Author Topic: [IC] HATCHET-01 | 65% | Groupbuy Live Now!  (Read 38557 times)
Offline Current Keyboards
    • currentkeyboards.com
« on: Tue, 19 May 2020, 09:43:27 »
HATCHET-01
by Mech Mountain
A 65% case and PCB with 3.5mm top plate and O-ring damping.
Weight is 2158g / 4.75lbs in aluminum without pcb or components.
Color/Material Options:
Note, colors are not exact. These are anodizing samples from the supplier who will try to match them as best as possible. Also all colors will be bead blasted, not brushed like some of these samples.
Bead-Blasted Polycarb:
Gloss Powder Coat White:
Mute Blue:
Bright Blue
Silver
Red
Black
Green
Can I make suggestions?
Please do, I am open to anything! Please fill out the IC form at the top.
Who is manufacturing this?
I have a good relationship with a CNC factory that has done great work for us for the last few years. They build our prototypes and small manufacturing runs for my day job. They are expensive but well worth it and have gone over and above to ensure high QC in the past. They are the same factory making the prototype above.
Will this come with a PCB?
Yes! Gondolindrim is currently finishing up the PCB. While the top plate will only support 65% standard ANSI with 1U keys right of the spacebar, the PCB and case are compatible with KBDfans 65% plates.
How many units will there be?
I am not going to limit the overall number of units (I'm a big fan of if you want a case, you should be able to buy it). That said, I will be shipping in batches. The first production batch will be 100 units to ensure QC with first bought, first shipped. From there I will produce the rest of the orders.
Is the pandemic going to seriously delay this?
Unless something radically changes, no, the factory I am using is up and running at 100%. If for some reason that shifts over the course of the GB, I have a backup that I also trust.
Collabs?
Reach out to me! Would love to talk if you have an idea!
Cost?
Not cheap, the big blank size drives cost. Looking in the ~$500 range.
Typing Angle?
6 degrees.
Who are you?
My day job is a consumer product engineer and so I naturally found myself wanting to build my own case and parts. What better way to build the case I want than get a GB going!
Code: [Select]
[url=https://geekhack.org/index.php?topic=106475.0][img]https://live.staticflickr.com/65535/50081187133_5f22063357.jpg[/img][/url]
« Last Edit: Mon, 17 August 2020, 11:30:10 by MechMountain »
Offline GEIST
    • schwarzgrau
Re: [IC] HATCHET-01 | A Single Piece Top Case with Sorbothane Damping
« Reply #1 on: Tue, 19 May 2020, 10:02:07 »
Such an incredible nice design. Do you know how thick the walls will be?
Offline Auxo
  • Formerly CJD_Anthony
« Reply #2 on: Tue, 19 May 2020, 10:03:16 »
Pretty cool concept and design you got goin on here  :)
« Reply #3 on: Tue, 19 May 2020, 10:11:42 »
THICC. It's essentially solid.
Offline hottrout
  • I'd Hit Dat Key
« Reply #4 on: Tue, 19 May 2020, 10:15:12 »
This could be really nice. Personally I would like to see 75% or at least 65% in this design.  Also ISO would be a requirement.  I do like your concept though, very clean and perfect for certain systems.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Peiweisgreat
« Reply #5 on: Tue, 19 May 2020, 10:16:32 »
Not really my cup of joe, but I think it would look a lot better if the keys were sunk into the board a bit.
« Reply #6 on: Tue, 19 May 2020, 10:21:57 »
If there is enough demand for other layouts, I'll probably make them. Just gets a bit messy since I can't reuse the same case for each layout.
Offline fruitofconfusion
« Reply #7 on: Tue, 19 May 2020, 10:35:11 »
This is my hope as well, 65% would be great. I also would be down at 75%
« Reply #8 on: Tue, 19 May 2020, 10:45:33 »
I've added a layout question to the IC form.
