Author Topic: [IC] GMK Nautilus 2 | GB LIVE!  (Read 135141 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] GMK Nautilus 2 | Kit update!
« Reply #150 on: Sat, 22 February 2020, 10:47:32 »
Fixed
Offline keyberzerker
« Reply #151 on: Sat, 22 February 2020, 12:48:50 »
Fixed
Not including YUGO ISO ... SMH
Offline nasp
« Reply #152 on: Sat, 22 February 2020, 15:08:51 »
Noticed on your site, rose of the winds being added to novelties? I like it. Makes the novelties a better buy for me!
Same. I’ll likely now get the novelties as well. Thank you for listening to feedback, Zambumon!!
Ditto. The kit's not as good as it could be, but the added image novelty is much better than the text novelty it is replacing.
Thanks Zambunny!
Offline Zambumon
    • Keyset projects
« Reply #153 on: Sat, 22 February 2020, 16:03:54 »
Offline piit79
« Reply #154 on: Sat, 22 February 2020, 17:34:04 »
You found the update right before I was going to post it here  ^-^
Kit update!
Awesome updates! I was also underwhelmed by the text novelties, very happy with the changes.
I might not be able to justify another base kit, but I can't wait to complete my R1 set with 40s, new novelties and spacebars kits.
Also, still keeping my hopes up for an R1 1u Rama artisan, perhaps also brass. Why not offer it alongside the Enter key? I bet there are plenty of people who can't use a 2.25u Enter key but who would love a matching Rama cap...
Offline Shutter_Shock
« Reply #155 on: Sat, 22 February 2020, 21:35:48 »
Kit update!
If we can only have one, I'd definitely prefer the brass Nautilus Rama enter with navy infill because of how cool it would be, but I would probably buy both Rama caps if there were also an R1 1u because I have no self control.
Offline lookid
« Reply #156 on: Sun, 23 February 2020, 04:00:48 »
no R2 Home and R3 End even at ext. kit?
very sad, I believed in that 'til the end.
VB
Offline bliss
« Reply #157 on: Sun, 23 February 2020, 05:47:51 »
New kits are great! - Wait what, no R3 \| for US ISO?
Looking forward to Oblotzky Industries, please do not understaff like it is so commonplace, for your sake and your customers' :thumb:
Offline Zeelobby
« Reply #158 on: Sun, 23 February 2020, 07:09:05 »
Where'd I miss this?
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #159 on: Sun, 23 February 2020, 08:01:18 »
European keyset enthusiasts and Nautilus fans, we have some great news for you:
Oblotzky Industries will be the European group buy host for Nautilus 2
You can read more about it here
Offline Zambumon
    • Keyset projects
« Reply #160 on: Sun, 23 February 2020, 11:39:29 »
I decided that it would be best to leave both the Explorer and Forties kits as they are right now. The kit sizing and price point are on point to what I was aiming for, adding more keys wouldn't be ideal.
No plans on adding back the US ISO layout support.
Offline heliar_mk
« Reply #161 on: Sun, 23 February 2020, 17:32:38 »
Don’t know why the explore kit have a r1 2u bs and r2 1.5u tab, as the base kit has these already.
Offline Zambumon
    • Keyset projects
« Reply #162 on: Sun, 23 February 2020, 17:38:01 »
As explained in the OP.
A standard Tab and Backspace key have been included so in conjunction with the Core kit you could re-use
the modifiers.
Offline thornkin
« Reply #163 on: Mon, 24 February 2020, 01:59:36 »
Some of the renders show sublegends on the numpad. Others do not.  Will there be sublegends or just the numbers?
Offline Zeelobby
« Reply #164 on: Mon, 24 February 2020, 03:20:37 »
In the update. No sublegends anymore.
Offline Zambumon
    • Keyset projects
« Reply #165 on: Mon, 24 February 2020, 06:58:38 »
No sublegends, I couldn't update all the renders in time, so the Sar ones are outdated :(
You can read more about the kit changes here: https://zambumon.com/2020/02/21/nautilus-2-kit-updates/
Offline thornkin
« Reply #166 on: Mon, 24 February 2020, 11:17:42 »
Thanks for the explanation.  I wanted to use this on a cypher which makes sublegends pretty useful.  Guess I'll look elsewhere.
Laser ALT sporting red Sky Pandas
Offline Zambumon
    • Keyset projects
« Reply #167 on: Tue, 25 February 2020, 06:18:21 »
If you are interested on numpad sublegends, you could just get a round 1 set. The colors and profile will be the same as Nautilus 2.
Offline bliss
« Reply #168 on: Tue, 25 February 2020, 07:15:47 »
I appreciate your sense of direction - no sarcasm here.
Offline Zambumon
    • Keyset projects
« Reply #169 on: Wed, 26 February 2020, 09:54:29 »
Got quotes from GMK  ;D We should have pricing from vendors soon.
Offline D3LTA
« Reply #170 on: Wed, 26 February 2020, 13:16:41 »
There seemed to be a lot of discussion on the possibility of adding a colevrak+ kit earlier but I didn't see a decision. Will you be adding a kit for this?
Offline Zambumon
    • Keyset projects
« Reply #171 on: Wed, 26 February 2020, 14:03:20 »
No.
