Author Topic: [IC] H1 Linear Switch by HHHH - In-Stock Sale Tomorrow  (Read 133950 times)
Offline austinliu
Re: [IC] H1 Linear Switch by HHHH - Production Complete + Review Link Added
« Reply #350 on: Wed, 15 April 2020, 15:15:39 »
With the date of the sale for these rapidly approaching, I thought I'd compile my full thoughts into a review. See the link below to read it.
https://eniigmakeyboards.com/pages/h1-switch-review
Good read
Offline Zeelobby
« Reply #351 on: Wed, 15 April 2020, 16:07:22 »
Don't quite understand the broken in stems part. So when broken in the stem wobbled a fair amount. But then you filmed em and somehow that reduced stem wobble. That's not how films work. They reduce housing wobble, but not stem wobble.
Offline eniigma
    • Storefront:
« Reply #352 on: Wed, 15 April 2020, 16:10:02 »
The way I see it, stem wobble = housing wobble. My logic is probably incorrect, but just bear with me.
The switches "broke in" and got smoother, the same way novelkeys creams do. Hope that answers your questions
Offline sortofsleepy
« Reply #353 on: Wed, 15 April 2020, 17:29:39 »
Could be wrong but I'm guessing housing wobble compounded the stem wobble, hence, after adding films, stem wobble appeared reduced.
Offline Zeelobby
« Reply #354 on: Wed, 15 April 2020, 17:41:09 »
Ah. Ok. Yeah. That makes more sense. I mean bad stem wobble is a concern. If it's only average with bad house wobble, I'm ok with filming.
Offline eniigma
    • Storefront:
« Reply #355 on: Thu, 16 April 2020, 08:19:56 »
There is virtually no wobble after filming, and the sound definitely improves :thumb:
Offline pixelpusher
« Reply #356 on: Thu, 16 April 2020, 08:44:32 »
Well darn. Sounds like your basic Durock switch.  It’s fine.  I like
Them a lot.  Just unfortunate that you have to film them.
Offline Joaquox
« Reply #357 on: Thu, 16 April 2020, 10:19:11 »
Well, $6 for a regular durock is a bit over the top.
Offline FIJ1
« Reply #358 on: Thu, 16 April 2020, 10:29:45 »
Is it $6 per switch or per 10 switches?
Offline Joaquox
« Reply #359 on: Thu, 16 April 2020, 10:46:18 »
Per 10.
They cost $.55 at durock if you buy a small quantity, if you buy more than 10000 you get them for $.4 ea without even haggling, though I hear you can get the price down below that.
And if you cut durock out and buy directly from JWK, you'd probably get a better price still.
Offline steezkeez
« Reply #360 on: Thu, 16 April 2020, 16:30:19 »
Might go with 3203 instead of 205g0 for these since it looks to be like they're pretty smooth stock.
Offline hmmmwhatsthis
  • no
« Reply #361 on: Thu, 16 April 2020, 17:00:25 »
Lol better off buying Durocks at this price if you have to film them for them to even be decent.
Offline Gondolindrim
    • My GitHub
« Reply #362 on: Thu, 16 April 2020, 22:26:27 »
I thought this wasn't produced by JWK?
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline clik_clak
« Reply #363 on: Thu, 16 April 2020, 22:29:05 »
Right in the OP:
"These are NOT ordinary JWK linears; HHHH worked with JWK and modified existing molds to his specification."
Offline scoopbb
« Reply #364 on: Thu, 16 April 2020, 23:45:05 »
all jwk linears are the same, change my mind.
Offline eniigma
    • Storefront:
« Reply #365 on: Tue, 21 April 2020, 15:11:53 »
Per 10.
*sigh* These aren't durock switches. Anyhow, the sale starts tomorrow so you'll finally have a chance to try them and formulate opinions.
The group buy thread is pending approval right now, and I will link it when it is approved. Thanks everyone!  :D
Offline eniigma
    • Storefront:
Re: [IC] H1 Linear Switch by HHHH - In-Stock Sale Tomorrow
« Reply #366 on: Tue, 21 April 2020, 15:19:19 »
GB thread is live. Please refer to that thread for any further discussion!  :thumb:
https://geekhack.org/index.php?topic=105882.msg2891920#msg2891920
