Author Topic: [IC] Evolv | A four year journey complete  (Read 521901 times)
Offline botchm
Re: [IC] Evolv - 75% Keyboard | Color Poll!
« Reply #200 on: Tue, 11 February 2020, 13:34:57 »
Join discord to look at this beauty.
Woooww, that looks amazing. You would be lucky to get your hands on something that sick looking, it oozes some dark alien vibes.. If there is a black variant, I will definitely sign up for the raffle
Any ideas on the price yet?
I know, imagine. He said very limited :( like super limited 25-45. But I told I have 1k set aside already haha
Offline Nivengoh
« Reply #201 on: Tue, 11 February 2020, 13:38:10 »
Seeing all these render has me really hype, its such a shame its only a limited run. I really don't have much confident in my luck to win raffle =(
KBD8x | E8-V1 | Xeno 75 | RAMA U80-A
Offline notabotscammer
« Reply #202 on: Tue, 11 February 2020, 19:36:58 »
very interested in the white case with the rose gold knob
Offline TonyPia
« Reply #203 on: Tue, 11 February 2020, 20:46:01 »
What's your discord?
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #204 on: Tue, 11 February 2020, 21:54:52 »
First post has a link to the discord sir.
Offline kalayna
« Reply #205 on: Wed, 12 February 2020, 08:13:24 »
Design nerd here, I have to ask - what software did you use to design this?
Offline NathanAlphaMan
« Reply #206 on: Wed, 12 February 2020, 08:22:28 »
The keyboard was designed in Fusion 360. I swapped to Fusion after 7 years in solidworks prior to starting this project. Haven't looked back for a moment.
Offline willyG
« Reply #207 on: Wed, 12 February 2020, 10:16:35 »
Can you make the bottom piece in in color / anodize it? I think white top ruby red bottom would look super trill :)) Sexy keeb either way  :eek:
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #208 on: Wed, 12 February 2020, 14:58:48 »
idk about that plate lol
may as well just make it PCB mount with a half plate
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #209 on: Wed, 12 February 2020, 15:35:37 »
Its integrated plate, one side of the switch will always be stiffer when we are talking about a switch near the edge like left control or caps. The alphas look uniform enough but why not just make a half plate with just the bottom row and top row having the integrated plate so that the pcb still has something to be mounted onto with switches. Your simulations are doing one keystroke at a time rather than multiple subsequent (sometimes concurrent) strokes within a short time period of each other. People also dont always hit the center of the keycap/switch directly at a perfect 90 degrees. Some people type heavily and others light. The simulations work only in a theoretical setting and arent really practical. A partial plate will provide as much consistency in typing feel without having to worry about whether or not those switch cutouts will break or bend.
Overall I think the plate is over engineered and you could've taken a much simpler, cost effective approach if you wanted to achieve uniformity.
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
« Reply #210 on: Wed, 12 February 2020, 16:35:53 »
Let's go through this bit by bit. Much like with Iron165, all engineering was done for the worst-case scenario of 2N or 200g force if you want to compare it to spring weights. From speaking with those who have typed on a 165 FE, this worst-case engineering process works for creating a more consistent typing experience, even if it doesn't represent the average user. Next, in terms of forces being not normal to the plate, I invite you to try and type off-angle right now. Likely, your finger just slipped over the key as switches are constrained to follow a normal path to the plate. If any sideways forces exist, they are due to friction between your skin and the keycap, a force so minimal it isn't worth time approximating. Finally, to address the one keycap at a time simulations: the fastest typists on here are at 200 wpm or so? With an average word length of 5 letters, that's 1000 letters a minute or 16.6 letters a second. If we generously round up, that means you depress a key every 1/20th of a second. Under a 2N load, the spring rate of aluminum is considerably faster than that.
Offline Remsky
« Reply #211 on: Wed, 12 February 2020, 17:33:19 »
- go observe your fingers resting on keycaps in typing form. It is not a perfect 90 deg. My argument is that its not a single point like your simulations use but rather an entire area that may or may not exert its force evenly. You can't assume a perfect force and say it transitions to a practical scenario.
