Author Topic: gateron ink black or novelkey creams  (Read 10982 times)
Offline killermax
« on: Mon, 27 January 2020, 00:41:14 »
I am in the market for linears. do you think is it worth it buy one of the two (gateron ink black vs novelkey creams) and lube+film them. Or just buy stock tealios.
Which of the two is better for lubing and filming? From doing web search, i think creams sound better than inks but its not as smooth and does not play well with lube.
Please enlighten me!
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: gateron ink black or novelkey creams
« Reply #1 on: Mon, 27 January 2020, 05:47:02 »
All are good. But if you want smoothness right off the bat, go for inks or Tealios. Creams are still quite good if you break them in a little.
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Mon, 27 January 2020, 08:33:19 »
Creams have been fixed to take lube well. Gateron ink black will be a better choice since it has a better sound. You should use Alpacas if you are looking for a cheaper option, they are just as good as ink black but do not have that characteristic sound. They are all very smooth.
I would not do Tealios because of their sound.
Everyone must pay the cat tax
