Author Topic: [IC] RAINDROP 60% by Laneware [Poll Open]  (Read 34039 times)
Offline Laneware
    • Laneware Peripherals
« on: Tue, 21 April 2020, 18:49:35 »
Link to prototype images: https://imgur.com/a/sq6H2tB
By Laneware
Global Vendor:
Regional Vendors:
TBA
RENDER BOOK
241606-2   241616-3
241608-4    241618-5
241610-6    241620-7
241612-8    241622-9
241614-10    241624-11
To Do List:
☑ Preliminary PCB design
☑ Preliminary case design
☑ PCB working prototype
☑ Collate IC feedback
☑ Poll IC popular feedback and suggestions (Poll Open)
☑ Finalise case design based on poll results
☑ Procure initial case prototype
⚫ Final adjustments based on prototype look and feel
⚫ Open group buy 🙌
Group buy will include:
-Aluminium 60% Case (2 peice top and bottom)
-Brass Weight
-PCB
-Brass Switch plate with gasket mounts
Case Design:
-2 Peice top and bottom aluminium case.
-Gasket mounted
-USB-C port located in "POKER" layout location, allowing you to utilize existing PCBs if you wish to
-18mm front height
-7 Degree typing angle
PICTURE BOOK
240374-12
240376-13
240378-14
240380-15
240382-16
240384-17
240386-18
240388-19
240473-20
240475-21
240476-22
240478-23
240480-24
240482-25
240485-26
240487-27
ASSEMBLY and GASKET MOUNT DETAIL
240390-28
240392-29
240394-30
240396-31
240398-32
240400-33
240402-34
240404-35
240406-36
240408-37
SCREW HOLE LOCATION - ZERO VISABLE SCREWS
240410-38
240412-39
PCB PROTOTYPE
241056-40
UPDATED PCB LAYOUT
The PCB has undergone two key updates since the above prototype. The switches have been rotated to be south facing and two additional layouts have been added as per below.
241202-41
241204-42
241206-43
LAYOUTS AVAILABLE
Standard 60%
241208-44
2u Left Shift with Arrow Keys
241210-45
HHKB with 6.25 Spacebar
241212-46
Contact Me:
Feel free to contact me with any questions, queeries or requests at my discord
LANEWARE#0468
Current Poll Results:
Q: Should the raindrops on the front of the case remain?
A: Yes
Q: Where would you prefer the top tab with the raindrops on it?
A: Middle of Keyboard
Q: How big should the characters on the back be?
A: How it currently is
Q: Where would you prefer the USB-C port?
A: Left of Keyboard
Q: Would you be interested in a different case colour?
A: White, Black, Grey
Q: Would you be interested in a different plate colour?
A: Gold, Black
Q: Would you be interested in a different weight colour?
A: Gold, Black
Q: Would you be interested in a Raindrop theme desk mat?
A: Yes
Q: Would you be interested in a blue colour matched cable with aviation connector?
A: Yes
Q: Should multiple PCB layouts be offered on the one board?
A: Yes
Q: What general layout should be offered?
A: 2u Left shift with arrow keys, Standard 60%, HHKB
« Last Edit: Mon, 29 June 2020, 00:15:35 by Laneware »
Re: [IC] RAINDROP 60% by Laneware [Poll Open]
« Reply #1 on: Tue, 21 April 2020, 18:53:12 »
board is cool, name is easily confused with the keyset
i like the shape
Offline Laneware
« Reply #2 on: Tue, 21 April 2020, 20:03:57 »
i like the shape
Thanks for the feedback  :thumb:
Offline CrazyAssMonkey
« Reply #3 on: Tue, 21 April 2020, 22:24:46 »
The top part of the case looks so cool, it's a design element I have not seen.  :D
Offline kbye
« Reply #4 on: Tue, 21 April 2020, 22:58:28 »
Interesting concept but I don't like the idea that I'd have to remove the bumpons every time I want to open it up. Granted they're cheap to replace, maybe it's just me.
Offline srignacio
« Reply #5 on: Tue, 21 April 2020, 23:01:41 »
I love the design and color. The shape is also great!