Offline Abec13
« Reply #9 on: Tue, 19 May 2020, 11:04:17 »
This looks really sharp. Like I mean the corners look uncomfortable to hold.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline i luv chuletas
« Reply #10 on: Tue, 19 May 2020, 11:17:24 »
Looks amazing, definitely a concept I'm into. Kinda wish we had a hi-pro variant of this though :(
« Reply #11 on: Tue, 19 May 2020, 11:25:08 »
The front edge is pretty far away from where your palm will rest (I've got giant hands too) but yeah, it's named Hatchet for a reason haha.
Offline logo4poop
  • Talk to me on discord @logoooo
« Reply #12 on: Tue, 19 May 2020, 12:52:41 »
o no
LCK75 so lit
Offline walston
« Reply #13 on: Tue, 19 May 2020, 23:21:32 »
This is sick. I want to embed a touch pad in it
Offline J_Noes
« Reply #14 on: Tue, 19 May 2020, 23:49:40 »
would love this if there was a high profile version without the exposed switches
« Reply #15 on: Wed, 20 May 2020, 00:21:07 »
i am intrigued, at least
would want to see a proto before the GB
Offline Joaquox
« Reply #16 on: Wed, 20 May 2020, 00:40:01 »
Integrated plate most often sounds terrible, I'm not sure how you would counter that in this design.
« Reply #17 on: Wed, 20 May 2020, 02:43:03 »
Integrated plate is usually a bad idea for sound. In your sideways render, the PCB is also touching the bottom part of the case.
I think that the sorbotane would only absorb sound below the PCB and nothing else of the forces that go through the case. I doubt that it would work better than craft foam in this construction.
« Reply #18 on: Wed, 20 May 2020, 08:17:04 »
This seems to be a common theme of some people like them exposed and others not, so I added an IC form question!
So the thinking behind this is you have the switch centers actually pressing into the Sorbothane. You're then making contact with the key where it bottoms out as well as the entire PCB. Since most sound is generated where the switch bottoms out, you're damping this exact spot before those high frequencies go anywhere else. The PCB being mounted to the bottom insert was also so that the sound generated by it gets transmitted down and away instead of through the mounting surface.
When I get the Proto I'm going to do a sound test with some holy pandas vs a standard 60% aluminum case. Likely have enough data by this weekend to get it made.
Offline GEIST
    • schwarzgrau
« Reply #19 on: Thu, 21 May 2020, 05:33:54 »
Holy ****! That's awesome
« Reply #20 on: Thu, 21 May 2020, 09:26:07 »
So right now it's looking like people really want a 65%. I am going to also lower the switches inside the case. Should have an update over the weekend. If it looks solid, I'll place a prototype order for that design with the factory. Since I'm lowering the switches inside, that will also free up the design for ISO and soldering PCBs with a mounting plate.
Offline FRANCO
« Reply #21 on: Thu, 21 May 2020, 09:43:00 »
Nice! I too think it would look a lot better if the keys were sunk a bit into the case. If you do, damn, I think I'm going to hop on this
Offline hottrout
  • I'd Hit Dat Key
« Reply #22 on: Thu, 21 May 2020, 10:01:29 »
Nice updates, looking forward to seeing the revised edition.
Systems -
  Keyboards -
Offline Joaquox
« Reply #23 on: Thu, 21 May 2020, 10:02:03 »
Full disclosure, I'm not interested in buying this keeb, I only use ortho, but I honestly don't think this will work. I'm not saying it to be mean or anything, I'm taking a guess that your prototype will run at $300 or so excluding the sorbo, please consider this before spending a ton on a prototype.
If your try tapping a integrated plate, you will have a ping sound, almost like strings or a drum skin.
I have a niu mini that I tried to dampen with bottom foam (mind you it was not sorbo, but a very low shore, high density foam) and that did not work.
What I ended up doing was putting a 3mm brass plate in between the integrated plate and the PCB, suspended between two layers of compressed 1mm foam, and then some foam at the bottom under the PCB  as well.
