Author Topic: [GB] GH80-3700 cherry numpad PCB (shipping)  (Read 31408 times)
Offline .
« on: Mon, 20 April 2020, 15:34:44 »
The GH80-3700
...is the way to make your Cherry numpad modern again. (Note: this is just a PCB, no case included)
It has pads to solder your own cable to, or you can use any USB-C cable while still keeping the vintage look,
as the cable connector is hidden inside. There is room for a rotary encoder as well.
For all your indication needs, the top row has individually controllable led locations just like the numpad toggle key does.
It also features a fuse and an ESD protection chip to protect the MCU and other parts of the PCB.
Features
  • Designed to fit the Cherry G80-3700 numpad case
  • Compatible with QMK Firmware and VIA Configurator (if you flash a VIA compatible .hex file)
  • USB type C with C-C support
  • ESD protection and fuse
  • 5 individual LED locations, can all be used in QMK
  • Rotary encoder support (top right key position)
  • ISP header
Pictures
Render and layout support
Cable hidden in case
Rotary encoder & LEDs
Plate file will be made available.
Pricing & where to get
This PCB will cost 25 euro excluding shipping.
I will ship anywhere and I've made sure it's decently affordable even for people outside of the EU. This group buy is limited to 50 PCBs.
You can get it here right now, group buy closes May 31st.
Thanks to ISO_returns for some of the pictures and for making this happen in the first place, by letting me borrow his G80-3700.
« Last Edit: Tue, 28 July 2020, 16:41:53 by . »
Re: [GB] GH80-3700 cherry numpad PCB
« Reply #1 on: Tue, 21 April 2020, 09:40:51 »
Approved :thumb:
« Reply #2 on: Tue, 21 April 2020, 14:08:54 »
I don't buy things anymore but this is really cool, there are a ton of 3700's out there.
Sent from my SM-G970U1 using Tapatalk
Offline t8c
« Reply #3 on: Tue, 21 April 2020, 16:00:04 »
Joined. Thanks for doing this!
Offline Franzl
« Reply #4 on: Sat, 25 April 2020, 07:21:20 »
Only PayPal :'-(
Offline .
« Reply #5 on: Sat, 25 April 2020, 07:42:41 »
Only PayPal :'-(
You can email me for other options  :)
Offline Franzl
« Reply #6 on: Sun, 26 April 2020, 12:13:00 »
Sent an pm ;-)
Offline Debido666
« Reply #7 on: Sat, 02 May 2020, 00:35:39 »
I take it the plate has to be sourced elsewhere?
Offline .
« Reply #8 on: Sat, 02 May 2020, 02:49:22 »
Yes, but the file will be available to download.
Offline .
« Reply #9 on: Thu, 14 May 2020, 06:19:17 »
There are a decent amount of orders and there's half a month left!
Offline akaceejaye
« Reply #10 on: Thu, 14 May 2020, 07:15:30 »
Anyone have any recommendations for a case for this guy. I'm having a bunch of trouble finding one.
Offline .
« Reply #11 on: Thu, 14 May 2020, 07:17:09 »
If you have a 3d printer nearby or someone who can print it for you, I can probably whip something up in fusion.
Offline .
« Reply #12 on: Sat, 30 May 2020, 03:49:38 »
It's the last day to get your numpad pcb (will close tomorrow night)!
Thanks to all who have joined so far.
Offline .
Re: [GB] GH80-3700 cherry numpad PCB (closed)
« Reply #13 on: Mon, 01 June 2020, 01:48:36 »
And we conclude with 27 PCBs sold!
Now it's time for me to get these ordered.
Offline .
« Reply #14 on: Tue, 07 July 2020, 03:31:50 »
So... Production is going well, but we're likely not going to make it to mid July because I'm waiting for parts that are delayed because of covid. I expect early to mid August for shipping. Thanks for your patience!
Offline .
« Reply #15 on: Wed, 15 July 2020, 11:17:05 »
Alright, I got the cables in today and I'm happy to say that everything works as expected!
I have teased this before on Instagram and my discord server, but for those who haven't seen it yet: you can connect use a PS/2 mouse to it!
It works through the PS/2 mouse feature in QMK, but I should probably show it instead. Here's a vid:
Offline .
« Reply #16 on: Thu, 23 July 2020, 07:59:11 »
Alright they're done and shipping soon  :D
« Last Edit: Sat, 25 July 2020, 13:59:44 by . »
Offline Debido666
« Reply #17 on: Fri, 24 July 2020, 12:51:55 »
Will there be another run?
I hesitated the first run because I thought it would be impossible to find a GH80-3700 to Mod.
I found one...
Offline .
« Reply #18 on: Fri, 24 July 2020, 13:36:51 »
I found one...
There will be very few extras. (4 or so?)
If that doesn't work out, you could make them yourself. The design is open source on github.
Offline Debido666
« Reply #19 on: Sat, 25 July 2020, 11:05:39 »
I found one...
Please let me know. I can pay now, if need be.
Offline .
« Reply #20 on: Tue, 28 July 2020, 16:41:39 »
All orders have been packed and will be shipped over the next few days. Thank you all!
Offline .
Re: [GB] GH80-3700 cherry numpad PCB (shipping)
« Reply #21 on: Sat, 08 August 2020, 08:43:39 »
The 3d printed case design is done, but I won't be able to test it right now due to a heat wave. When it's over I will print one and see if it all fits like it should.
Here are some pictures:
So yeah, the files for these will be up soon :) (and I don't recommend getting it milled. It is not designed to be milled.)
Offline .
« Reply #22 on: Wed, 19 August 2020, 12:01:26 »
I was able to print one, here are some pictures:
 :llama: :llama:
I will increase the chin size a bit and fix some small mistakes, then the files will be freely available.
Offline jay6889
« Reply #23 on: Mon, 24 August 2020, 14:10:13 »
I need this so bad, do you still have any extra?
Offline Debido666
« Reply #24 on: Mon, 21 September 2020, 17:28:57 »
Any update on VIA firmware?
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #25 on: Mon, 21 September 2020, 17:33:35 »
This is super cool, wish I saw it when it was available.
Offline .
Offline akaceejaye
« Reply #27 on: Fri, 09 October 2020, 12:16:43 »
Hey mate, where did you get the plate for yours?
Offline Debido666
« Reply #28 on: Fri, 09 October 2020, 14:17:39 »
Q
« Last Edit: Mon, 07 December 2020, 01:28:17 by Debido666 »
Offline Debido666
« Reply #29 on: Fri, 09 October 2020, 14:19:30 »
I don't have one yet.
Here are the files if you want one made somewhere.
https://github.com/evyd13/gh80-series/tree/master/GH80-3700/plate
Offline akaceejaye
« Reply #30 on: Fri, 09 October 2020, 15:42:54 »
hmmm okay thanks.
Offline akaceejaye
« Reply #31 on: Thu, 15 October 2020, 20:38:16 »
How does one edit this file, to change where the stabs would be, I am not gonna utilize large keys on this.
