Author Topic: [IC] PH60 - Polycarbonate HHKB with POM plate (Rev.2 Renders Posted)  (Read 35635 times)
Offline anonymous
Hi guys, I just want to share with you another design that I made. I never owned a pc board or a pom plate so I am curious about the sound and feel of this keyboard. I think many people are also curious since there a only a few boards that have this kind of combination. I decided to make it a 60% since pcbs for these are accessible. There will be only one layout for now and it will be HHKB.
Features:
  • 6.5 degree typing angle
  • Seamless design
  • HHKB blockers
  • 3 star and a sun cutout on the weight
  • Top mount white POM plate. Possible brass and PC plate as add-on
  • Wedge bottom cover with weight
  • Compatible with GH60 pcbs (DZ60, YD60MQ, etc)
Tentative Price: $250 for case, bottom cover, and plate
Discord server: https://discord.gg/dApSWW5
Latest IC Form: https://forms.gle/ktJ9Pa2mYUzqgQAK6
Prototype Album 1: https://imgur.com/a/AIGvncQ
Prototype Album 2: https://imgur.com/a/ebPMph1
Rev2 Render Album (Final Design): https://imgur.com/a/YZJwlrE
Outdated Renders
Renders (Outdated):
Additional Renders (Outdated):
Side bezel is a little less thicker and added an angled bottom cover with internal brass weight
Prototype photos:
The quality of the prototype is satisfactory. This is my first PC board so I do not have a point of comparison. In terms of machining, the prototype was made according to the design files that I sent to the factory. All pieces fit and there are no tolerance issues.
However, there is slight bowing on the bottom cover due to the absence of center point screws (https://imgur.com/VpeYkjS). The bottom cover is attached to the top piece only on the four corners. I didn't put screws in the middle to achieve uniformity on the plate. The bowing is only .2-.3mm and does not affect the typing experience at all. Adding the height of the bump-ons, the bottom will not touch the surface of your table.
To mitigate the issue, I added an extrusion to the lower part of the bottom cover (https://i.imgur.com/4ACq7i1.jpg). (More design changes can be found at the bottom of this post)
Rev2 Renders:
Some design improvements were done after acquiring the prototype. Below is a summary of these changes. (This will be the final design when the groupbuy launches.
  • Decreased the bezels
  • made the plate screws m2 instead of m3 (same mounting points)
  • removed the curve on the front part
  • removed the 3 star and a sun engraving on the back
  • added a 3-star and a sun cutout on the weight
  • added an extrusion that will make the lower part of the bottom cover stiffer (please refer to the renders to see what I meant)
Typing Test with Gateron Milky Blacks:
Typing Test with T1 Switches:
« Last Edit: Thu, 09 July 2020, 09:17:39 by anonymous »
Offline Rafa_n
  • stuffforrectangles.etsy.com
Re: [IC] PH60 - Polycarbonate HHKB with POM plate
« Reply #1 on: Thu, 30 April 2020, 11:29:32 »
Very interested  :thumb:
Offline self
« Reply #2 on: Thu, 30 April 2020, 11:31:12 »
Interested!
Sent from my ONEPLUS A5010 using Tapatalk
Offline joshuarubin
« Reply #3 on: Thu, 30 April 2020, 11:32:30 »
Looks great! Sign me up. Great price too. How theoretical is this? I mean, are you just throwing this up against the wall or are you closer to GB stage? Any idea on what the production time for something like this would be? If you can't tell, I need something like this, like, yesterday.
Offline ddnomad
« Reply #4 on: Thu, 30 April 2020, 11:35:32 »
This looks interesting. Wondering how bad would be a price increase with an angled bottom (cause empty space may murder a sound signature).
Offline cijanzen
« Reply #5 on: Thu, 30 April 2020, 11:35:50 »
It’s like a flatter Leaf60.
Offline anonymous
« Reply #6 on: Thu, 30 April 2020, 11:37:17 »
I'll probably run a GB but not sure when. Depending on feedback and when I will get a prototype
Offline arcaen
« Reply #7 on: Thu, 30 April 2020, 11:38:21 »
looks clean, i'm interested
Offline anonymous
« Reply #8 on: Thu, 30 April 2020, 11:43:08 »
This may be true with metal cases. With plastic cases like this or acrylic, IMO the effect would not be bad
« Last Edit: Thu, 30 April 2020, 11:47:25 by anonymous »
Offline Vyndem
« Reply #9 on: Thu, 30 April 2020, 11:48:51 »
Interesting! What hotswap PCBs would work with the keyboard?
