Author Topic: OG Cherry caps profile  (Read 12355 times)
Online phinix
« on: Mon, 27 January 2020, 07:45:00 »
What profile does OG Cherry caps have?
I mean, is it 1,1,2,3,4,5?
Or 1,1,2,3,4,4?
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: OG Cherry caps profile
« Reply #1 on: Mon, 27 January 2020, 07:45:52 »
112345
Or 112344
And occasionally 222344
Online phinix
« Reply #2 on: Mon, 27 January 2020, 07:49:51 »
112345
Or 112344
Cool :rolleyes:
I was wondering if bottom row is 4 or 5. So it can be both then.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3 on: Mon, 27 January 2020, 07:51:27 »
Most of the full size boards will have R5
But 1800s you'll find R4 and I've also seen some full sizes with R4 as well
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #4 on: Mon, 27 January 2020, 08:17:52 »
112345
Or 112344
So Cherry did do some messing around with their profiling back in the day, although 2-2-2-3-4-4 sound pretty funky to me. R5 on the other hand I wish would make a comeback, I got the OG set of GMK Sky Dolch that came with R5 caps & I always use them over the R4 ones!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #5 on: Mon, 27 January 2020, 08:36:50 »
112345
Or 112344
1800s like the one below have the flatter top profile
But yeah, GMK now has R5 (1u, 1.25u, 1.5u, numpad enters...) for all compatibility since GMK Carbon R2 so people should make more use of it.
IMO, it's superior.
« Last Edit: Mon, 27 January 2020, 08:39:17 by LightningXI »
Offline Rob27shred
« Reply #6 on: Mon, 27 January 2020, 09:15:01 »
112345
Or 112344
IMO, it's superior.
I guess the flatter profiling does make a bit more sense on a board like that. Also good to know since I have almost pulled the trigger on similar Cherry 1800s & did not know it had a different cap profiling. I agree with R5 being the superior option for Cherry profile bottom rows, but we seem to be in the minority there. Hopefully more sets start to make use of it going forward though!
« Reply #7 on: Mon, 27 January 2020, 09:28:07 »
Of the full-size G80-3000, the winkeyless had R5, but those with Windows keys have R4 at the bottom.
Online phinix
« Reply #8 on: Mon, 27 January 2020, 10:18:39 »
Cool, thanks. I have some OG at home (I think it was from Desko keyboard), I'll check what profile it is.
Online phinix
« Reply #9 on: Mon, 27 January 2020, 16:03:54 »
Ok, guessing thats 112345?
234456-0
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10 on: Tue, 28 January 2020, 00:26:50 »
Yes
Sent from my Pixel 3a using Tapatalk
Online phinix
« Reply #11 on: Tue, 28 January 2020, 02:32:54 »
Yes
Cool, thanks for confirming.
So now I know which profile caps I need to complete it :)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #12 on: Thu, 27 August 2020, 06:43:00 »
« Last Edit: Mon, 15 April 2024, 21:02:13 by FearsomeCubedWarrior »
« Reply #13 on: Thu, 27 August 2020, 07:46:18 »
A bit of necromancy: which boards had R0 (or F-row) profile top row (like modern GMK Carbon R2)?
Very few, relatively speaking. You'll usually only find it on the absolute oldest, non-standard layout Cherry boards. For example:
G80-0312
G80-0505
250448-0
You'll find more on the Cherry database spreadsheet, look in the pre-1000 section.
There are also very few examples of winkeyless boards with R4, for example G81-3100SPBUS.
« Last Edit: Thu, 27 August 2020, 07:49:46 by Photekq »
Offline ideus
  • Björkö.
« Reply #14 on: Thu, 27 August 2020, 09:27:52 »
That g80 is a very interesting keyboard and the set is very nice. It is a shame that the bottom row appears to be engraved and is now worn off
« Reply #15 on: Thu, 27 August 2020, 10:43:48 »
Yeah, it's quite an interesting one. I should probably document it properly sometime soon. It has a real MX lock underneath the Alpha Lock key too, one of the few boards that comes with one.
« Reply #16 on: Thu, 27 August 2020, 11:00:12 »
« Last Edit: Mon, 15 April 2024, 21:02:20 by FearsomeCubedWarrior »
Offline Mikhail
« Reply #17 on: Fri, 28 August 2020, 17:47:06 »
I think high 5 row was until mid 90'.
Offline Mikhail
« Reply #18 on: Fri, 28 August 2020, 17:50:07 »
Wow, i seen same R0 in old OEM and Tai-Hao caps))
Offline Rayndalf
« Reply #19 on: Sat, 29 August 2020, 00:04:52 »
Some keymodules Cherry OEMed for other manufacturers used it as well. On this board the R0 keys are very thin.
« Reply #20 on: Sun, 06 September 2020, 17:30:24 »
Roughly how much cost does R5 row add to a base kit? For non-Drop quantities but more like normal vendors.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #21 on: Sun, 06 September 2020, 17:36:34 »
GMK doesn't do quotes on a per-key basis and instead accounts for the kit as a whole, so there's no real "formula" that's known publicly for that to be calculated accurately.
« Reply #22 on: Mon, 07 September 2020, 09:25:00 »
Makes sense, thanks.
