Author Topic: [IC] iNETT Studio:SQUARE.X 60% Keyboard (Review and Build Stream Added, GB Soon)  (Read 106271 times)
Offline Simen
Will the polished chamfer be available for every color? And is there any extra cost for that option?
It will only be available on black and there will be extra cost.
Offline J_Noes
would love a rose gold brass plate with a polycarb case.
Offline GhostEther
Is the GB still gonna happen in June?
Offline Simen
Most likely yes!
Offline CrazyAssMonkey
Most likely yes!
Is polycarbonate pricing the same as aluminium?
Offline shawnlin
Decent work! May I know, if brass plate is an option, will there be the same color options (e.g., black, red, dark green, blue, etc) as steel plates?
Offline Blvck.-
Def in for this looks great.
Offline swarp
Brass plate plz :'(
Offline nathanchere
I don't see it explicitly mentioned anywhere but is that a USB-C port I see? 😁
Offline York Chan
It definitely tells you the type-c interface :thumb:
Offline myflowsocold
Def in for the PC HHKB
Nunu | Lyn Whale R2 | Bauer | Satisfaction75 | WKL Polaris | TGR x Singa Unikorn
Offline thestateofmay
Will this come with PC plates?
Offline kanki0213
I want to buy PC bottom as an extra part
Offline StateSheriff
If you wanted a backspace in the top right instead of two 1u keys you'd have to go for the non-hotswap pcb right?
Offline catamscott
if you want the traditional 2u backspace then yes, you'll have to get the standard pcb
Offline Simen
Offline Simen
Pc plate is too soft will cause deformation, so we will not use Pc plate :thumb:
Offline Nvr_Smile
Maybe I missed it, but is this going to be a limited group buy or unlimited group buy?
Offline Simen
We haven’t started GB yet, but there’s no doubt we’ll be doing GB this month :thumb:
Offline Sabin
Love the design choices and would love be part of the gb! Is there a discord or are all updates on this thread? Thanks
EDIT: OK so stupid question, where is the backspace on the hotswap PCB?
« Last Edit: Sun, 07 June 2020, 13:12:06 by Sabin »
We havenâ€t started GB yet, but thereâ€s no doubt weâ€ll be doing GB this month :thumb:
You should be able to configure it how you please. It is a split backspace I believe so you can choose if you want it where it used to be or one row below on the 1.5u key.
Offline kidpid
Will there be a brass weight option?
« Last Edit: Sun, 07 June 2020, 20:42:55 by kidpid »
Offline Sabin
Oh right, I assumed because its the hotswap layout it would be fixed. Thanks
Offline KFOXE
Really interested in the white colorway. If you ever do future rounds would you consider adding a purple color?
Offline prizeS
    • TastyKeys
how would hotswap work with a configurable backspace? pretty sure it's split backspace for the hotswap as that's the layout listed
i lub 65% and wkl tkl.
Offline Aerizu
  • Professional Lurker
I think he meant that it is configurable in the sense that you can program the backspace into any position you like.
But the switch layout for the hotswap PCB is indeed fixed.
Offline prizeS
    • TastyKeys
ah yes yes. i see what he meant now. :)
Ahhh snap that’s right. I wasn’t clear enough, my bad. Thanks for clarifying <3.
Offline DomAndretti
I neeeeeed this. When is GB going live?
Offline huey
Please iron your shirt. It's making me crease.  :)
Offline potatokuka
Yes, yes, yes and YES! Will definitely be picking this up, thank you for having the HHKB layout!!
Offline konstantin
  • Formerly constexpr
TaeKeyboards posted a build video / review of a SQUARE.X prototype today:
And TaehaTypes is building another prototype on stream right now!
Offline ufoken
 can someone please tell me what keyset this is or something similar to this?
Offline FGLurker
EPBT Kuro/Shiro. The GB ended last month.
Offline shb
Can you get the HHKB layout with the hotswap PCB?
Offline syke
subbed
Offline konstantin
The hotswap layout is tsangan (7u space), so the answer is yes.
Offline isaiasr212
Interested in this depending on the price.
Offline EarlAsterisk
Really nice keyboard!
« Last Edit: Wed, 17 June 2020, 22:49:53 by EarlAsterisk »
Offline kanki0213
How about WKL lay-out? I think it is possible too
Offline NotYeMK
  • I will yeet your keyboard
Yep. I will be in for two of these. Just wish I can get all the variants.
Offline shawnlin
But for a hotswap pcb, how do you split the backspace into \ and `?
Offline konstantin
Yep, if you don't mind split backspace.
According to the OP, it's already split:
Hot-swap PCB layout:
Offline jonowarren94
Finally an ISO 60% PC board!
Colour me interested
Offline adamjohari
Will the USB-C cutout be made in the shape of a USB C port? Think Nathan (Taeha Types) mentioned that he was bothered that it was a square cut in the prototype.
After | KBD8X Mk2 | Prophet | Ducky One 2 Mini
GMK Laser | ePBT Kon MoMo | Infinikey Port | Sanctuary Rebirth PBT | GMK Deep Navy
Offline neutralstate
I'm actually more concerned that there was a need to use masking tape to reduce rattle of the plate! Would that be addressed?
Offline Simen
Unfortunately we can't change the design anymore at this point. However, the cutout is very snugged and you can't really see the cutout once a cable is plugged in.
Offline Simen
Yes, we have fixed the design so that won't happen on production units.
Offline Simen
Hey everyone! Latest update on the first post, GB coming up soon!
Hey would it be possible to show a video of the final prototype just so we can take a look at what the product we would be receiving would look like? For example with the fixed plate issues and such?
Thanks
