Author Topic: New enthusiast needs help  (Read 2284 times)
Offline Ediv
« on: Fri, 17 April 2020, 09:36:20 »
Hi guys! I'm looking for my first mech keyboard, budget around 2-300€. I am from Italy and I know this is not the perfect time for US shipping towards us, for that reason I am not in a hurry at all.
I like the 65% form factor, possibly with regular sized switches all across the keyboard so that if I want to upgrade the keycaps in the future i don't have to go crazy finding a compatible set. I am not afraid of soldering the board myself since I am quite used to electronics soldering (I heard that hotswappable pcb are not the best about long term reliability).
I am completely new in this world so any advice will be helpful! Thank you in advance guys!
Re: New enthusiast needs help
« Reply #1 on: Fri, 17 April 2020, 12:04:04 »
Outbound international postage from the US is always very expensive, the Covid-19 pandemic will not change that.
- D Trump 2026-10-24
Offline Ediv
« Reply #2 on: Fri, 17 April 2020, 15:08:41 »
Yep, unfortunately that is a fact.
Has someone any suggestion about a good starting keyboard (or DIY kit) for that budget?
Thanks for your answers ^^
Offline Maledicted
« Reply #3 on: Fri, 17 April 2020, 15:11:58 »
I have never done the LEGO keyboard thing before, so I would barely know where to start. I ordered parts, but that's going to end up being a GK64 layout, so I'll be frankensteining some cap sets. I wish I could help.
Offline Leslieann
« Reply #4 on: Fri, 17 April 2020, 20:05:33 »
Look the other direction, China, most of ours come from there anyhow.
Check YMDK, KBDfans and Krepublic.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline el_murdoque
« Reply #5 on: Sat, 18 April 2020, 18:00:17 »
Do you already know which switches you want in that keyboard?
I'd give a few a try before committing serious time, effort and money into a custom build.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #6 on: Sat, 18 April 2020, 18:38:54 »
Leslieann is right, https://kbdfans.com/, https://kprepublic.com/, & https://www.amazon.com/stores/YMDK/node/17919265011 are all great places to get affordable MKB kits that are of decent quality.
Offline Ediv
« Reply #7 on: Sun, 19 April 2020, 08:11:49 »
Thanks for your answers guys! I'd go for tactiles, around 50g. I have tried cherry browns on a friend's kb and it felt really good. Maybe because I haven't tried anything else ^^. Have you guys alternatives for maybe a tactile on the "less bumpy" side?
Offline el_murdoque
« Reply #8 on: Sun, 19 April 2020, 08:14:45 »
I doubt there is a tactile switch less bumpy than the MX brown. I mean, when they are worn in a bit they feel like scratchy reds. And I am literally typing this now on Cherry mx browns.
Offline Ediv
« Reply #9 on: Sun, 19 April 2020, 08:19:41 »
I'll go for browns then ^^ when the moment comes you'll be updated with some pics guys. TY!!
