Author Topic: [IC] GMK ██████████ REDACTED | Final Kits Announced | Groupbuy starts May 6th  (Read 76446 times)
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
INTRODUCING GMK REDACTED
INTEREST CHECK FOR ██████████
SUBJECT: GMK KEYCAP SET █████████
CONTACT FORM: RESPONSE MANDATORY
Please fill out the form if you are interested in this set and to give some feedback on this set.
You are being assigned to a highly classified case that began in July of the year 2019. ██████████████████████████
Certain parts of this document
have been redacted because some of the information is above your clearance level. The main information you need to know to get the job done
is that this set will be use doubleshot legends with pad printed redactions on top of the doubleshot legends.
GMK stock colors will be used.
One advantage of a project that has this much information redacted, is that it can cover nearly every sized
keyboard layout in the base kit
. Each redaction was carefully chosen so that the correct amount of each sized
keys on each row
that are needed for more obscure layouts, which are usually not covered in base kits. In the image below,
you will find a list of how many of each key are redacted on each row. This is based on our Obscure kits we usually run. So there should be
the same coverage that the Obscure kit gives from our past groupbuys. ███████████████████████████████████████
There will also be a novelties kit that will include all the top level pattents you need to make sure your build is truly secure from any leaks.
The bars is kit is just that. Bars.
1. Dixie Mech will run the GMK REDACTED groupbuy from May 6 to June 2, 2020.
Proxies include:
Dixie Mech for NA
Oblotzky Industries for EU
Daily Clack for AU
iLumKB for Asia
zFrontier for China
The prices will be ██████, ██████, and ██████.
██████████████ is ███████████████████ according to █████████████
2. The project includes ██████, ██████, and ██████.
3. Three kits will be included: Clearance, Classified, Bars, and Eyes Only.
4. Stock GMK Colors. 2M Base and N9 legend with Double CR pad print.
The REDACTIONS will be pad printed over the double shot legends. We have gotten samples from GMK and they are really cool.
They sent us a version with one layer of pad print and one with double pad print.
The single pad print has nearly no difference in texture from the regular cap, yet you can slightly see the legend showing through.
The double pad printed is lifted a tiny bit where you can feel the edge of the print if you rub your finger back and forth on it.
But the legend beneath is completely covered.
I have spent a few weeks with both of these options on the E and R keys of my board and to be honest, I really cant tell a difference
in them when I am just in the rhythm of typing. My wife has also typed on them for a while and I asked her if she could tell the difference,
and she couldn't either. The redactions are not placed on the main keys most people rest on so I believe the double would be okay.
The double will succeed in the theme of this set the best.
AUTHORIZED PERSONNEL ONLY
5. Combo mod legends (text +icon).
UPDATED KITS
CLEARANCE KIT
You will need this kit to have clearance to be allowed to use the other kits available.
CLASSIFIED KIT
This kit will allow you to classify information as you see fit.
BARS KIT
EYES ONLY KIT
COMPATIBILITY OF THE CLEARANCE AND EYES ONLY KITS
SPREADSHEET
RAMA X ███████
Aluminum E-White w/ Black Enamel Fill
Silcone Swirl Gray and White
DESKMATS
REDACTED MEKA MATS
ORIGINAL KITS AND IMAGES
█████████ KITS
CLEARANCE KIT
CLASSIFIED KIT
BARS KIT
GMK REDACTED
ON █████████ by D███ M██.
GMK REDACTED
ON HCBP BY hiney
GMK REDACTED
ON NO. 2 REV. 1 BY KEYCULT.
« Last Edit: Mon, 04 May 2020, 18:11:11 by GarrettSucks »
Offline jmsp0511
Re: [IC] GMK ██████████
« Reply #1 on: Wed, 01 April 2020, 08:51:49 »
Interesting concept
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #2 on: Wed, 01 April 2020, 08:54:00 »
If I had a set with Dixie mods, I would have redacted them too.