- 200g is way more than what is necessary to actuate a switch. Just look at the most popular spring weights which usually fall in the lower to mid 60g weighting. Lets take the point above and assume that your 90 deg theoretical typing pressure completely applies to practical typing. You can make the plate consistent for 200g, but 200g is not anywhere close to how much force is applied per keystroke. Most people bottom out their switches whether harshly or lightly. Even with people who harshly bottom out, they might increase the spring weight to the upper 70s at most. Some outliers love weights above the 70s. Those are still obscure cases since the 70-89g range is still uncommon in most custom boards relative to 50-69g range. So you are basically adjusting the feel of the board for the .001% of people who might actually constantly type with 200g of force at a reasonable WPM. Consistency != flex. Your plate can be consistently stiff and still be consistent.
- Your simulations don't even account for a pcb. This means that even if we assume your hypothetical force simulation to be a 1-1 replica of real typing, it would still be inaccurate. You aren't accounting for the fr4 pcb that will go beneath the aluminum plate and whatever thickness that you choose for it.
Sometimes consistency shouldnt always the goal, and its seriously become a fad nowadays. Perfect consistency in keyboards is extremely hard to achieve and sometimes impossible with a given mount: Your F row, arrow cluster and nav cluster won't be consistent feel wise with your alphas or mods, its just a facet of many mounting styles and how you implement flex cuts. What matters is if the board provide a comfortable typing experience on the alphas and mods where typing is most frequent. I think you are going a bit overboard with the science and not looking into the practicality of things.
« Last Edit: Wed, 12 February 2020, 17:37:10 by Remsky »
« Reply #212 on: Wed, 12 February 2020, 17:57:38 »
Okay, let's do this one more time.
- My simulations aren't a single point, they're force over area, with that area being the switch contact surface on the plate. With the way keycaps are designed and the way the switch physically works, the difference between pushing on the left side of the cap vs the right side of the cap is negligible when it comes to the force distribution over that area.
- 2N was an experimentally determined upper-boundary during the iron165 IC. The great thing about working with non-elastic materials (like metals) is that if flex is consistent at 2N, it's also consistent at all loads less than that.
- They do account for a PCB. You're just wrong there.
- I've never pretended I want the F-row, columns, and arrows to flex as much as the alphas flex. In fact, I'm doing exactly what you're suggesting: which is prioritizing the feel of the alphas and mods. That's the reason why there are no crazy cutouts in that section of the plate. I'm going overboard with the science to show that not only is this analysis possible in keyboards but that it has practical benefits to an end-user.
« Last Edit: Wed, 12 February 2020, 17:59:28 by NathanAlphaMan »
Offline lbaron
« Reply #213 on: Wed, 12 February 2020, 18:31:48 »
Has it really become a fad?  I feel like we were the first board to put engineering to it to try and make the typing on alphas feel more consistent.
As for your 2N being crazy.  Look at this:
He is playing in that sloped line on the left called the youngs modulus.  As long as you don't exceed that area, metals will spring back to their original shape with no permanent deformation and behave as such.  So at 2N he might exhibit a 0.15mm displacement of keycap switch, but at 0.7N it may only be 0.09mm, either way the plate will behave the same uniformly.
Offline Remsky
« Reply #214 on: Wed, 12 February 2020, 18:42:58 »
- Your force is still off for keys like mods and some alphas that don't have mounting/connections on all sides. Take for example the popular 3-sided space bar on OTD boards and now plenty modern boards. The flex while pressing down on the spacebar is relatively even on the top, left and right side of the spacebar switch. The bottom side of the spacebar has no mounting, it flexes considerably more than the rest. if you don't press down on the bottom side of the spacebar you wont really notice it as much. Take your left control or shift for example. They are connected via the bottom side of the switch to the plate structure/left control respectively. If I disproportionately place more force on the top side of that left shift, it will bend/flex more than if I put the same amount of force on the bottom side. Keycaps help distribute force on the switch, that doesn't mean that they perfectly spread out force. Your constraint when it comes to weighting is wrong.
- Consistency doesn't guarantee flexibility. As stated in my example above it could be guaranteed in your simulation but maybe not in a practical setting. Your QAZ column is also stiffer than the rest of the alphas because there are two connections between Q and the much stiffer numrow compared to how the rest of the switches in the qwerty row are.
- I assumed not because your simulations don't show a picture of the pcb nor do you mention that you did test with a pcb. When you say you made a visual representation of a test, then everything you tested should be present in that visualization. There is only a plate in those visualizations. You don't even make a mention of a pcb in the plate design section.