Offline Laneware
« Reply #6 on: Tue, 21 April 2020, 23:11:05 »
All done in persuit of the cleanest design possible. I hear you tho, I will include spares  :)
Offline Laneware
« Reply #7 on: Wed, 22 April 2020, 15:47:28 »
I recieved alot of initial feedback to also offer a white/e-white case colour. Let me know what you think of the new renders under the picturebook  ;D ;D ;D
240601-0
240603-1
Offline Laneware
« Reply #8 on: Thu, 23 April 2020, 05:30:48 »
Over 100 poll responses! Thanks for all of the great feedback so far  :thumb:
Offline keebguy
« Reply #9 on: Sat, 25 April 2020, 17:16:38 »
Made this account just to say I LOVE THIS :confused:, insta buy especially if it came with a black plate option
Offline Laneware
« Reply #10 on: Wed, 29 April 2020, 02:13:53 »
Updated to include PCB detail. Let me know your thoughts on the feedback form or in the comments :)
« Last Edit: Wed, 29 April 2020, 04:28:29 by Laneware »
Offline yuki
  • sleep is for the weak
« Reply #11 on: Wed, 29 April 2020, 05:53:25 »
Correct me if im wrong but based on the samples, your pcb is north facing? Please considering swapping to south facing so we can use cherry profile keycaps. You dont even have leds on here in the first place.
I assume you've done this to make room for the usb connector, but please consider doing the normal thing and flipping only "Esc" and "1" to be north facing instead.
Regards, a very sad cherry profile keycap user.
Offline funderburker
« Reply #12 on: Wed, 29 April 2020, 06:59:14 »
There's definitely potential with the design. I feel that if you're going for a custom PCB then it would look way cleaner with a centred USB. Offering standard PCB compatibility is nice but just saying... Also, I think there's not a real reason to go with gaskets on the sides and you'd actually benefit from it more, both in manufacturing (slightly but still) and "feels". How deep is the engraving on the bottom? Seems real deep.
Screwholes under bumpons is a nice touch. If you go with standard sizing and/or add some extra in the final product than it's definitely an easy and quick way to keep it clean!
Also what Puddsy said - Raindrop was a keyset with quite a heavy past. :D Nothing wrong with the name though.
« Last Edit: Wed, 29 April 2020, 07:22:53 by funderburker »
Keyboard design by Skepur
Offline skyyyy
« Reply #13 on: Wed, 29 April 2020, 07:13:28 »
Beautiful design! I agree with @funderburker about the centered usb aligning with the raindrop motif.
Looking forward to seeing the development and some full renders.
Offline Darthbaggins
  • PC Cannibal
« Reply #14 on: Wed, 29 April 2020, 14:01:14 »
Can't wait to see this go further, and would love to get my hands on one to build in it.  :thumb:
Offline Laneware
« Reply #15 on: Wed, 29 April 2020, 16:22:40 »
Hi Yuki, please help me understand your question a little more. See below image with cherry profile GMK Oblivion on the board, attached to a standard 60% case. The switches are rotated 180 compared to the "standard", this was done for prototyping purposes and will be reverted on the final PCB, however it makes no difference as the switches are symetrical. This would only be an issue if the switched were rotated 90 as the horizontal legs of the stems are thicker than the vertical.
241074-0
« Last Edit: Wed, 29 April 2020, 16:29:31 by Laneware »
Offline Laneware
« Reply #16 on: Wed, 29 April 2020, 16:39:04 »
Hi funderbkeurr, thanks for all of the feedback! So far 78.9% have polled to keep the USB-C on the left, I was also in two worlds about this but I guess compatability is king! The engraving on the bottom is 1.5mm. Thankyou for the feedback on the gasket, an initial prototype is on its way to get a general "feel" and better understanding on the ergonomic components of the design.
« Reply #17 on: Thu, 30 April 2020, 02:05:33 »
Switches are symmetrical but switch housing and keycap is not. There can be some rub between the inside of a GMK keycap and switch housing on certain row profiles because of north-facing placement. Just google around for the issue on r/mk or here.
Offline Laneware
« Reply #18 on: Thu, 30 April 2020, 05:12:30 »
Thankyou! The initial prototype is on its way, I cant wait to make it come to life!
Offline Laneware
« Reply #19 on: Thu, 30 April 2020, 05:41:01 »
Thanks for the info guys, easy change 👍
Offline Laneware
« Reply #20 on: Thu, 30 April 2020, 17:43:23 »
Over 200 responses to the feedback poll and 100 people registering to be notified when the GB is live, thanks for such a great response! All of the feedback is very appreciated and is being listened to.
Offline Laneware
« Reply #21 on: Fri, 01 May 2020, 05:58:33 »
Update: Changes to PCB. Flipped switches to be south facing, added two more layouts, standard 60% and HHKB with 6.25u spacebar
« Last Edit: Sun, 03 May 2020, 18:38:13 by Laneware »
Offline Laneware
« Reply #22 on: Mon, 04 May 2020, 00:39:03 »
Current poll results posted at the end of the thread. The poll is still open so be sure to get your feedback in, especially if you're keen on a specific colour!
« Last Edit: Mon, 04 May 2020, 02:44:27 by Laneware »
Offline Laneware
« Reply #23 on: Mon, 04 May 2020, 23:51:09 »
Renderbook added!
