Author Topic: Acer switch keyboard hack  (Read 3446 times)
Offline Kirks3dprinting
    • kirks 3d printing and design
« on: Thu, 23 April 2020, 14:51:34 »
Just thought I would post this hack I figured out.
I happened to come across a large supply of Acer switch detachable keyboards. SW312-31 N17H1.  It's a nice action small keyboard and I wanted to use it on a kitchen computer setup because its so small.  However it has no USB connector just 6 gold pins with no markings. like this:
                                pins
                           1   2   3  4  5  6
   |               Q  W  E  R  T  Y  U  I  O  P           |
   |____________|SPACE BAR|_____________|
                          |TOUCH PAD  |
                          |__________ |
               Pin# 1 Ground Black wire of USB
                   # 2 Nothing  (not used) (no connection)
                    #3 White wire of USB    , Data -
                    #4 Green wire of USB   , Data +
                    #5 Red wire of USB  +5V
                    #6 No connection (not used)
  240694-0" alt="" class="bbc_img" />
« Last Edit: Thu, 23 April 2020, 15:35:37 by Kirks3dprinting »
Re: Acer switch keyboard hack
« Reply #1 on: Thu, 23 April 2020, 14:57:01 »
« Last Edit: Thu, 23 April 2020, 15:41:45 by Kirks3dprinting »
« Reply #2 on: Mon, 04 May 2020, 13:04:06 »
I have been noticing the keyboard connection drops out after a while.  I unplug and replug and it works again.  Does anybody have an idea this might happen?  should I connect the unused pins to ground?  and by ground I mean either the Black ground or the shielding of the usb cable.  Any suggestions?
« Reply #3 on: Mon, 04 May 2020, 19:17:13 »
Is it some kind of power saving feature so it goes to sleep when you don't use it for a while then fails to wake up, or does it stop working after a while even while you're using it?
« Reply #4 on: Fri, 08 May 2020, 20:21:47 »
I will keep track.  its not a computer i use for any long period of time.  Its a file server for the rest of my house.
