Author Topic: Razer replacement spacebar stabilizer  (Read 7622 times)
Offline MrZozool
« on: Wed, 12 February 2020, 14:56:13 »
Hi, I am very new to this community so sorry if it is not a place to post this. I have Razer Blackwidow Chroma with no spacebar stabilizers and that's the reason I was not using it. I spent last 3 hours looking for them but I couldn't find any 6u stabilizers. The spacebar also has no "pins" in the places that should be over the stabilizers. Could anyone help?
Mod edit: split post and changed title
« Last Edit: Wed, 12 February 2020, 18:53:55 by suicidal_orange »
Re: 6u stabilizer wire
« Reply #1 on: Wed, 12 February 2020, 18:52:58 »
Welcome to geekhack :)
As this is a completely different question I've made you a new thread, otherwise people who don't like guessing circuits won't look at it.
From reading around it seems the Razer use Costar stabilizers so you'll need to find some end pieces (they are the same for any size) and a wire - I found this on ebay which is expensive for a bit of wire but at least it has cheap shipping to you.
Offline MrZozool
Re: Razer replacement spacebar stabilizer
« Reply #2 on: Thu, 13 February 2020, 13:36:07 »
Thank you a lot, I will actually try that.
Also big thanks for a very warm welcome <3
