Author Topic: [GB] KAM Wraith  (Read 113169 times)
Offline biip
    • @biipmk
[GB] KAM Wraith
« on: Mon, 27 January 2020, 02:53:12 »
About
1.65mm thick PBT keycaps manufactured by Keyreative
Overall Dye sublimation
Live until February 28th
Shipping time is estimated for Sept. 2020
IC thread
Vendors
Novelkeys US:
Candykeys EU:
Zfrontier Asia:
Zfrontier International:
Dailyclack Oceania:
Pricing
KitNovelkeysCandykeysZfrontierZfrontier CNDailyclack
base$95.0093.00€$95.00¥578.00$152.00
calc$16.0020.00€$17.00¥100.00$26.00
ergo$65.0058.00€$65.00¥395.00$104.00
extension$30.0034.00€$30.00¥185.00$48.00
intl$35.0038.00€$35.00¥216.00$56.00
nav$15.0019.00€$12.00¥72.00$24.00
space$22.0023.00€$23.00¥135.00$35.00
Kits
Samples
Renders
by Oblotzky
Grid 600
Rama M65-A
HBCP
Campine
Rama M60-A
Keycult No.2 Rev 1
Deskmat
Feel free to support the project by adding the banner to your signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=97181.0][img width=302 height=120]https://i.imgur.com/QHngmaR.png[/img][/url]
« Last Edit: Mon, 31 August 2020, 07:10:50 by biip »
Offline biip
    • @biipmk
Re: [GB] KAM Wraith
« Reply #1 on: Mon, 27 January 2020, 02:53:27 »
Numbers
Updated on March 4th
base-kit705
calc-kit181
ergo-kit184
extension-kit161
intl-kit70
nav-kit92
space-kit312
« Last Edit: Wed, 04 March 2020, 02:20:48 by biip »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] KAM Wraith
« Reply #2 on: Mon, 27 January 2020, 07:17:27 »
Approved, GL w GB!
Offline Capsy
Re: [GB] KAM Wraith
« Reply #3 on: Mon, 27 January 2020, 07:35:59 »
Yes !! Thanks for this, biip.
Offline zekth
Re: [GB] KAM Wraith
« Reply #4 on: Mon, 27 January 2020, 08:07:44 »
RIP wallet
Offline vilagefool
Re: [GB] KAM Wraith
« Reply #5 on: Mon, 27 January 2020, 08:38:16 »
RIP wallet
RIIP?  :p
also, woohoo!
Offline KingOfMemes
Re: [GB] KAM Wraith
« Reply #6 on: Mon, 27 January 2020, 08:59:32 »
I don't think there is a set of yours that I haven't bought on day 0. Can't wait for this one
Offline biip
    • @biipmk
Re: [GB] KAM Wraith
« Reply #7 on: Mon, 27 January 2020, 09:39:47 »
What devotion! Thanks, my fellow!
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [GB] KAM Wraith
« Reply #8 on: Mon, 27 January 2020, 09:44:20 »
Awesome to see this come to life, fingers crossed I can get in before the GB ends!
Offline KHAANNN
Re: [GB] KAM Wraith
« Reply #9 on: Mon, 27 January 2020, 10:18:07 »
Too late but a 1.75 Up on the Extension kit would've made sense for the 60% arrowed usages
Regardless, it's a great set, and since it's too chaotic (in a good way), accuracy doesn't matter anyway
Offline KHAANNN
Re: [GB] KAM Wraith
« Reply #10 on: Mon, 27 January 2020, 10:19:35 »
It's also a bit of a gut punch that one must purchase both the extension and the spacebar kit for the signature look
Offline farmisen
Re: [GB] KAM Wraith
« Reply #11 on: Mon, 27 January 2020, 10:56:32 »
This set is brilliant. In for one of each kit + a few extra base ones.
Offline Loligagger
Re: [GB] KAM Wraith
« Reply #12 on: Mon, 27 January 2020, 20:18:56 »
Put in my order, thanks. Now for the inevitable months long wait.
Offline eyedrop
Re: [GB] KAM Wraith
« Reply #13 on: Mon, 27 January 2020, 23:45:14 »
There isn't a way to get an extra B for alice type layout, right?
Offline biip
    • @biipmk
Re: [GB] KAM Wraith
« Reply #14 on: Tue, 28 January 2020, 02:24:35 »
buy 2 base or ergo kits 🙃
Offline biip
    • @biipmk
Re: [GB] KAM Wraith (GB Jan. 27th — Feb. 28th)
« Reply #15 on: Tue, 28 January 2020, 03:39:29 »
Really nice start!
base-kit153
calc-kit46
ergo-kit51
extension-kit44
intl-kit19
nav-kit25
space-kit52
Offline Galdom
« Reply #16 on: Tue, 28 January 2020, 04:13:48 »
Hello, i’m new to this, so my question is this. Will this fit a Varmilo keyboard?
