Author Topic: [IC] Infinikey: PBT Islander - GB May 15 to 29 Deskmats added  (Read 165675 times)
Offline grundlemere
Re: [IC] Infinikey: PBT Islander
« Reply #100 on: Fri, 01 May 2020, 15:39:11 »
GB NOW
Offline Abec13
Re: [IC] Infinikey: PBT Islander - GB May 15
« Reply #101 on: Sat, 02 May 2020, 14:15:02 »
Hello everyone, update for you.
This group buy will be running on May 15 to May 29. Yes. 13 Days from today.
I bring a few changes to refine the kits. Deskmats are in the works.
All changes are reflected in the renders on the main post.
Thank you for your support.
List o' Changes
The leaf, bag, and fossil have been modified to be less IP heavy.
225 Fishing rod novelty has been sized to fit a 1.5 novelty now.
A variation of fishing novelties has been added to 1.5 and is mirrored across the sides.
1.25 Fishing novelty has also been mirrored.
Added blue 1.25 Shift to Extension Kit for 40s users who will use this on the right side.
Added green 1.75 Shift for 40s users to use on the left side.
Added blue 1.00 Shift to Extension kit for Minivan users that will use this on the right side.
Changed blue 2u Shift to green as this is actually used on the left side.
Added brown accented leaf to novelties for 40s users to use as an escape novelty.
Added blue tilde-grave.
Added blue and green (whatever the name of that) ISO key.
Moved accent arrows and numpad enter to add on kit.
Removed 1.5u "Function" keys from Add On kit, as there is already a 1.5u Alt and Fn in Base Kit.
Centered icons.
Canadian Proxy Added: Deskhero
Art Caps
For this set I will be working with:
CYSM: https://www.instagram.com/cysm_caps/
Alpha Keys: https://www.instagram.com/alphakeycaps/
Archetype: https://www.instagram.com/archetype_mk/
« Last Edit: Mon, 11 May 2020, 16:15:13 by Abec13 »
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline rewke
« Reply #102 on: Sat, 02 May 2020, 14:20:21 »
GB in two weeks? Heck yes.
Offline //gainsborough
  • MATRIXの日常
« Reply #103 on: Sat, 02 May 2020, 14:55:36 »
YOOO!  BEST NEWS!  How the heck did you get this to GB so fast?!
Offline Abec13
« Reply #104 on: Sat, 02 May 2020, 21:04:22 »
Connections ;)
[/url]
Offline PikaJoyce
« Reply #105 on: Sat, 02 May 2020, 21:13:04 »
-What are the RAL or Pantone colors codes you are using? And, more specifically, what colors are you color-matching for the blue, green, and brown?
Any answer for this?
Mostly worried about getting a set with colors that didn't look anything like the renders.
edit : Would you consider getting samples as well?
« Last Edit: Sat, 02 May 2020, 21:15:52 by PikaJoyce »
Offline EpictheHamster
« Reply #106 on: Sat, 02 May 2020, 23:18:30 »
Are these dye-sub or laser etched? laser etched wont last as long and i hope these will last me a while if i buy them. Otherwise Terrific Job! These look amazing!
Offline kbye
« Reply #107 on: Sat, 02 May 2020, 23:43:51 »
Offline Abec13
« Reply #108 on: Sun, 03 May 2020, 01:52:47 »
PBT Dye Sub!
[/url]
Offline midnatwili
« Reply #109 on: Sun, 03 May 2020, 07:49:06 »
 I AM SO READY FOR THIS!!!!!
Offline NeroGrave
« Reply #110 on: Sun, 03 May 2020, 11:19:15 »
How long will this GB run for?
Offline kamisamamizu
« Reply #111 on: Sun, 03 May 2020, 11:50:48 »
Shame about the changed novelties, but I like seeing 1.5u ones. Seemed strange only one shift had a novelty.
Still no ISO novelty, but oh well.
Hyped as f for it.
Offline zabblleon
« Reply #112 on: Sun, 03 May 2020, 13:40:25 »
Unfortunate there's no non-brown option for the modifiers. Might still be a pickup though, don't see anyone else doing the NH colorway in the future.
