Author Topic: [GB] GMK Zhuyin (add-on kit) - Complete  (Read 76471 times)
Offline cbbplanet
Re: [GB] GMK Zhuyin (add-on kit) - $405 donated - Order Placed with GMK
« Reply #50 on: Mon, 09 November 2020, 12:40:09 »
can not wait to type in zhuyin again
Offline mustardgreens
« Reply #51 on: Mon, 09 November 2020, 12:51:13 »
It bo po mo fo time
Sent from my LG-M703 using Tapatalk
Offline Abhorrent Cell
« Reply #52 on: Mon, 09 November 2020, 12:51:25 »
Bam! Got my tracking. Getting this set just in time for a modded black/white HHKB. Super excited.
Offline HoodrowThrillson
Re: [GB] GMK Zhuyin (add-on kit) - Shipping to you!
« Reply #53 on: Mon, 09 November 2020, 19:02:05 »
For anyone wondering, I am making the second round of donations.
I can't recall exactly what it was supposed to be but I think $95 to round it out to $500 is more than suffice.
(I kind of forgot I only did one round and was waiting on 1-2 vendors)
Also Zhuyin should be arriving to your doorsteps soon. Thanks for another successful finish.
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #54 on: Mon, 09 November 2020, 20:44:20 »
Yessssss
Offline gnho
« Reply #55 on: Mon, 09 November 2020, 21:03:28 »
You're the man!
Sent from my Pixel 3 using Tapatalk
Offline vocal118
« Reply #56 on: Mon, 09 November 2020, 22:27:35 »
255574-0
255576-1
255578-2
« Last Edit: Mon, 09 November 2020, 22:30:39 by vocal118 »
Offline Arithmetics
« Reply #57 on: Wed, 11 November 2020, 12:01:54 »
looks sharp!
Offline keyboardkrill
« Reply #58 on: Fri, 13 November 2020, 13:36:34 »
So nice! Great work!!!
« Reply #59 on: Mon, 16 November 2020, 14:45:35 »
Just got my set, looks great.
« Reply #60 on: Mon, 16 November 2020, 17:19:47 »
Same. Nice crispy legends. Everything looks great.
Offline m1raz
« Reply #61 on: Mon, 16 November 2020, 17:35:02 »
Looks sharp!  :thumb:
Re: [GB] GMK Zhuyin (add-on kit) - Complete
« Reply #62 on: Sun, 06 December 2020, 03:07:55 »
« Reply #63 on: Sun, 06 December 2020, 11:23:37 »
Looks awesome.
In other news, I will be running a set utilizing these molds through Novelkeys in 2021. (Mike and I worked hard to get these made so might as well do something with them you know)
Offline gnho
« Reply #64 on: Sun, 06 December 2020, 11:36:03 »
Nice! Thanks for sharing the news! I suppose it will be in a different color way? Maybe a Taiwanese theme?  ;)
Offline DukeEsquire
« Reply #65 on: Sun, 06 December 2020, 16:04:41 »
Would love to see this in a 9009 addon kit as well.
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #66 on: Mon, 07 December 2020, 07:39:04 »
Oh yes.
Offline DukeEsquire
« Reply #67 on: Mon, 07 December 2020, 15:42:13 »
I assume some folks have seen the Metaverse potential issue with R2 alphas.
I just opened by Zhuyin set and I have the same issue. Anyone else have this issue?
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #68 on: Mon, 07 December 2020, 15:43:18 »
Would you mind describing the issue instead of just referring to it as "this issue/the issue"?
Offline DukeEsquire
« Reply #69 on: Mon, 07 December 2020, 15:53:38 »
Yes, good point, I wasn't very clear in my initial post.
Here is a picture of what the issue is: https://imgur.com/a/bTxvbuV
Here is the Metaverse post on the same issue: https://geekhack.org/index.php?topic=104269.msg2988992#msg2988992
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #70 on: Mon, 07 December 2020, 16:23:37 »
Interesting. So varying textures on the top? I suppose enough usage would even things out in time, but I can see the inconvenience in both the look and feel. Sounds like QC from GMK is dropping off the edges as has been proven with a few other things. I can only imagine since we have many dozens of sets in the queue now with many thousands of kits.
I did notice a bit more texture on my Zhuyin WoB spacebar, but the alphas weren't uneven by row or anything like that on mine. Perhaps I haven't paid close attention, but if I check again, I'll make sure to note it.
Offline DukeEsquire
« Reply #71 on: Mon, 07 December 2020, 17:27:29 »
If it's one of those things that will even out over time, it wouldn't bother me. I'm just concerned that I'll have a difference in texture forever. I'm not one of those people that gets freaked out over shine.
Offline delrn
« Reply #72 on: Tue, 08 December 2020, 08:16:22 »
I just checked both my WoB and BoW sets, the texture is indeed different across the whole R2. It's not as noticeable on the BoW keys, you can definitely tell under normal lighting with WoB though.
257399-0
Offline diyachronic
« Reply #73 on: Tue, 08 December 2020, 08:46:34 »
Just throwing his here for documentation. I'm not too worried if this shines out, but it's a little bit of a bummer as I was trying to do a proper time-lapse of "the shining" and it's very apparent there's a texture difference.
« Reply #74 on: Tue, 08 December 2020, 08:53:16 »
zF brought this to our attention a little time ago. Mike and I have been working towards a solution to this problem.
We did not want to pre-emptively post without having all the details. Please expect an update from either of us on the situation once we figure more things out.
I believe the issue was that the texture on R1(qwerty) is different than the other rows. Additionally it's not as noticeable as Metaverse since the keys are WOB or BOW.
Offline Lil
    • designedbydark
« Reply #75 on: Tue, 08 December 2020, 09:44:07 »
If you look on the back of the keycaps there is a different doubleshot pattern between the textures
« Reply #76 on: Wed, 09 December 2020, 11:02:45 »
I inspected mine carefully, there seems to be no defect.
Offline thanatic
« Reply #77 on: Wed, 09 December 2020, 23:21:45 »
woops missed this set.
Offline diyachronic
« Reply #78 on: Thu, 10 December 2020, 09:11:03 »
Do your R2 alphas have the same doubleshot pattern on the back as your other alpha keys? Mine had a vertical pattern rather than the normal horizontal one.
I'm absolutely in love with this kit, but just curious how yours turned out.
Offline orim23
« Reply #79 on: Fri, 11 December 2020, 14:45:40 »
My Zhuyin sets all have this "defect". but on the white set its barely even visible. And yes, on the back they have a vertical pattern on all R2 keys.
Offline tentboy
« Reply #80 on: Fri, 11 December 2020, 18:16:07 »
Texture issues aside... I still like the set alot!  Put it on my salamander today.
« Reply #81 on: Sat, 23 January 2021, 16:07:09 »
All horizontal on the back, nothing out of the ordinary with them.
« Last Edit: Sat, 23 January 2021, 20:39:41 by mustardgreens »
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #82 on: Sat, 23 January 2021, 22:09:52 »
Doubleshot pattern on the back is a thing to scrutinize now (/s)? TIL
Offline Lil
    • designedbydark
« Reply #83 on: Mon, 25 January 2021, 16:27:13 »
260525-0
