Author Topic: [IC] ADK64v2 - Split Gasket Mount 60%  (Read 23571 times)
Offline menuhin
Re: [IC] ADK64v2 - Split Gasket Mount 60%
« Reply #50 on: Thu, 16 July 2020, 03:42:39 »
I've been looking for a case for my original AEK keycaps, and found the ADK64.
In version 2, I like the smoother curve and the smoother print result, and even the gasket mount and split-able idea.
Some requests:
  • I still like to re-use my AEK Apple logo and stick it onto the case
  • I like to sport my AEK keycap set, and its 6.5u spacebar - but if you can't make 6.5u space happen, can you resin cast / custom make some fitting split spacebar caps like the R_Shift in the Lunar case?
  • This splits like a Mistel, kind of quite asymmetric; if you add one functional column on the left edge of the left-half, both sides can be symmetrical.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline menuhin
« Reply #51 on: Thu, 16 July 2020, 04:08:04 »
e.g. a concept from my previous comment:
IBM M13 black
HHKB Pro 2 HasuBT
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #52 on: Thu, 16 July 2020, 09:25:21 »
Hey, thanks for the feedback/input. I will be making space for the apple logos. Not sure about a 6.5u space, but I will be supporting the 4.75 from the M0116. I'm not a fan of the arrows on the left, or arrows at all.