Offline BreadBanana
« Reply #113 on: Sun, 03 May 2020, 16:22:26 »
Can't wait to buy the set! it's unfortunate that you can't keep the original design of the leaf, bells and fossils definitely buying day 1 tho!
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #114 on: Sun, 03 May 2020, 16:43:49 »
I hope we can see some samples in the future! Love the colors and hope that they come out well!!
(credits to Kokaloo)
Offline Abec13
« Reply #115 on: Sun, 03 May 2020, 17:49:24 »
Til June 15. Will update.
[/url]
Offline dibkib
« Reply #116 on: Mon, 04 May 2020, 02:37:15 »
Argh, I wasn't expecting the GB so soon and won't have time to budget for it. Shame, but I'm excited to see what it looks like on people's boards!
Offline Tyson
« Reply #117 on: Mon, 04 May 2020, 09:56:09 »
Looks like this will be my first PBT set in 2 years. Glad this set was so fleshed out that you were able to hit the ground running and get a GB date really quick! Can't wait to see the set in person! :D
Offline vinyldoodles
« Reply #118 on: Mon, 04 May 2020, 10:51:50 »
Sorry if this is mentioned elsewhere in the thread, but what profile are these?
Can't wait for the GB. My poor wallet is not enjoying this month.
Offline Tyson
« Reply #119 on: Mon, 04 May 2020, 10:59:39 »
These are going to be cherry profile.
Offline PikaJoyce
« Reply #120 on: Tue, 05 May 2020, 02:22:32 »
+1
Would be totally in if we can see samples and color codes!
Offline dennis.limbo
« Reply #121 on: Tue, 05 May 2020, 05:16:39 »
These look great! Let's hope the colors turn out great.
Offline frasnow
« Reply #122 on: Tue, 05 May 2020, 14:35:08 »
We need samples pictured next to an Animal Crossing Switch. I'm sure OP wouldn't mind if somebody sent one.  ;D
Offline BreadBanana
« Reply #123 on: Thu, 07 May 2020, 19:20:49 »
From what I read Gok sent you the files for the 7V render is it possible to render this set with the 7V in E-white? since I'm getting the 7V and your set, it would be awesome!
Offline chowder266
« Reply #124 on: Sun, 10 May 2020, 20:25:58 »
possible rama collab?
Offline frostrambler
« Reply #125 on: Tue, 12 May 2020, 13:30:45 »
Trying to figure out, does the base or expansion come with a 2U right shift key? The base keys aren't labeled with sizes so I am not sure. Trying to see if I can get it to fit my ducky one 2 SF that uses a 2u right Shift.
Offline frasnow
« Reply #126 on: Tue, 12 May 2020, 15:42:36 »
The Key Company site has the sizes in the screenshots at https://thekey.company/collections/group-buys/products/infinikey-pbt-islander. You'll need the expansion kit for the 2u right shift.
I also note The Key Company still has some images with the older version of the leaf that had some questionable IP issues. Hopefully, those images won't upset a certain company.
Offline bakuretsu
« Reply #127 on: Tue, 12 May 2020, 23:32:51 »
Um.
The 2u shift in the expansion kit is a left shift. It's green. I think frostrambler might be out of luck.
Offline Dristan
« Reply #128 on: Wed, 13 May 2020, 02:32:38 »
These are incredible but god I need them in DSA. I just can't use cherry profile. Any chance of a followup run?
Offline DNWMN
« Reply #129 on: Wed, 13 May 2020, 13:46:22 »
since all ive been doing is playing animal crossing.... this would be perfect
Offline Rilow
« Reply #130 on: Wed, 13 May 2020, 16:39:00 »
No EU vendor?
Offline pixelpusher
Re: [IC] Infinikey: PBT Islander - GB May 15 to 29
« Reply #131 on: Wed, 13 May 2020, 22:53:08 »
I dont have a ton of hours on AC yet (just finished paying off my home loan and got the store built), so maybe I just haven't come across this yet.  What is this supposed to be?:
  • MATRIXの日常
« Reply #132 on: Wed, 13 May 2020, 23:00:49 »
it's fish looking at a fishing lure
Offline pixelpusher
« Reply #133 on: Wed, 13 May 2020, 23:18:17 »
Ah!  I see it now!  Thanks
Offline pixelpusher
« Reply #134 on: Wed, 13 May 2020, 23:31:06 »
Hey, any chance we can have an addon pack that has like 150 goddamn bunny day egg caps?  Like maybe 150 3u caps?  Seems fitting.
