Author Topic: [IC] iNETT Studio:SQUARE.X 60% Keyboard (Review and Build Stream Added, GB Soon)  (Read 105173 times)
Offline Simen
Re: [IC] iNETT Studio:SQUARE 'X' 60% keyboard
« Reply #50 on: Fri, 20 March 2020, 02:32:40 »
Well this definitely has my attention. Looking great so far!
Thanks!  ;)
Offline Boy_314
« Reply #51 on: Sat, 21 March 2020, 14:26:42 »
Filled out the form  :thumb:
Offline AIRPOTTER
  • Owner of Gray Studio
« Reply #52 on: Sat, 21 March 2020, 21:59:24 »
Great design,man,really nice job!
Offline Simen
« Reply #53 on: Sun, 22 March 2020, 03:01:16 »
Thanks Gray. :thumb:
Offline MooGoesTheToast
« Reply #54 on: Sun, 22 March 2020, 11:00:14 »
I looooooove this. :D I am stuck between the white or black case with the botanical keycaps. any suggestions?
Offline Simen
« Reply #55 on: Wed, 25 March 2020, 20:15:24 »
I think a PC case and green/white plate would match pretty well :thumb:
Offline pchoi
« Reply #56 on: Wed, 25 March 2020, 20:39:56 »
238393-0
Is there any way you can make this yellow part of the HHKB layout matte/clear like the rest of the keyboard?
Offline Simen
« Reply #57 on: Thu, 26 March 2020, 19:39:21 »
Unfortunately that's not possible. The yellow parts are part of the plate that are extruding out to serve as the HHKB blockers.
Offline gnhuy91
« Reply #58 on: Thu, 26 March 2020, 20:24:07 »
Would you be offering PC plate? that'd be interesting
Offline pchoi
« Reply #59 on: Thu, 26 March 2020, 20:26:11 »
This^
Offline Simen
« Reply #60 on: Sun, 29 March 2020, 01:25:05 »
This^
PC plate will not be offered because it's too soft to be milled
Offline Eipplepod
« Reply #61 on: Sun, 29 March 2020, 13:35:44 »
Side view:
Will this be available only with the yellow or just in black too?
Offline ywcsam
« Reply #62 on: Sun, 29 March 2020, 19:23:29 »
Side view:
Not exactly sure what you are asking. If you are asking about the side cutouts, they will show the color of the plate.
Offline Eipplepod
« Reply #63 on: Sun, 29 March 2020, 20:05:24 »
Side view:
The one in the back on this picture is completely black, the one in the front is yellow/black, viewed from the top. Is the yellow coming from the plate? And will it be available in all black? Maybe i missed something in your original post and im sorry if i did.
Gesendet von iPhone mit Tapatalk
Offline Simen
« Reply #64 on: Sun, 29 March 2020, 23:26:05 »
Side view:
Yes, all the yellow in that keyboard is part of the plate. The plate is available in multiple colors  ;)
Offline lenznel
« Reply #65 on: Mon, 30 March 2020, 00:54:04 »
Excited to see sum WKL Renders ;D
Offline ElKapitain
« Reply #66 on: Wed, 15 April 2020, 15:41:38 »
I'll pull the trigger on a black and yellow for sure  :p
Offline BigBabyJesus
« Reply #67 on: Thu, 16 April 2020, 05:40:25 »
Oh my! I'm interested.
Offline York Chan
« Reply #68 on: Thu, 16 April 2020, 09:44:46 »
Instagram:iNETT Studio [ Follow me to see the latest designs ]
Hello GeekHackers, this is Simen from iNETT STUDIO. Before introducing the new keyboard, I want to apologize to the buyers who joined the SQUARE 80 GB for not delivering the product on time. As a token of apology, people who joined the SQUARE 80 GB will receive a small gift when you join this group buy of SQUARE.X 60.
Introduction:
This time we will be bringing you the "X" in the SQUARE series by iNETT STUDIO. The SQUARE series share some very defining characteristics. We spent a lot of time to refine the design of SQUARE.X 60 so that it stands out as a unique product, yet similar enough to be recognized as one of the SQUAREs. We started designing this keyboard since October 2019. After countless modifications and revisions, we came up with three versions of the keyboard before finally deciding on the current design which we are very satisfied with. To achieve a more unique appearance, we will be adjusting some details such as implementing thinner side cutouts, narrower side bezels, and a slightly taller forehead.
We are very glad to see that users are paying more attention to the typing feel rather than focusing solely on the appearance of the keyboard. The 4mm thick plate that was used in other SQUARE series will be reduced to 1.5mm, with half plate as an option. SQUARE.X 60 will also be the first in the series to adopt the gasket-mount system. The left and right side of the plate are held in place by the upper and lower cases, whereas the top and bottom of the plate are suspended and supported by rubber strip gaskets that can reduce vibration. Thanks to Luis from iLumkb, we gained valuable insights on utilizing gaskets. We will be testing gaskets of different harnesses for the perfect typing feel once the prototype is made.
If you are interested with SQUARE.X , please take 1 minute to fill IC Form
Features:
  • Mounting Method: Gasket (Hardness to be determined)
  • Layout: WKL, WK, HHKB
  • Type Angle: 7 Degree
  • PCB: Type-C, QMK Programmable, Per Key RGB, Underglow (designed and supported by astro)
Case color:
  • Anodized color:black, blue, red, dark green
  • E-color:white
Plate color:
  • Anodized color:black, red, dark green, blue
  • E-color:white、yellow
Layout:
Top View:
Side view:
Structure and Details:
(LEDs for underglow will come pre-installed, but they are not shown in these images. Underglow will only show with PC bottom)
With 1.5mm full plate
With 1.5mm half plate
PCB:
Color Options:
PC Version:
Polished Chamfer Renders:
The last unique feature of the SQUARE.X 60 is the option to add Polished Chamfer to bring more elegance to the keyboard. Personally, I think this is the highlight of the keyboard which requires delicate manufacturing. This kind of chamfer is not very common in realm of keyboards, and we will show case this more once the prototype is made. I am sure you would love this feature as much as I do!