Offline KRY2SOON
  • Divine Studios
« Reply #24 on: Tue, 05 May 2020, 17:21:14 »
Offline Laneware
« Reply #25 on: Fri, 08 May 2020, 18:18:36 »
Update: Prototype Case is on its way!!!! Stay posted for build video :D
Offline Laneware
« Reply #26 on: Thu, 28 May 2020, 03:05:00 »
The Prototype is here! Stay posted for a full build video and photoshoot :D
The poll is still open for feedback and to register for the Group Buy!
243681-0
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #27 on: Thu, 28 May 2020, 04:27:07 »
Will hotswap be offered?
Offline Laneware
« Reply #28 on: Thu, 28 May 2020, 05:38:39 »
Not at this point. Potential to offer hotswap pins as an add on  if there is enough interest 😁
Offline GaNeBaL
« Reply #29 on: Thu, 28 May 2020, 07:19:45 »
any tsangan avail?
Obsessed with 60%TKLs
Offline GaNeBaL
« Reply #30 on: Thu, 28 May 2020, 07:24:37 »
is the top picture horizontally flipped?
Offline theside123
« Reply #31 on: Fri, 29 May 2020, 01:13:22 »
when gb start?
Offline Laneware
« Reply #32 on: Fri, 29 May 2020, 05:13:22 »
Nope, it looks like the plates been put in the wrong way for the photo  :-[
Offline Laneware
« Reply #33 on: Fri, 29 May 2020, 05:13:52 »
when gb start?
It's looking to be within the next 4-6 weeks
Offline Laneware
« Reply #34 on: Fri, 29 May 2020, 05:16:09 »
any tsangan avail?
No it wont, however you could closley mimic it with row1-4 HHKB and row 5 standard
Offline theside123
« Reply #35 on: Fri, 29 May 2020, 21:27:22 »
Is the imprint of the lower housing of the keyboard fixed? Can Kanji be selectively removed? Or can you put your favorite stamp?
Offline Laneware
« Reply #36 on: Fri, 29 May 2020, 23:59:11 »
It is CNC into the bottom case. There won't be the option to remove it or request different characters unfortunatly, variations like this would send the cost through the roof and I am aiming to offer it around the $350USD price point, far below recent 60% boards that have run in a GB. The current design that you see, including position, size and specific characters are what have polled out of several design polls.
Offline marshskitow
« Reply #37 on: Sun, 07 June 2020, 18:27:29 »
So sad there is no ISO ... This is one of the most beautiful project i've seen atm.  :mad:
Offline sctang
« Reply #38 on: Sun, 07 June 2020, 23:27:51 »
Is there a HHKB render or proto by chance?
Offline Laneware
« Reply #39 on: Thu, 11 June 2020, 03:12:20 »
Hi sctang. The demand for the HHKB top was not enough to project us reaching a MOQ for that specific top. What we have done is altered the HHBK layout slightly. Rows 1-4 will remain as standard HHKB layout, row 5 will be changed to a standard 60% row 5. This allows us to still offer a HHKBish layout that still captures the main draws to the specific layout, however will now fit into the standard 60% case. The layout section will be updated to reflect this.
Offline Laneware
« Reply #40 on: Thu, 11 June 2020, 03:14:17 »
ISO in the works, stay posted. Thanks for the kind words.
Offline marshskitow
« Reply #41 on: Thu, 11 June 2020, 04:55:44 »
We should have a discord server, i didn't see one.  :)
Offline Laneware
« Reply #42 on: Thu, 11 June 2020, 18:02:21 »
Good idea, Ill put one together before the GB opens :D for now you can contact me directly on discord if you have any questions :)
Offline Laneware
« Reply #43 on: Fri, 19 June 2020, 23:29:47 »
First of all a huge thankyou to the entire Mechanical Keyboard community for your support and feedback to date, it really is a great community to be a part of ❤
The prototypes are here, and our build stream is ready! I would love for you to come and join in the communities first look at the case.
The build stream will be hosted by https://www.twitch.tv/bytesizedseamus, an incredibly entertaining and knowledgeable up and coming streamer in the mech community at 11am - 3pm AEST on Sunday 21/06/2020.
Stream Full Build Details:
-RAINDROP 60% Case by LANEWARE
-RAINDROP 60% custom PCB
-Durock Stabilizers
-Custom Blue Cable with Aviator Connector
-Lubed and filmed Gat Yellows
-GMK Oblivion V2 by Oblotzky
Offline skyyyy
« Reply #44 on: Mon, 22 June 2020, 07:48:47 »
Just watched the end of the twitch stream. What a beauty.
Offline Laneware
« Reply #45 on: Mon, 29 June 2020, 00:16:05 »
GB thread is now live! (29/06/2020): https://geekhack.org/index.php?topic=107163.msg2925405#msg2925405