Offline Fredington
    • Instagram
« Reply #10 on: Thu, 30 April 2020, 11:51:03 »
Definitely interested.
Offline anonymous
« Reply #11 on: Thu, 30 April 2020, 11:52:58 »
As long as the port is in the same position it would work. The only pcb I know that can work is the kbd6x. Not sure if there are other hhkb/tsangan hotswap pcbs
Offline holocene
« Reply #12 on: Thu, 30 April 2020, 11:55:20 »
It would be great to have a sneek peak of the engraving at the back! The PH stands for the Philippines, right? Hello kababayan!
Is there any chance you could do an alu case as well?
Very nice price point, though! Fingers crossed for this one.
Sent from my SM-G973F using Tapatalk
Offline anonymous
« Reply #13 on: Thu, 30 April 2020, 11:58:36 »
Yup that's right haha
It can be seen on the 3rd render. But it's very subtle. It's just .3mm deep
For now alu is not an option. I'll decide after the GB for this.
Offline holocene
« Reply #14 on: Thu, 30 April 2020, 12:06:09 »
Oh it's right there! Very subtle but very nice touch.
Exciting.. was looking for an HKKB and a poly board, never thought I'd find both in one but here it is haha.
Will definitely jump on this one
Offline Fredington
    • Instagram
« Reply #15 on: Thu, 30 April 2020, 13:45:16 »
Would it be possible for the plate to come in different colors?
Offline Kabonkers
« Reply #16 on: Thu, 30 April 2020, 15:06:55 »
Hope this comes to GB. I've got holy pandas coming that'd work perfectly in this type of case.
Offline ilikerustoo
« Reply #17 on: Thu, 30 April 2020, 15:09:10 »
Interested
Offline lush_bunny
« Reply #18 on: Thu, 30 April 2020, 15:21:52 »
oh hey you're introducing this to geekhack? Must have gotten amazing feedback locally, but I'm not surprised! The sun and stars look much better as an engraving btw  :thumb:
Offline kaisn
« Reply #19 on: Thu, 30 April 2020, 15:29:29 »
as a mx HHKB lover I want to join the GB
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #20 on: Thu, 30 April 2020, 15:50:51 »
I dig it, definitely something I'd consider buying! Although any chance of a weight option? I see these being extermely light boards without a weight.
Offline ddnomad
« Reply #21 on: Thu, 30 April 2020, 16:05:38 »
Well, I mean it may be okay, though sound test will show (obv requires a prototype).
Offline skrunk
« Reply #22 on: Thu, 30 April 2020, 16:20:13 »
oh wow, i just saw the back's engraving. it's really great to see Filipino designers in the keyboard space!
definitely interested in this project
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline The Equals D
« Reply #23 on: Thu, 30 April 2020, 16:22:06 »
Well ****, hard to find anything wrong with this one. Nice price and I like the design. I imagine this will do very well
Offline treeleaf64
    • treeleaf64
« Reply #24 on: Thu, 30 April 2020, 20:20:34 »
Def interested, will watch out for this one.  :D
Everyone must pay the cat tax
Offline befbef
« Reply #25 on: Fri, 01 May 2020, 00:13:02 »
I would buy it  :thumb:
Option for half-plate would be nice.
Offline Merked
« Reply #26 on: Fri, 01 May 2020, 04:18:24 »
how much would it add to the cost at the very least an optional internal brass plate to fill the space and add weight?
Offline anonymous
« Reply #27 on: Fri, 01 May 2020, 06:09:21 »
I am not sure but I think around 50-70$? Here's a render of the angled bottom cover with weight that I made. This is a separate design and is not just an upgrade to the flat bottom
Offline rkarp
    • hypertext.dev
« Reply #28 on: Fri, 01 May 2020, 10:13:31 »
Very nice - interested in this.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #29 on: Fri, 01 May 2020, 18:46:09 »
Very interested as well. Would this fit the PCB that ships with the tokyo60 by any chance?