« Last Edit: Thu, 14 May 2020, 08:09:05 by pixelpusher »
Offline gecruz
« Reply #135 on: Thu, 14 May 2020, 00:37:57 »
I'm undecided since now I'd have to buy another kit just for the accent arrows  :-\
Offline Pizza_on_Pineapple
« Reply #136 on: Thu, 14 May 2020, 02:10:24 »
Offline Rilow
« Reply #137 on: Thu, 14 May 2020, 09:39:43 »
No EU vendor?
Prototypist.net
Prototypist is UK. If these doesn't ship until next year and there's a hard Brexit, Europeans have to pay import taxes.
Offline konstantin
  • Formerly constexpr
« Reply #138 on: Thu, 14 May 2020, 10:04:09 »
Someone had similar concerns about GMK Bleached. Here is what Jae had to say:
Proto[Typist] is acting as lead vendor on this one, doing the negotiating with GMK etc and running the GB with the designer after talking about the project at a UK meetup and is effectively a UK community project.
I understand the concerns, and GMK timelines still show the set shipping in October. From delivery to buyer shipping turnaround will be 1 day, so its highly likely that shipping will occur in 2020 and we will be working with GMK to achieve that.
Whilst you are right that we dont know the UK's position within the EU and any shipping / VAT or other constraints in 2021, there are contingency plans in place to ensure that shipping can be conducted without inference of additional fees should delivery of the GMK sets take place in 2021.
Also, VAT will be paid on these items at point of sale where it is due; and will be marked as such when shipped if any delays push the delivery into 2021. The GB takes place as an EU transaction at the moment and is bound by the single market and customs union rules. Those rules state that goods sold under them should only be inclusive of VAT once. There will be many many businesses that sell something in 2020 that ships and is delivered after the changes take place; and both the EU and UK have said that those customers should not be impacted.
Finally, its highly likely that the current end-date of Dec 2020 for the UK to formally leave the EU trade agreements will be extended given the impact the Corona Virus has had on the economy and this is something myself and my accountant are paying close attention to.
Offline Abec13
« Reply #139 on: Thu, 14 May 2020, 12:06:53 »
Deskmats have been added! Group buy begins tomorrow!
Deskmats
Islander Hopper Mat
Investors Mat (blue)
Investors Mat (green)
[/url]
« Reply #140 on: Thu, 14 May 2020, 12:16:25 »
I love those mats!
Offline dallman5
« Reply #141 on: Thu, 14 May 2020, 12:25:04 »
Deskmats
Islander Hopper Mat
Love the Island Hopper! Great job, looking forward to joining :)
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline SodiePops
« Reply #142 on: Thu, 14 May 2020, 13:21:43 »
Oh my God these deskmats! So cute.
Sent from my SM-N960U using Tapatalk
« Reply #143 on: Thu, 14 May 2020, 13:45:13 »
No EU vendor?
Prototypist.net
Oh damn you're right. Haven't thought about that.
EDIT: The deskmats look awesome!
« Last Edit: Thu, 14 May 2020, 13:50:40 by Pizza_on_Pineapple »
Offline sirieous
  • help
« Reply #144 on: Thu, 14 May 2020, 13:49:51 »
damn that fullart deskmat is so gorgeous
Offline mikagee
  • Nobody helps me
Re: [IC] Infinikey: PBT Islander - GB May 15 to 29 Deskmats added
« Reply #145 on: Thu, 14 May 2020, 15:44:46 »
Is there an estimated shipping date for the keycap set and deskmats?
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #146 on: Thu, 14 May 2020, 16:23:27 »
This will look great by my Switch :)
Offline platypusduck
« Reply #147 on: Fri, 15 May 2020, 01:36:23 »
Is there a chance of running this at least until the end of the month, or even until June 1st?
« Reply #148 on: Fri, 15 May 2020, 14:45:54 »
Bought base and novelties!
Offline BreadBanana
« Reply #149 on: Fri, 15 May 2020, 19:44:11 »
Just bought base novelties and deskmat !
« Last Edit: Fri, 15 May 2020, 19:48:24 by BreadBanana »
