Author Topic: [IC] OIL-68 (5/20/20 - CLOSED)  (Read 27939 times)
Offline Retne
Re: [IC] OIL-68 (3/28/20 - Updated Layout)
« Reply #50 on: Mon, 30 March 2020, 14:13:24 »
I love that the plate has 2 cool S symbols on it.
Offline Arezok
  • Formerly pbplyr38
« Reply #51 on: Mon, 30 March 2020, 15:29:52 »
Is the back weight an infinity? It also looks a bit like a bikini top
Well now I can't unsee that.  But the weight is very much a work in progress.  I really wanted to provide an update on the overall design changes since the initial post
very nice, the accent plate makes the board stand out. The bottom weight looks a little out of place to me, I'd like to see it more like the "infinity" symbols on the plate. Dunno, maybe a rectangular weight with engraving.
The bottom weight is definitely changing.  I have a few ideas in mind that I'm going to mock up in fusion before I push out a more "final" model for a prototype to be manufactured.
 :cool: :cool:
Offline awstonedp
« Reply #52 on: Mon, 30 March 2020, 17:08:18 »
That’s really the only thing that needs to change on this board
And your solution is 100% what he should do
Offline JustFluxz
« Reply #53 on: Thu, 23 April 2020, 11:53:25 »
What are the odds that the pcb will be hotswap? If it is, this might be a must-have for me... I hope the amount sold won't be too limited... Please be a groupbuy!
I really love this layout, but it definitely will be an adjustment losing the F-row, but that comes with this format of keyboards. I really like how the Esc is separated from the rest of the board, as well as the arrow and additional keys being separated too.
« Last Edit: Thu, 23 April 2020, 11:55:01 by JustFluxz »
Wantlist: Black/Red Blue Little Dot, Orwell Revenant, 451 Spook, Heterochromic Shishi
Offline Kinesiologist
« Reply #54 on: Thu, 07 May 2020, 19:39:22 »
Please support the following in regards to the PCB:
QMK
USB-C connector
ESD protection
thank you
Offline twoshoes
« Reply #55 on: Sun, 10 May 2020, 23:59:30 »
I really like the esc key position. Not sure if I personally like all the dark colors offered but I will be following this one.
Offline KaosJ
« Reply #56 on: Mon, 11 May 2020, 00:24:44 »
Probably in if ESC will be placed in a normal position.
I also would suggest the logo a bit on the left (in the space between the 60% module and the right keys), above the arrows
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #57 on: Tue, 12 May 2020, 02:48:49 »
I don't have a particular opinion on the logo, but given a lot of people are asking for the esc to be in a traditional spot, I feel the need to comment: please keep it as it is, I really like it's placement now :)
Offline werc
« Reply #58 on: Tue, 12 May 2020, 10:16:38 »
I think this keyboard is awesome. Glad you shrank the emblem and added a key. If you end up doing hotswap, I am definitely in.
Offline IBMweMissU
« Reply #59 on: Sat, 16 May 2020, 14:32:12 »
Wireless or BT option?
Offline asciisii
« Reply #60 on: Sat, 16 May 2020, 14:52:09 »
Like this a lot. Looking forward to updates / protos
Offline alper_maestro
« Reply #61 on: Sat, 16 May 2020, 15:14:23 »
Great looking board.  Any change of a hot-swappable PCB?