Offline biip
    • @biipmk
« Reply #17 on: Tue, 28 January 2020, 04:26:51 »
hey, yes the base kit covers that layout :thumb:
Offline Galdom
« Reply #18 on: Tue, 28 January 2020, 04:36:14 »
Ty
You just got orderd! ;)
Offline rockydbull
« Reply #19 on: Tue, 28 January 2020, 07:56:38 »
I see there is a lot of compatibility in the base kit (looks like even 40s), what keyboards/layouts would the extension be used to fill? Trying to figure out whether I should drop cash on that or skip and maybe squeeze for the ergo kit.
Offline TheAutoManCan
« Reply #20 on: Tue, 28 January 2020, 09:45:13 »
Isn’t the Symbol Shift key you have labeled as 2.00u in the Base kit meant to be 1.75u?
Offline biip
    • @biipmk
« Reply #21 on: Tue, 28 January 2020, 09:59:49 »
fixed!
thanks :thumb:
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #22 on: Tue, 28 January 2020, 15:58:17 »
Really nice start!
base-kit153
calc-kit46
ergo-kit51
extension-kit44
intl-kit19
nav-kit25
space-kit52
« Last Edit: Wed, 19 February 2020, 13:09:13 by dvorcol »
Offline IOVERCALLHISTIOCYTES
« Reply #23 on: Tue, 28 January 2020, 17:25:42 »
I wasn't even that hyped for this dvorcol chart and it was my mistake because this things lit
small brain: design kits to use as keys
mid brain: design kits to use as memes
big brain: design kits to see dvorcol's graphs
Offline dvorcol
« Reply #24 on: Tue, 28 January 2020, 19:49:42 »
Thank you! :)  I really enjoy making these, I'm glad you like them.  Or, at least, this one.
Offline Shurakai
« Reply #25 on: Tue, 28 January 2020, 20:31:42 »
They are always awesome, but you outdid yourself with this one.
Offline KingOfMemes
« Reply #26 on: Tue, 28 January 2020, 20:35:39 »
Was there ever a MOQ discussed?
Offline Ensaum
« Reply #27 on: Tue, 28 January 2020, 21:33:21 »
Maybe I'm dumb, but what is the extension kit for? Is it a novelty kit or a layout compat kit? I'm having a hard time trying to figure out what it is with the custom legends.
Offline dvorcol
« Reply #28 on: Tue, 28 January 2020, 21:46:56 »
My understanding is KAT/KAM has one single MOQ for the entire GB.  It is the total keycap units* sold, there are no individual kit MOQs.  I'm guessing Wraith has a 54,000u MOQ, but there are at least three possible levels so it could be different.
*for example, a 1U keycap is 1, an ISO enter is 2.75 (1.5+1.25), etc.
Offline Photoelectric
« Reply #29 on: Tue, 28 January 2020, 23:02:39 »
Quick color check: is the base plastic going to be blue-tinted gray?  How noticeable is the blue element with lower indoor lighting?  The renders show a bluish gray, but photographs of the sample caps are more toward neutral dark gray (I know it's difficult to get tints correctly in photos).  The main legends are a pale pink?
Also, is the matte but smooth texture of these caps going to be basically the same as for KAT caps?
Offline biip
    • @biipmk
« Reply #30 on: Wed, 29 January 2020, 02:48:39 »
Just an addon pack, basically.
The colors of the photo are the most accurate.
Yes the surface will be smooth af :thumb:
Correct!
Numbers without extras
Updated on Jan. 29th
base-kit181
calc-kit58
ergo-kit54
extension-kit56
intl-kit20
nav-kit30
space-kit68
« Reply #31 on: Wed, 29 January 2020, 09:12:56 »
That helps, thanks.  So but to confirm, is there a slight pink-cream tint to the main legends?  Or is that a play of light to give that impression?  (I like it for the unusual color combinations, so I'm hoping the answer is yes).
Offline biip
    • @biipmk
« Reply #32 on: Wed, 29 January 2020, 09:28:03 »
If you're talking about the white, it's supposed to be a pure white :D
« Reply #33 on: Wed, 29 January 2020, 09:30:49 »
That's why I asked, since there are no color values listed that I could find, and the legends look off-white on those photographs.  Appreciate the quick replies :thumb: :-*
Offline biip
    • @biipmk
« Reply #34 on: Wed, 29 January 2020, 09:35:13 »
yeah, I tend to get rid of colors in the ICs when I already have the samples.