So much for the rendering, stay tuned for photos of the prototype!
Q&A:
  • Q1: Hot-swap PCB?
    A1: Still under consideration, but unlikely. Due multiple layouts, it’s hard to accommodate everyone with hot-swap. The thinner 1.5mm plate may also influence the typing feel when used with hot-swap.
  • Q2: Lead time?
    A2: Maybe 3-5 months after the GB has ended. Due to coronavirus and the complex design of this keyboard, we don’t have an exact answer at this time.
  • Q3: When can we see a prototype? And the price?
    A3: The prototype is being manufactured and we are expecting it by the end of the month, possibly sooner. The price is $350 before PayPal fees and shipping.
  • Q4: Limited group buy?
    A4: Limited by time but not limited by quantity. All available options will be shared before the GB.
  • Q5: Brass plate and weight?
    A5: There will be a survey question for this. Let us know if you want this as an option and we will consider adding them if there is enough interest.
Closing:
iNETT STUDIO has been around for more than a year now, thank you for all your support over the past year! We will continue to improve and refine our workmanship to make better keyboards, and we will gladly hear your comments and suggestions. Feel free to comment below or contact us at inett.studio@gmail.com.
Last but not least, may all of you have a good health during this coronavirus pandemic and good luck in the year of rat!
Peace & Love,
Simen
Stay tuned for the figure image and the sound test.
Good work!! :thumb:
Offline BMLN
« Reply #69 on: Thu, 16 April 2020, 15:00:04 »
I saw some pictures of a 65% variant, is that one coming aswell?
Offline JvMil
« Reply #70 on: Thu, 16 April 2020, 18:30:32 »
Definitely interested in the PC version, going to keep an eye out for this board. Good work!
Offline Simen
« Reply #71 on: Thu, 23 April 2020, 07:20:38 »
The Square 68 GB only in China. :D :D
Offline BMLN
« Reply #72 on: Thu, 23 April 2020, 07:46:00 »
My heart </3
Offline Simen
« Reply #73 on: Sat, 02 May 2020, 23:11:22 »
5/2/2020 Updates added on the first post  :)
Offline catamscott
wow, prototypes look really great! feels like a hard choice between aluminum and pc, but that subtle polished chamfer is looking to nice too pass on :p can't wait for the gb!
« Last Edit: Sun, 03 May 2020, 01:40:24 by catamscott »
Offline byomes
beautiful stuff. I'm def in for one!
Offline junwon9710
Looks good. def looking forward to join! Will there be an option for hotswap pcb for wkl as well?! Is there estimated date for groupbuy? can't wait!
Offline neutralstate
very interested! will the groupbuy be carried out through vendors ? Perhaps iLumKB as you named dropped louis in the original post?
Offline Solotov
« Reply #78 on: Sun, 03 May 2020, 10:26:53 »
May I ask what went wrong with the gasket mount that you tried?
Flex is love, flex is life.
Offline swarp
No brass plate? Oh no :'(
Offline Simen
Yes, the hotswap PCB works for WK/WKL/HHKB plate. Don't have a set date for GB yet, but looking like late May for the GB for now.
Offline Simen
« Reply #81 on: Sun, 03 May 2020, 16:52:30 »
The gaskets basically make no contribution to the typing feel due to the way that the keyboard is structured.
Offline Romutulus
I love that orange/yellow color.
how programmable will the pcbs be?
Any support for VIA, that would be amazing
Offline asciisii
The PC + yellow plate looks absolutely goddamn stunning
Offline enjoidis
I love this! Do you think you might add Grey ano to the color choice? A grey/yellow would be perfect for me.  :thumb:
Offline Simen
Maybe there will be =)
Offline Simen
Unfortunately gray does not have enough demand to justify the cost for adding another color. Black + Yellow is my favorite XD
Offline Simen
yep!
Offline jurisitum
How is the weight for those prototypes?
Offline GhostEther
I'm interested.
Love the design, this will look great in HHKB white!
Offline yarlah
Will the hot swap pcb have per key and underglow rgb?
Sent from my SM-N960F using Tapatalk
« Last Edit: Mon, 11 May 2020, 16:26:11 by yarlah »
Offline Yehuo.
I heard from my friends that China ’s GB is over. I really like this design. Damn, when will GH be turned on :thumb:
Offline bakerozee
Interesting for sure :) I will have to follow this one.
"more the knowledge lesser the ego, lesser the knowledge more the ego..." Albert Einstein
Offline Simen
We will make a GB in June :thumb:
Offline Simen
I'm interested.
Thanks :D
Offline Simen
Yes,both PCBs have. :thumb:
Offline Learis
Do you have to solder anything if you choose the hotswap model?
Also, are there any videos showing what other iNETT SQUARE keyboards sound like? I couldn't find any on youtube.
Mend and Defend
Offline duckunz
Will the polished chamfer be available for every color? And is there any extra cost for that option?
Offline Simen
You won't have to solder anything if you pick hot-swap. Would defeat the purpose of hot-swap otherwise =)
Kiyoboard has quite a few videos on the Sqaure 80. https://www.youtube.com/channel/UCK9SgFbH2FrCJxX6LdG03Pw/videos
