Author Topic: Where is the silent linear with 4mm of travel?  (Read 2106 times)
Offline lakeboredom
« on: Sat, 14 March 2020, 03:03:49 »
If someone could get on that please... Like instead of adding rubber material to the sliders and reducing the travel, have the bumpers be the same dimensions of a regular switch. Am I crazy?
« Last Edit: Sat, 14 March 2020, 03:06:36 by lakeboredom »
Re: Where is the silent linear with 4mm of travel?
« Reply #1 on: Sat, 14 March 2020, 09:23:13 »
The bumpers have to be able to compress somewhat also.
I think that the listed key travel for these switches might be without compression.
Offline Polymer
« Reply #2 on: Sat, 14 March 2020, 18:47:24 »
Have you tried them?  There is a very slight difference but it shouldn't really matter in normal usage..
If the important part was keeping it at 4mm exactly then yes, what you're saying makes sense.  But I'm sure the idea was to keep as much of the identical parts the same while adding a different functionality while keeping the overall feel roughly the same..and they've succeeded.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #3 on: Sat, 14 March 2020, 21:25:57 »
Never heard of someone who wants that switch.
Just my thoughts
Offline Riverman
« Reply #4 on: Mon, 16 March 2020, 11:27:14 »
It sounds like the OP just wants a Cherry silent switch without the slightly reduced travel that the silent red and black switches have.  I've used both, and there is a very slight reduction in the travel (Cherry specifies 3.7mm), but in use, I have no issues with them.  The rubber bumpers on the sliders certainly reduce travel less than either o-rings or QMX Clips.  If you want a silent linear switch, they're both good options.
Offline 4sStylZ
« Reply #5 on: Tue, 17 March 2020, 09:46:33 »
White / cream dampened alps linearized ?
It's dampened on the two side, and if you want you can use the bottom housing / slider to make others alps hybrids.
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
