Author Topic: realforce 87u broken backspace key need help  (Read 2623 times)
Offline rf86u
« on: Wed, 01 April 2020, 23:07:55 »
my backspace key broke, guess I didn't pull it gentle enough. I can't find any replacement key, I can use glue to fix it.
What else would I do? the best is to get a original backspace key, or aftermarket pbt backspace key
« Last Edit: Wed, 01 April 2020, 23:24:02 by rf86u »
Offline nmur
  • ಠ_ಠ
Re: realforce 87u broken backspace key need help
« Reply #1 on: Wed, 01 April 2020, 23:08:24 »
photos?
Offline rf86u
« Reply #2 on: Wed, 01 April 2020, 23:21:29 »
Offline nmur
  • ಠ_ಠ
« Reply #3 on: Wed, 01 April 2020, 23:31:09 »
cheapest way would be to attempt to superglue. would be difficult to get the position correct enough that it would click on and hold on to the slider.
another way would be to get an aftermarket set, just for the backspace (eg from https://kbdfans.com/collections/electrostatic-capacitive-keycaps).
the oem way would be to buy a topre realforce set, however they only come in colours, and are discontinued, so they're rare and expensive.
Offline rf86u
« Reply #4 on: Wed, 01 April 2020, 23:43:32 »
for $120 I can get a used realforce 87u with some rust spot. go for that?
Offline nmur
  • ಠ_ಠ
« Reply #5 on: Wed, 01 April 2020, 23:51:20 »
if you're prepared to pay that, sure
rusted plates can be fixed too if you're handy
Offline rf86u
« Reply #6 on: Wed, 01 April 2020, 23:56:05 »
please advise on how to fix rust spots, thank you!
Offline nmur
  • ಠ_ಠ
« Reply #7 on: Wed, 01 April 2020, 23:58:33 »
https://geekhack.org/index.php?topic=96389.msg2630371#msg2630371
tl;dr, completely disassemble, sand plate until rust is gone, and spray paint a few coats.
Offline rf86u
« Reply #8 on: Thu, 02 April 2020, 00:18:51 »
I tried when I lubed my boards. very difficult to remove the key housing from the plate, how did you do that?
Offline nmur
  • ಠ_ಠ
« Reply #9 on: Thu, 02 April 2020, 00:22:02 »
it's been a while but i'm pretty sure you just have to push on the left/right side, then the other side. takes a bit of force