- Its great to go overboard with science when the approach is right. I disagree with your approach with this board.
« Reply #215 on: Wed, 12 February 2020, 19:18:47 »
Cool. You have your opinions and I have my months of research and data analysis. Yes there are some problem areas in the plate, namely the much higher compliance values on the QAZ column. But again, as I've mentioned in both the write-up and various replies throughout the thread, the plate is ever changing. Since the IC went live I've already incorporated a lot of the constructive crtisism I've received into the model to improve generation. The QAZ issue is nearly fixed and left shift no longer floats. I apologise for not talking about PCB analysis in the write-up, but it's also information that's readily available in the thread in the form of replies to questions about that exact topic.
Offline Jaxxstatic
  • Haptic Recon
« Reply #216 on: Wed, 12 February 2020, 20:12:44 »
Interested in how the prototype actually comes out though.
Offline asdds22
« Reply #217 on: Thu, 13 February 2020, 09:47:14 »
Even though I questioned about the shear stress and Nathan replied, the discussion about orthogonal force simulation won't be over. This should be described in the first post.
The guy wants you to present in the conference-style I think. How surprised it is. I never saw a question like that in my conference experience. Or the first post should be described in a paper-style? with a proper reference?
As a mechanical engineering graduate, as a student in a master's program, the discussion made me sad. That guy didn't even know how the stress made deformation in a specific material.
Offline vewy_nice
« Reply #218 on: Thu, 13 February 2020, 11:36:40 »
I do tech support for a company that makes instruments to measure fluid properties, mostly viscosity.
Sometimes I'll get a call and someone's like "My viscosity is reading very different between setup a and setup b! Why!?"
And then when I mention that setup a has a shear rate of 0.50 sec-1, and setup b has a shear rate of 65 sec-1, they're confused why that matters... And the response to me inquiring about rheological properties of their sample results in a "The what, now?"
And these are supposed to be industry professionals lol.
Anyway...
I'd type on a bed of soggy moss if it looked this sick, so... Carry on with the design!
« Last Edit: Thu, 13 February 2020, 11:38:20 by vewy_nice »
Offline dubious
  • 쏘쿨
« Reply #219 on: Thu, 13 February 2020, 12:17:16 »
Nice! I'd like to stand on that thing
Offline Butterbeer
« Reply #220 on: Thu, 13 February 2020, 12:42:18 »
It’s nice to see keyboard design emphasize a scientific approach, otherwise it’s just an exercise in aesthetic value, taste, and personal preference. Often the challenge I’ve observed is explaining the science in a straightforward way that everyday people can easily understand, digest, and appreciate.
Offline hottrout
  • I'd Hit Dat Key
« Reply #221 on: Fri, 14 February 2020, 07:19:44 »
Agreed.  A great design and looks, hopefully it can be actually made.  Good luck with this.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline L8T
« Reply #222 on: Fri, 14 February 2020, 11:41:12 »
Its a cool idea but idk why you are trying to get consistent feel when the plate displacement is less than 0.2mm. Im also worried about the left and right shifts pinging cuz its basically a cantilever, but i assume the plate material is stiff enough to prevent that :S Either way gl with your research!
Offline lush_bunny
« Reply #223 on: Fri, 14 February 2020, 12:39:26 »
With the amount of interest this board is generating, I doubt I’ll get a slot. Apart from that, discussion in discord is implying big bucks. So I have to ask: will a round 2 be considered? Thanks!
« Reply #224 on: Fri, 14 February 2020, 12:52:16 »
I'm working on getting that number up, 10N/mm is the target for compliance.
Let's get round 1 done first. ;D
Offline flysloth
« Reply #225 on: Fri, 14 February 2020, 20:46:06 »
Wonderful!
I like the rotary joystick.
Offline BlankeyGotCaps
« Reply #226 on: Mon, 17 February 2020, 09:43:57 »
Absolutely Stunning.
Offline Darthbaggins
  • PC Cannibal
« Reply #227 on: Tue, 18 February 2020, 21:40:30 »
Beautiful design, I'd love to get this board  :eek:
Offline YoRHannya
« Reply #228 on: Wed, 19 February 2020, 02:21:23 »
Beautiful design. Would love a chance to have this board.