But since you're talking about that:
- Grey 5415 C / 5405 C
- Red Warm Red C / 1788 C
- Green 374 C
- Blue 2171 C / 2191 C
- Cyan 2905 C
- Magenta 529 C
- Yellow 101 C
We're working on contrast with the manufacturer atm to find the perfect balance :thumb:
Offline dvorcol
« Reply #35 on: Wed, 29 January 2020, 19:30:35 »
base-kit181
calc-kit58
ergo-kit54
extension-kit56
intl-kit20
nav-kit30
space-kit68
Only the second day and already 80% of the way toward MOQ!
<-- history to date
« Last Edit: Wed, 19 February 2020, 13:10:15 by dvorcol »
Offline biip
    • @biipmk
« Reply #36 on: Thu, 30 January 2020, 02:16:32 »
base-kit181
calc-kit58
ergo-kit54
extension-kit56
intl-kit20
nav-kit30
space-kit68
These numbers don't include orders from Zfrontier website because of CNY btw.
Offline dvorcol
« Reply #37 on: Thu, 30 January 2020, 11:44:01 »
<-- history to date
« Last Edit: Wed, 19 February 2020, 13:10:33 by dvorcol »
Offline biip
    • @biipmk
« Reply #38 on: Fri, 31 January 2020, 02:38:07 »
Numbers without Zfrontier numbers and without extras
Updated on Jan. 31st
base-kit205
calc-kit64
ergo-kit64
extension-kit67
intl-kit32
nav-kit37
space-kit80
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #39 on: Fri, 31 January 2020, 03:15:00 »
I'm in for Base + Nav  ;D
Offline dvorcol
« Reply #40 on: Fri, 31 January 2020, 15:21:47 »
<-- history to date
« Last Edit: Wed, 19 February 2020, 13:10:55 by dvorcol »
Offline Kawamashi
« Reply #41 on: Sat, 01 February 2020, 09:20:58 »
Just joined for 2 ergo kits + extension + intl + nav + space. Thanks again Biip for such an amazing keyset !
Offline bliss
« Reply #42 on: Sat, 01 February 2020, 16:22:23 »
biip doing pioneer work here - again - really awesome.
What I find best is compatibility: thanks to the uniform profile, it's possible to have Colevrak the easy way (just mind the homing keys) :thumb:
Also, with this I can finally upgrade the keycaps of my first mech (with exception of the dreaded 6.5u spacebar :rolleyes:), which has a quite weird setup: 2.25u left Control, 6.5 spacebar, 1u and 2u Shift ... it is going to look great with this, very retro.
Thank you for your diligent work!
edit: goofed
« Last Edit: Sun, 02 February 2020, 07:46:17 by bliss »
Offline biip
    • @biipmk
« Reply #43 on: Mon, 03 February 2020, 02:47:56 »
edit: goofed
Thanks for your kind regard! I appreciate it a lot. I'm not there to break records, I'm definitely happier to see people's issues getting solved :thumb:
Updated on Feb. 3rd
base-kit267
calc-kit88
ergo-kit91
extension-kit88
intl-kit35
nav-kit48
space-kit125
Offline dvorcol
« Reply #44 on: Mon, 03 February 2020, 16:26:06 »
Updated on Feb. 3rd
base-kit267
calc-kit88
ergo-kit91
extension-kit88
intl-kit35
nav-kit48
space-kit125
<-- history to date
« Last Edit: Wed, 19 February 2020, 13:11:17 by dvorcol »
Offline gminso
« Reply #45 on: Wed, 05 February 2020, 07:15:05 »
one question, the samples look a bit pinky is that some kind of filter or that is how the kits will look?
Offline biip
    • @biipmk
« Reply #46 on: Wed, 05 February 2020, 07:23:12 »
That's due to lighting. Legends are white :thumb:
Offline dvorcol
« Reply #47 on: Thu, 06 February 2020, 20:54:41 »
Updated with 11 Feb numbers.
<-- history to date
« Last Edit: Wed, 19 February 2020, 13:12:22 by dvorcol »
Offline dvorcol
« Reply #48 on: Wed, 19 February 2020, 13:13:59 »
<-- history to date
« Last Edit: Wed, 26 February 2020, 12:28:15 by dvorcol »
Offline Loligagger
« Reply #49 on: Wed, 19 February 2020, 14:24:57 »
Will there be samples with the final colors & texture sometime before the expected ship date?