Offline Vadurr
  • Valar Morghulis
« Reply #30 on: Fri, 01 May 2020, 19:01:26 »
I'd be interested in this...
Offline nathanchere
« Reply #31 on: Fri, 01 May 2020, 22:40:08 »
Interested but hesitant at that low price point. PC boards tend to have high issue rates from other GBs I've seen even from well established and proven GB runners. If you don't account for this in the price I would be worried about ending up with another Teseletron situation. Other than for that concern though, it's very appealing.
Offline joonia
« Reply #32 on: Sat, 02 May 2020, 00:54:24 »
interested  ;D ;D
Offline anonymous
« Reply #33 on: Sat, 02 May 2020, 00:58:30 »
Thanks for the heads-up. The price is just my estimate. I'll know the final pricing once I get quotes from a manufacturer and successfully get a prototype
Offline NoxNoxNox
« Reply #34 on: Sat, 02 May 2020, 11:41:58 »
Keep in mind that there isn't a PCB included in this one, which does keep the price down.
Offline ArchDill
« Reply #35 on: Sat, 02 May 2020, 11:49:09 »
I tend to like more blocky keyboards but I am interested in this. I had a poly leaf60 and was not a huge fan of the way it looked so I sold it. I have been wanting another PC hhbk so bad.
Offline StreakInTheSky
« Reply #36 on: Sat, 02 May 2020, 19:09:24 »
Very interested in this, could be my ideal board. Never been a big fan of heavy, metal keyboards. Would actually prefer it with the extra internal space, especially if sound isn’t compromised. Since it’s completely plastic, would be the perfect case for a BT board like the BIOI G60 pcb. Though I suppose the space used for the weight could work if that’s where you decide to take this.
Offline Baron
  • oops its me
« Reply #37 on: Sun, 03 May 2020, 07:13:41 »
keep the thinner bezels, that looks great
i'm not sure about the curve on the bottom front though
Offline anonymous
« Reply #38 on: Fri, 08 May 2020, 06:32:19 »
Placed an order for a prototype. ETA is 3-4 weeks
Offline anonymous
Re: [IC] PH60 - Polycarbonate HHKB with POM plate (Prototype ordered)
« Reply #39 on: Thu, 04 June 2020, 06:05:07 »
Prototype is finished! The manu will send it to me within the week. Video: https://imgur.com/a/75iZZOo
Offline CrazyAssMonkey
Re: [IC] PH60 - Polycarbonate HHKB with POM plate (Prototype finished)
« Reply #40 on: Thu, 04 June 2020, 07:44:54 »
Oh snap that looks nice!
Do you have an estimate for the price? Because If you manage the initial one that’s nuts.
Offline delvix
« Reply #41 on: Sat, 06 June 2020, 12:58:08 »
Proto looks incredible man, I'm super interested in this. Any idea of a timeline?
Offline econeuler
« Reply #42 on: Sat, 06 June 2020, 15:18:15 »
That looks great  :thumb: would be nice with an eu proxy for the gb!
Offline mikeduran
« Reply #43 on: Sun, 07 June 2020, 09:34:12 »
Looks gucci, would really consider this if there were a EU proxy  :thumb:
Offline nathanchere
« Reply #44 on: Sun, 07 June 2020, 18:18:26 »
If that prototype is an indication you're going to have a hit on your hands here
Offline konstantin
  • Formerly constexpr
« Reply #45 on: Sun, 07 June 2020, 18:21:10 »
Ngl, $200–$250 is a pretty good price for something like this. I hope you'll manage to hit that target. The prototype also looks good.
I'm going to mirror everyone else's thoughts and suggest that you bring an EU proxy on board for this ;)
Offline Rafa_n
« Reply #46 on: Sun, 07 June 2020, 18:23:04 »
yeah + 1 for EU proxy
Offline befbef
« Reply #47 on: Sun, 07 June 2020, 18:31:25 »
+1
Will definitely join if there is EU proxy
Offline anonymous
« Reply #48 on: Sun, 07 June 2020, 21:03:30 »
May I know what's the advantage of having an EU proxy vs. shipping directly from me to EU joiners?
Offline nathanchere
« Reply #49 on: Mon, 08 June 2020, 03:32:09 »
Tax / import duties. The EU is savagely protectionist about imports.