Offline Felt
« Reply #229 on: Thu, 20 February 2020, 23:42:51 »
Is this board going to be run via normal GB or is it going to be a raffle? thx
Offline BanksE
« Reply #230 on: Fri, 21 February 2020, 00:10:02 »
Im excited to see where the bottom plate design can be carried over in the future. I love beam/truss structures in architecture and this has a very organic truss vibe that I like a lot.
Offline Void225
« Reply #231 on: Fri, 21 February 2020, 10:23:13 »
I want this keyboard but with hotswap on the keys. I can do and don't mind soldering but hotswap is just so much more convenient for dealing with broken switches and just "I feel like playing around". RGB would be nice too but not essential. Yes I know you poo-pooed both of these on the front page, but my opinion stands: I would buy this instantly with one or both features; without it's a bit less attractive and will depend on price and keycap availability. I don't understand why "high end" is somehow in avoiding these features. To me, high end means MORE features, not less.
« Last Edit: Fri, 21 February 2020, 10:36:54 by Void225 »
« Reply #232 on: Fri, 21 February 2020, 12:08:21 »
The board will be run via raffle. Quantity, Date, and Price are all still TBD.
Offline Crack85
« Reply #233 on: Fri, 21 February 2020, 12:52:32 »
Raffle.... Well there goes my chance of getting one. Really cool board though.
Sent from my Pixel 3 XL using Tapatalk
« Reply #234 on: Fri, 21 February 2020, 15:52:53 »
I'm still considering whether or not to have a limited amount of boards reserved for a Vickery auction after the raffle spots deliver. So not all hope is gone :p
Offline JayBeamz
« Reply #235 on: Fri, 21 February 2020, 19:57:01 »
this is just gorgeous!.... perfection perfected.... really hope i can get my hands on one, knowing that now it will be via raffle  :confused: :eek:
Offline dom
  • allergic to hypocrisy
« Reply #236 on: Fri, 21 February 2020, 23:25:10 »
Life is short. Please do unlimited GB  ;D
Offline triplec110h
« Reply #237 on: Sat, 22 February 2020, 13:29:01 »
Another 75% fanboy checking in. Looking forward to joining the raffle!
Offline Karni
« Reply #238 on: Sat, 22 February 2020, 15:46:17 »
i dont even like big boards, but just shut up and take my money already, this is awesome
Offline godofdeath
« Reply #239 on: Sat, 22 February 2020, 17:55:14 »
Is there a list of kits that give us a 1.5u shift?
Offline Crack85
« Reply #240 on: Sat, 22 February 2020, 17:56:32 »
Very very few.
Offline WZ3R0
« Reply #241 on: Mon, 24 February 2020, 18:48:15 »
Great size and. has a Win key!
Offline PocketAces
« Reply #242 on: Tue, 25 February 2020, 18:56:15 »
What’s the knob material again?
I would definitely go in on an all black.
« Reply #243 on: Thu, 27 February 2020, 03:53:40 »
As of right now, the knob is alu
« Last Edit: Fri, 28 February 2020, 04:41:38 by NathanAlphaMan »
Offline FaKe_VirTual
    • Virtual Designworks
« Reply #244 on: Thu, 27 February 2020, 05:17:30 »
This Board is truly amazing.
Great Job!!
Offline PocketAces
« Reply #245 on: Thu, 27 February 2020, 06:37:02 »
As of right now knob is alu
Any chance the knob 3D file would be available for us to play with? It could be interesting to see people customize the knob in different ways.
« Reply #246 on: Fri, 28 February 2020, 04:41:15 »
Yes! In fact, I have some extra special plans for the spot.
Offline PocketAces
« Reply #247 on: Sat, 29 February 2020, 09:02:46 »
Every day I pray that I get a spot in this raffle. Pleaaaaase do that all black version you teased earlier.
Offline asianfork
  • Alice
« Reply #248 on: Mon, 02 March 2020, 23:31:04 »
I keep going back to this post because I find this case to be very interesting. However, I feel like there will be a lot of durability issues or even the easiness of cleaning the board.
Offline chanceofthat
« Reply #249 on: Mon, 02 March 2020, 23:31:35 »
I joined geekhack today because this is the first keyboard I've actually wanted badly enough to join the community.
