Author Topic: QMK malfunction, need advice please.  (Read 1650 times)
Offline typo
« on: Sun, 22 March 2020, 07:08:07 »
HI, After a lot of trial and error I figured out that QMK communicates with my Korean 65% as one of the KBDFANS microcontrollers. I am sure this is not the issue. All I wish to do is change the static color of the LED's. So, I build a JSON file. I download it to the board. Success. Nothing has changed on the board! I have tried it 25+ times to no avail. What could be going wrong? Is there some other application I might be able to use? I suppose it would have to support that KBDFANS microcontroller as well. Thank you
Offline typo
Re: QMK malfunction, need advice please.
« Reply #1 on: Mon, 23 March 2020, 12:15:18 »
Can anyone try to help me? I am a C# coder myself and can't figure it out. Perhaps that is why no one responded? Darnit! I mean for what I spent I would at least like to change the color!
Offline walie
« Reply #2 on: Mon, 23 March 2020, 16:58:29 »
Maybe ask KBDFans for help. They have a Discord.
Or Drop.
Offline typo
« Reply #3 on: Tue, 24 March 2020, 00:01:22 »
Thank you walie. That was nice of you. Ill ask Drop as they have a forum.
