyboard lights up).
I saw someone else with this same problem here: https://geekhack.org/index.php?topic=82820.msg2241405#msg2241405. I, too, have fiddled with all the DIP switches listed in the manual for different host configurations to no avail.
At this point I'm wondering if the board is dead (unlikely I guess because at least some response is being generated), or if my converters are incompatible with the board (also seems unlikely considering I've put the board into AT, XT, and other modes).
I was wondering if anyone had gotten their Omnikeys (regardless of specific model) to work with a Soarer's/TMK converter. If there is another ProMicro/Teensy based converter I could try, I would definitely try that, but I haven't found any. Or maybe I just need to buy a different/new converter on Amazon.
Thanks in advance for your help!
Offline pixelpusher
Re: Northgate Omnikey 102 with Converter
« Reply #1 on: Wed, 22 January 2020, 18:03:17 »
I had an omnikey for mac that did this until I had the dip switches in the right position.  You’ll need to look up the positions online.
Offline daguil68367
    • /u/daguil68367
« Reply #2 on: Wed, 22 January 2020, 18:08:33 »
The capacitors have probably gone bad. You can replace them with new ones by soldering/desoldering.
Offline zbaylin
« Reply #3 on: Wed, 22 January 2020, 19:43:10 »
I have since taken the board apart and it looks like all the capacitors are in working order  :confused:. I'm not super experienced with that kind of stuff, so I've taken a picture here to show what it looks like:
Sorry for the bad lighting!
Let me know if anything looks amiss.
Offline pixelpusher
« Reply #4 on: Wed, 22 January 2020, 20:43:21 »
Would need a multimeter to test I suppose
Pages 4-6 explain the dip switches.
http://bitsavers.trailing-edge.com/pdf/northgate/Northgate_OmniKey_Users_Guide_Apr92.pdf
Offline zbaylin
« Reply #5 on: Tue, 28 January 2020, 21:45:09 »
Thank you for that link. Unfortunately, even after iterating through each DIP switch configuration, I still can't get the keyboard to work :/. I wonder if anyone else has had this problem, or has had any luck repairing Omnikeys like this one.
Offline pixelpusher
« Reply #6 on: Wed, 29 January 2020, 07:51:29 »
This is the option that worked for me. Worth one last try maybe?
234608-0
Offline GuyfromWroclaw
« Reply #7 on: Fri, 01 September 2023, 11:52:55 »
Wanted to say thank you, and confirm that switches 1 and 3 in the on (down) position also works for the OmniKey/PLUS (GT6OMNIPLUS1), in conjunction with the drakware ADB->USB converter.  There were some posting online recommending 1, 3, and 8 being in the on position for an omnikey ultra, butit  didn't work for me.  See https://deskthority.net/viewtopic.php?t=25139.  Was about to rip out my hair and give up but for this post.
Offline pixelpusher
« Reply #8 on: Fri, 01 September 2023, 19:24:57 »
