Author Topic: [GB] GMK Masterpiece  (Read 463578 times)
Offline Adelscott
Re: [GB] GMK Masterpiece - R2 IS HAPPENING!
« Reply #200 on: Sun, 31 May 2026, 12:28:24 »
Nice, I'll grab a PRESERVING for my R1, I need the blue 3Us. But why is there a blue 7U in it ? I'd prefer 2 white 3U instead of that duplicate 7U  ;D
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Energieschleuder
    • Discord
« Reply #201 on: Mon, 01 June 2026, 17:58:34 »
The blue 7U spacebar in the R2 Preserving Kit is intended for R1 buyers who own the Value, Clarity and West Kits allowing them to fit two boards with this new R2 Preserving Kit. Additionally, it serves as a 7U spare spacebar for R2 buyers. I also included a 1.5U Accent Control key for a new refreshing touch, which is also a nice addition for R1 buyers. Thank you for your support!
Offline Zahul
« Reply #202 on: Mon, 15 June 2026, 10:35:24 »
So I haven't seen it mentioned. But the GB is open, at least on oblo. For those interested in a set!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #203 on: Mon, 15 June 2026, 16:40:36 »
It was announced two weeks ago. But the post is now at the bottom of the previous page so it's easy to miss.
Vendor links are in KeycapLendar and KeyAtlas
Hello everyone, I'm excited to introduce
GMK Masterpiece R2 マスターピース
Group Buy will be live from June 5th.
Kits
オリジン ORIGIN Katakana Base
ローマン ROMAN Latin Base
プレシジョン PRECISION Numpad
プリザービング PRESERVING Extension
A note from me
I have worked hard over the past months to bring you what I believe to be an outstanding upgrade for GMK Masterpiece.
The entire Nav Cluster and Numpad now feature full Katakana legends. To achieve fully cohesive Katakana aesthetics across the entire keyboard, the biggest challenge for me was fitting the necessary Kanas onto 1u keycaps without resorting to cluttered two-line legends. I am happy with the final result, and I believe it delivers a clean, sharp look while staying true to its English equivalent as much as possible.
While my initial plan was to keep the large Base Kit from R1, the kitting had to be adjusted to align with current production requirements and structures. To make this run possible, the Base Kits, as well as the Numpad (Precision Kit), will now be offered separately.
Thank you all for your continuous support and appreciation for GMK Masterpiece! ;D Mark your calendars for June 5th!
Discord: https://discord.gg/uxhpght3X A hub for possible future designs.
Edit: Discord link added
« Last Edit: Mon, 15 June 2026, 16:52:42 by dvorcol »
Offline dvorcol
« Reply #204 on: Fri, 03 July 2026, 19:01:41 »
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #205 on: Fri, 17 July 2026, 20:23:35 »
Looks stunning