#JusticeForEmir
Offline Evilocity
« Reply #3 on: Wed, 01 April 2020, 08:55:14 »
I love it! Very unique!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #4 on: Wed, 01 April 2020, 08:55:47 »
My feedback is to include a dixie mod kit and scribble over them
Offline self
« Reply #5 on: Wed, 01 April 2020, 08:56:53 »
 i hope this is not a joke
Sent from my ONEPLUS A5010 using Tapatalk
Offline Zambumon
    • Keyset projects
« Reply #6 on: Wed, 01 April 2020, 08:57:03 »
Stop trolling Emir.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #7 on: Wed, 01 April 2020, 08:59:09 »
Stop trolling Emir.
ngl the overall idea is pretty sick and creative, I would be interested
ne og icon mods avail
Offline Visionaire
« Reply #8 on: Wed, 01 April 2020, 09:01:35 »
Minvan support. Instacop.
Offline Gondolindrim
    • My GitHub
« Reply #9 on: Wed, 01 April 2020, 09:05:12 »
What the actual **** is going on
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline Aiwanei
    • ThocKeys.com
« Reply #10 on: Wed, 01 April 2020, 09:05:54 »
I like the 75% Bauer Stealth Leak
ThocKeys.com
Offline mrpetrov
« Reply #11 on: Wed, 01 April 2020, 09:06:20 »
Actually ****ing amazing. Amazing amazing. Every lawyer globally will want this.
Offline Dr_Bond
« Reply #12 on: Wed, 01 April 2020, 09:07:10 »
love this set, so creative
if this is an april fools set I will sharpie my minimal set to achieve the same greatness
TGR Alice | TGR Matrix 8x V2.0 | Iron165 FE | Prophet
Offline tominabox1
« Reply #13 on: Wed, 01 April 2020, 09:14:33 »
recommend red and green accents for SECRET and UNCLASSIFIED
Offline heyjaykay
« Reply #14 on: Wed, 01 April 2020, 09:25:06 »
ngl the CLASSIFIED Kit is pretty dope
Offline jaspertandy
« Reply #15 on: Wed, 01 April 2020, 09:32:03 »
I am absolutely in for this.
Offline Jaltr
« Reply #16 on: Wed, 01 April 2020, 09:41:14 »
I love this. Want every kit, please .
Offline nasp
« Reply #17 on: Wed, 01 April 2020, 09:45:52 »
Any Sharpie novelty avail??
Offline eniigma
    • Storefront:
« Reply #18 on: Wed, 01 April 2020, 09:46:30 »
If you can make this happen, I am ██. However, my only feedback is to ██████ the ████████. Other than that, ████ ███, and ████ ███  :thumb:
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #19 on: Wed, 01 April 2020, 09:49:32 »
Hold up, this is actually a genuinely good idea.
Offline carlouws
« Reply #20 on: Wed, 01 April 2020, 09:50:17 »
Yes. I want this.
Offline amarotea
« Reply #21 on: Wed, 01 April 2020, 09:55:48 »
This is really clever—in the best possible way.
Offline hughtrue
« Reply #22 on: Wed, 01 April 2020, 10:03:23 »
I gave up clicking those spoiled. LMAO
Sent from my Pixel 4 using Tapatalk
Offline mgsickler
« Reply #23 on: Wed, 01 April 2020, 10:04:22 »
Can't tell if this is real or not. But I actually love it.
Offline eniigma
    • Storefront:
« Reply #24 on: Wed, 01 April 2020, 10:06:15 »
https://i.imgur.com/kr2XtXx.jpg
Dixie has samples btw
Offline eniigma
    • Storefront:
« Reply #25 on: Wed, 01 April 2020, 10:06:29 »
Is this running through novelkeys?
Offline Pach
« Reply #26 on: Wed, 01 April 2020, 10:08:12 »
you would actually save a lot of money if you added the redactions with sharpie
Offline MadsMe
« Reply #27 on: Wed, 01 April 2020, 10:09:46 »
I didn't spot that the first time around. Thats pretty sick!
Offline clasicks
  • Formerly KeyboardUser4
« Reply #28 on: Wed, 01 April 2020, 10:13:14 »
NGL would hit MOQ - pretty hot
Offline Jaltr
« Reply #29 on: Wed, 01 April 2020, 10:13:55 »
Hey Dixie, are the spacebar going to have the size written on em? 1u, 2.25u, etc?
