Author Topic: (Artisans, UK) Need recommendations for Silicone Rubber for Mould  (Read 4004 times)
Offline CrazyNun
« on: Tue, 04 February 2020, 03:54:57 »
Hi, I'm just getting into artisans and would like some recommendations for silicone rubber that can use for mould making. The casts that im doing won't be very detailed (im not sculpting anything) - just doing some swirly psychedelic resin casts of row 1 SA profile keys. I have seen many people use Oomoo 30, but it is quite expensive for small quantity - and I keep reading that you have to use it all in one go otherwise it just sets.. was wondering if there are cheaper options that are equally as good?  What would be wrong, for instance, of using this - https://imgur.com/a/165OeOa ?
I live in the UK and would be ordering online..thanks
Offline nevin
Re: (Artisans, UK) Need recommendations for Silicone Rubber for Mould
« Reply #1 on: Tue, 04 February 2020, 04:23:50 »
they cover most everything here
Offline IsoCaps
« Reply #2 on: Thu, 06 February 2020, 14:06:19 »
RTV silicone works great.  After trying a few I settled on this one and have used it successfully for a couple of years now.  Great quality and and loads of different quantities available.
https://www.scarva.com/en/Scarva-Special-Effects-Mold-Makers-RTV-Silicone-Mould-Making-Rubber/m-3052.aspx
Offline CrazyNun
« Reply #3 on: Sat, 08 February 2020, 07:42:56 »
Thanks man, think ill order some.
And about Silicon mould release - how's this product -https://www.invotecsolutions.co.uk/ambersil-formula-5.html -  it's cheap and quickly available in a store near me (as opposed to Mann Ease Release 200)
« Last Edit: Sat, 08 February 2020, 07:49:49 by CrazyNun »
Offline IsoCaps
« Reply #4 on: Thu, 13 February 2020, 09:57:06 »
Personally I use this, it works well but I haven't really tried anything else to compare it to:
https://www.mbfg.co.uk/macwax.html
Offline IsoCaps
« Reply #5 on: Tue, 18 February 2020, 03:46:24 »
Having said that, using a wax release always leaves a residue that needs a fair amount or work to remove, so might be worth experimenting with a few other types.
