Author Topic: [IC] PBT Modern Hangul  (Read 34355 times)
Offline ackzot
Re: [IC] PBT Modern Hangul
« Reply #50 on: Mon, 27 April 2020, 20:55:08 »
As a 재미 교포 2 세, will definitely be looking forward to this set.
Offline Zeelobby
« Reply #51 on: Mon, 27 April 2020, 21:57:16 »
Def a beautiful keyset.
Offline octix
« Reply #52 on: Mon, 27 April 2020, 22:15:27 »
Need this!
Discord: octix#0478
Offline HanaDesu
« Reply #53 on: Tue, 28 April 2020, 03:33:06 »
lookin real nice
Offline spoiledmilktea
« Reply #54 on: Tue, 28 April 2020, 05:23:09 »
Set looks amazing!
Offline alper_maestro
« Reply #55 on: Tue, 28 April 2020, 06:59:40 »
It has something special.
Offline Malvix Studio
    • Malvix Studio
« Reply #56 on: Wed, 29 April 2020, 17:16:09 »
Any chance of getting a render on a navy board? Looks great and love that its in pbt, will buy for sure!
I'm currently working on more renders! That's one of the things that I have to do moving forward, getting the set rendered on more boards, more board colours, and with updated sublegend colours. I'm hoping to iron those out within the next little while. I've gotten an overwhelming amount of support for the set, and I'm so excited to show more soon!
Canadian retailer? Support!
We should have that, currently ironing out manufacturer details!
Offline NMZS
« Reply #57 on: Thu, 07 May 2020, 12:40:41 »
Loving the idea of more muted sublegends. It's why I opted against buying SpaceCadet, for instance, it's just too visually busy. Although I actually think it looks fine in the renders so far since the Hangul characters are fairly thin.
As I said previously: ISO-DE-Support and this is a must buy for me :)
Offline bajapatty
« Reply #58 on: Tue, 12 May 2020, 15:50:38 »
Looks awesome
Offline D3LTA
« Reply #59 on: Wed, 13 May 2020, 09:08:13 »
Have you thought about offering a hangul mono legend alphas kit? Is it possible from this PBT manufacturer?
Offline shodid
« Reply #60 on: Fri, 22 May 2020, 12:59:03 »
Need this. I'll be all in.
    • Malvix Studio
« Reply #61 on: Sun, 24 May 2020, 05:00:53 »
Appreciate the support guys!
Definitely possible, but I have not seen enough interest to make it a thing.
ISO support was only recently added for Hammer CRP caps, so I'll try my best to push for those. If not, I want to get at least basic ISO-UK support in.
Offline Scucka
« Reply #62 on: Sun, 24 May 2020, 05:07:51 »
Interested in this
Offline GaNeBaL
« Reply #63 on: Thu, 28 May 2020, 09:59:15 »
Any plans for accompanying deskmat?
Obsessed with 60%TKLs
Offline Tywele
« Reply #64 on: Thu, 28 May 2020, 10:26:23 »
Don't know if it's still relevant but I'm definitely interested. Would love it if the colored caps would be available in pink as well.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #65 on: Thu, 28 May 2020, 11:30:31 »
I love me a good Hangul set so count me as interested!
Offline tofulo
« Reply #66 on: Fri, 29 May 2020, 21:12:05 »
So much potential for cool mats with this
Offline theside123
« Reply #67 on: Fri, 29 May 2020, 21:26:09 »
when gb start??
    • Malvix Studio
« Reply #68 on: Fri, 12 June 2020, 15:00:16 »
After speaking with my preferred manufacturer, they will not be able to start making these sets until Q4 at the earliest, due to extra preparations needed. In the interest of pushing forward a higher quality product, I’ve decided to wait until then. In the meantime, I will be working on finalizing kits for this set, collaborations, deskmats, and other necessary designs. Make sure to join my discord channel for the latest updates on this, as well as other projects! https://discord.gg/64rZMEB
Offline asciisii
« Reply #69 on: Fri, 12 June 2020, 15:02:39 »
Oof Q4, but looking forward to it!
Offline Bonsa
« Reply #70 on: Fri, 12 June 2020, 16:20:01 »
I love Hangul legends. Good job on the colors too!
    • Malvix Studio
« Reply #71 on: Fri, 12 June 2020, 18:43:31 »
Appreciate the support guys! I'll keep working on improving everything while we're all waiting <3
Offline kimchijody
« Reply #72 on: Mon, 22 June 2020, 03:01:02 »
I know this would probably cost more, but I would love a colored short spacebars kit.
Offline bl1ndguy0
« Reply #73 on: Wed, 24 June 2020, 05:08:36 »
Any plans for an alpha only 한글 kit? or even an 한글 only (no English letters) kit?
Offline konstantin
  • Formerly constexpr
« Reply #74 on: Wed, 24 June 2020, 10:02:52 »
There's a few small mistakes with the ISO-UK keys:
  • 1! should be 3£
  • \¦₩| should be \|₩ (| instead of ¦ and no fourth sublegend)
  • `¬ should be `¬¦
  • If you want, you can also include 4$€ for complete coverage including sublegends.
Also, the F13 should probably be black instead of white.
Now, would you consider including basic (Korean) ISO support in the base kit? This consists of the following keys: ISO Enter, 1.25u Shift, R3 \|₩, R4 <>. You could then have the UK-specific keys in the add-on kit, as you currently do. This would make ISO support less expensive, and would make the add-on kit cheaper, too. If I'm not mistaken, some Korean keyboards are ISO, so to me it makes sense to have basic Korean ISO support in the base kit.
On a different note, your base kit is missing a second 1u Alt key to go with the 1.5u Super and 1.5u Function for Mac bottom rows. So you could either add the missing second 1u Alt, or remove those two 1.5u keys.
Finally, feel free to remove the 1.75u key from the space kit, as that size is used only on 40% boards (and only three of them, at that).
Offline vi0till
« Reply #75 on: Tue, 21 July 2020, 03:38:43 »
Hope can see updates on this set soon. This will be my first PBT set.
Also this, I will buy the colored short space bar.
Offline tnsw
« Reply #76 on: Sun, 27 September 2020, 20:22:42 »
I’m 100% in.