Offline Nim
« Reply #30 on: Wed, 01 April 2020, 10:18:00 »
I don't even like GMK profile caps, but I need this to be real
« Reply #31 on: Wed, 01 April 2020, 10:21:02 »
this isn't even what real redactions look like
    • Omnitype
« Reply #32 on: Wed, 01 April 2020, 10:24:01 »
GET REDACTED
Offline jbrandona119
« Reply #33 on: Wed, 01 April 2020, 10:28:17 »
Absolutely love this.
I will definitely be buying it!
Offline Lil
    • designedbydark
« Reply #34 on: Wed, 01 April 2020, 10:30:18 »
Finally someone redacted puddsy
Offline Sunhwan Jeong
« Reply #35 on: Wed, 01 April 2020, 10:33:29 »
I guess this is a teaser for New Bauer 75
Offline hkiri
« Reply #36 on: Wed, 01 April 2020, 10:41:33 »
Seriously, this is awesome! Please make it happen!
Offline wholypantalones
  • text and icon mods plz.
« Reply #37 on: Wed, 01 April 2020, 10:45:41 »
Couldn't one just purchase a WoB GMK set and give the kids a sharpie instead?
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #38 on: Wed, 01 April 2020, 10:51:59 »
if this is real, i actually want it :D
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Darthbaggins
  • PC Cannibal
« Reply #39 on: Wed, 01 April 2020, 10:58:56 »
IC Has been █████████.
I can't wait to see what the Rama cap will look like.
Offline JamesHereford
« Reply #40 on: Wed, 01 April 2020, 11:07:15 »
Love it! Would absolutely be interested. What was the inspiration on redacting 7 in the number row, or was it random?
Just an idea, redacting the 2 would better support NorDeUK which might use " instead of @ as the modifier, so it would be more universally applicable but I suppose it might look too clustered next to the W and E...
Other than that, ███████!
Offline Audiobs
« Reply #41 on: Wed, 01 April 2020, 11:08:47 »
Can you just sell the set with a free Sharpie? Each set will be unique if we can do it ourselves, and we can do it overtime too!  ;D
Offline fatboycarney
« Reply #42 on: Wed, 01 April 2020, 11:17:44 »
These April fools IC posts end up being so good, to smart, I'd be in  :thumb: And this is all top secret from Canada so  :cool:
Offline Darknight00z
« Reply #43 on: Wed, 01 April 2020, 11:24:13 »
No 10u spacebar, no buy
Offline pngu
  • send noots
« Reply #44 on: Wed, 01 April 2020, 11:25:40 »
Any chance this could get a redacted international (NorDeUk+x?) kit? You could call it OSINT kit, $69 to my paypal for the idea please.
This set lends itself towards that because it wouldn't have to be as big as it would be in regular sets.
Offline bigapplepietart
  • Topre Convert
« Reply #45 on: Wed, 01 April 2020, 11:28:02 »
Super cool, but wonder if it will stick around after the first, or get REDACTED.
Current:
Heavy Grail (Purple DES V1) | hiney tkl one PC (Orange SKCM Alps) | Lunar II (Green SKCL Alps) | Sho S60 V2 (Purple DES V1) | HHKB Hybrid Type-S (45g Stock Domes)
Past:
Razer Blackwidow (MX Blues) | FC660M (MX Blues) | GH60 (Ergo Clears) | 8x mkI (Vintage Blacks) | Klippe (Sakurios) | Equinox (Sakurios) | MGA (Silent Alpacas) | Kei (Creamsicles) | KFE CE (Alpacas) | Rukia R1 (Durock L7) | H60 (Silent Blacks) | E80-1800 (MX Blacks) | Ottantaquattro (Vintage Blacks) | hbcp (Vintage Blacks) | HHKB Pro 2 (45g Aged Domes) | ADK64 (Blue SKCM Alps) | Palmetto (Ultraglides)
Offline Jampot_298
« Reply #46 on: Wed, 01 April 2020, 11:39:25 »
I second this!
Offline aodaliya1234
« Reply #47 on: Wed, 01 April 2020, 11:39:53 »
Dots was also April fools.. wonder if this will blow up same as dots
Offline brln
« Reply #48 on: Wed, 01 April 2020, 11:48:40 »
will buy if the cap sizes are scribbled on them as presented in the clearance kit
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #49 on: Wed, 01 April 2020, 12:05:37 »
nice gmk minimal
