Author Topic: [IC] Lyra keyboard (March 1 to 22, 2020)  (Read 34253 times)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
Re: [IC] Lyra keyboard
« Reply #50 on: Mon, 10 February 2020, 07:58:24 »
« Last Edit: Mon, 15 April 2024, 19:32:54 by FearsomeCubedWarrior »
Offline alexbarb
« Reply #51 on: Mon, 10 February 2020, 08:21:12 »
I think, kle links for all supported layouts will help to prevent confusion.
I will do it to GB. I took this from my project North https://geekhack.org/index.php?topic=99231.0. I will return to him and finish as I complete Lyra
Offline rmendis
  • Artisan addict
« Reply #52 on: Mon, 17 February 2020, 00:09:26 »
Will all those color options be available? I love the breadth of choice
« Reply #53 on: Mon, 17 February 2020, 01:49:24 »
« Last Edit: Mon, 15 April 2024, 19:33:03 by FearsomeCubedWarrior »
Re: [IC] Lyra keyboard (NEW: Beta PCB. Update Color. GB Date)
« Reply #54 on: Thu, 27 February 2020, 04:11:24 »
« Last Edit: Mon, 15 April 2024, 19:33:24 by FearsomeCubedWarrior »
Offline stoffelduss
« Reply #55 on: Thu, 27 February 2020, 06:53:13 »
Awesome! Can we get a few renders of both the alpha and the beta version for the GB? I'm thinking about maybe building beta with a full spacebar, but a picture would help in deciding if I _really_ want it :D
Offline alexbarb
« Reply #56 on: Thu, 27 February 2020, 07:22:29 »
Visualization will be on internal changes in the housing prior to production. The layout can be considered without visualization)
Offline KneeDeep
« Reply #57 on: Thu, 27 February 2020, 09:49:30 »
I was just saying how I wanted a 60% southpaw yesterday and then I find this. I'm in!
Offline diegopx
« Reply #58 on: Thu, 27 February 2020, 10:03:29 »
Woah. Really sweet design. I'm guessing the standard num keys (above the alphas) would be under a layer? Specifically curious as to how you'd get at the symbols these shift into.
Offline alexbarb
« Reply #59 on: Thu, 27 February 2020, 10:23:35 »
this is QMK. there may be other solutions
https://imgur.com/a/xq07FHt
Offline diegopx
« Reply #60 on: Thu, 27 February 2020, 11:16:09 »
Thanks for that, not very familiar with QMK, that's very helpful. Count me in, really digging what you got going on here and looking forward to the GB.
Offline bakuretsu
« Reply #61 on: Sun, 01 March 2020, 07:26:18 »
GB is scheduled to start on March 1 to March 22
Ok, let me just check my calendar...
Offline alexbarb
« Reply #62 on: Sun, 01 March 2020, 07:35:33 »
GB will start soon. waiting for the confirmation of the moderator.
Offline Starius
Re: [IC] Lyra keyboard (March 1 to 22, 2020)
« Reply #63 on: Sun, 01 March 2020, 17:49:51 »
It's live, if no one noticed yet!
https://geekhack.org/index.php?topic=104916.0