Offline Zambumon
    • Keyset projects
Re: [IC] GMK Nautilus 2 | RAMA × Nautilus | Launching April 2nd
« Reply #172 on: Mon, 02 March 2020, 10:04:26 »
There's just a month left for Nautilus' re-release and we have a special announcement to make:
RAMA × Nautilus Novelty Keycap
Made in collaboration with RAMA WORKS®, we'll be releasing a limited-edition keycap designed to match the Nautilus 2 keycap set.
The keycap, which is made from anodized aluminium, depicts the Nautilus II ship from the League of Extraordinary Gentlemen created by Alan Moore and illustrated by Kevin O-Neill.
Technical Specs
- Bead-blasted aluminium. Anodized finish.
- Dark enamel infill.
- Cherry profile
- Row 3 2.25U size (ANSI Enter)
- Compatible with MX switches and clones
Offline IOVERCALLHISTIOCYTES
« Reply #173 on: Mon, 02 March 2020, 10:30:40 »
Oh man that's awesome
Offline shoobopper
« Reply #174 on: Mon, 02 March 2020, 10:37:53 »
Was expecting a navy infill due to your previous posts and would probably prefer a yellow e-coating over both.
I like the novelty kit additions though! Will probably be buying 2 kits for when 1 shines. :thumb:
Offline Zeelobby
« Reply #175 on: Mon, 02 March 2020, 10:45:47 »
Please no yellow coat. Like the brass standout. Infill of a color is fine.
Offline Zeelobby
« Reply #176 on: Mon, 02 March 2020, 10:46:04 »
And when we getting a mat of that illustration? Lol
« Reply #177 on: Mon, 02 March 2020, 12:57:57 »
Agreed. Pleaseeeee no yellow coat. Aluminum and infill color are fine, though I was also hoping for brass and navy.
Offline Zambumon
    • Keyset projects
« Reply #178 on: Mon, 02 March 2020, 13:22:02 »
We wouldn't get a perfect match with yellow e-coating and if I wanted that I'd rather get a novelty pack instead.
It's a milled aluminium keycap. Brass would be too heavy and problematic.
The black infill works with the set and makes the cap more versatile. I can see myself using it with sets such as WOB.
That could be possible.
Offline thornkin
« Reply #179 on: Tue, 03 March 2020, 02:52:58 »
No Vim this time?
Offline Zambumon
    • Keyset projects
Offline Zambumon
    • Keyset projects
« Reply #181 on: Tue, 03 March 2020, 10:30:01 »
GMK Nautilus 2 Pricing
Offline kilogeno
Put me in coach
Offline noorejji
Is Oblotzky pricing including EU tax? If so I trust that he'll subtract it if shipped outside of EU in Europe.
Offline Zambumon
    • Keyset projects
Pricing includes Germany's 19% VAT
Offline f1
Mobilis in Mobile
« Reply #185 on: Wed, 04 March 2020, 01:53:42 »
You have no idea how much trouble you have saved me by announcing the N2 six weeks in advance Mr. C.
I mean, even my Evernote bot started telling me I might be going a bit overboard with the "research" into what caps to buy next. So many notes. So many webpage clips. I bought Vernier Calipers for crying out loud!
And then I discovered it, ventured into it, and before long, sir, you too will have passed through my credit card statement.
Now, Wait a few months, our lantern will be lit, and, if you like light blue and yellow places, you will be satisfied.
Mobilis in Mobile kind man, Mobilis in Mobile indeed.
Offline Zambumon
    • Keyset projects
Kits' group buy pricing for all regions:
Offline Zeelobby
Pretty solid pricing.
Offline dom
  • allergic to hypocrisy
Approved!  :thumb:
Offline Zambumon
    • Keyset projects
Yep, on  point to what I was expecting them to be.
Offline batdog
Beautiful set, in for Core, Explorer, and Rama
Offline Zambumon
    • Keyset projects
Forgot to mention: we should have pricing for the RAMA × Nautilus keycap probably later this week.
Offline Traveler
I'm a few weeks late, but thank you so much for adding a Rose of the Winds novelty. I love my graphic novelties so I lost interest in this set shortly after it was announced, but that new addition is just enough to get me interested in R2 again.
« Last Edit: Sat, 14 March 2020, 21:50:53 by Traveler »
Offline Zambumon
    • Keyset projects
NAUTILUS 2 ORDERS OPEN IN JUST 10 DAYS
Save the date, Nautilus 2 group buy starts on April 2nd and we have one final update right before the group buy starts: Space Cables will be making some awesome themed cables!
Offline Azurewrath
From all i've read it looks like all the kits listed on the first page will be available to buy already anyway? Correct me if i'm wrong. :)
Anyway, i'd be in for Core+Explorer+International. Maybe even two sets each... we'll see. :)
Offline Zambumon
    • Keyset projects
Yes, those kits are final.
The kits will be available for pre-order from April 2, 2020 to May 5, 2020. Then, the order will be submitted to the GMK. The expected shipping date should be Q1 2021
Offline HerrGartenzwerg
Will all kits be made, specificaly the International kit?
Regardless of any MOQ?
Offline Zambumon
    • Keyset projects
Kits need to hit MOQ to get made.
Offline Azurewrath
Can you tell us how high the MOQ is? And will we be able to pre-order with the condition that all ordered kits are actually made?
(As an example, the other kits would be useless to me without the international kit.)
Offline big_tuna
That RAMA cap looks pretty dope with the Jules - looking forward to pricing for this!