This did not remove all the ping (but a lot), so I eventually settled for silent switches, which have internal damping as well.
See, unless you're using holy pandas (or some kailh switches) the sliders will hit, and they hit closer to where the switch meets the plate. HP (and some kailh switches) have a longer plunger that hits the bottom where you'd have sorbo. This is not normal, it's an exception.
Maybe you could save some money and order a smaller version as a first prototype, and figure out if the mounting and damping works first. Or get a niu top and putting a ton of sorbo underneath to see if it helps.
« Last Edit: Thu, 21 May 2020, 10:21:37 by Joaquox »
« Reply #24 on: Thu, 21 May 2020, 14:44:03 »
I think that's a pretty good point about how in integrated concepts the top acts almost like a drum skin. I am moving to a separate top plate now that the keys will be recessed.
One interesting thing to note is I've found through research that thinner amounts of rubber sometimes perform better in sound deadening. I think it absorbs and dissipates the energy a bit more instead of acting like a stiff wall of rubber.
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #26 on: Sun, 24 May 2020, 11:42:23 »
https://imgur.com/t7FFG1m
The idea was where the switch sticks through the PCB and into the Sorbothane. So yes, directly rather than other solutions that damp the case, etc. But it's changing.
Offline locxu
« Reply #27 on: Wed, 27 May 2020, 18:36:12 »
Reserved, gorgeous design, especially White color.
Offline perry4761
« Reply #28 on: Wed, 27 May 2020, 18:45:12 »
I'm usually not the biggest fan of low-profile, but I'm definitely intrigued! The design looks immaculate, and although I understand why, it is a shame that it only works with hotswap PCBs.
« Reply #29 on: Wed, 27 May 2020, 22:17:09 »
That's interesting.  I've had a somewhat similar idea where the bottom centre "pin" of each switch would rest on a small bump in a cast mat of silicone.
I'm looking forward to your results!
Hmm... Maybe this applies as an explanation of why that is so. It's a long video on designing loudspeakers, that uses a Sorbothane-like adhesive material for damping.
Hi all,
Made some major changes based on the feedback I received on the Discord and the Google form. The design now has a very thick but more standard top plate that will include optional O-Rings to damp vibration. There are also a myriad of other minor changes to the design and manufacturing details based on the first prototype.
Currently the rev 2 prototype will be shipped to me in the next week or two and I'll make a sound/fit test and post it here as soon as I get it.
Thanks to everybody for their feedback and help up to this point! This community has been extremely welcoming and helpful during this IC.
« Last Edit: Sun, 05 July 2020, 23:33:23 by MechMountain »
Offline YangYoga
yes yes yes yes yes!
Offline hottrout
  • I'd Hit Dat Key
Cool
Systems -
  Keyboards -
Offline Hugs94
glad to see you have made those changes from the original!
Hi all, quick update. There has been enough interest for me to order a polycarb prototype. Hopefully shipping soon with the rev 2 aluminum version.
I also deleted the built in feet from the bottom of the polycarb version. I will be including separate clear rubber feet but you can leave these off for an ultra-clean look.
Offline hottrout
  • I'd Hit Dat Key
The PC looks very cool.
Systems -
  Keyboards -
Prototype in the mail. Took four attempts to perfect the anodizing process. Looks immaculate though. Really happy with the results. As with any small production run though, I expect there may be some units with small defects you can't see when assembled.
The four threaded holes on the bottom are just for the anodizing jig. They're covered up by the rubber feet. Or you could drill some holes in your desk if you really want a solid mount...
« Last Edit: Tue, 21 July 2020, 22:27:26 by MechMountain »
Offline 1corazon
LOOKS WICKED MATE,
Thanks for the update. I cant wait to buy this!!!!!
Offline cloudtastrophe
Re: [IC] HATCHET-01 | 65% Integrated Wrist Rest and O-ring Damping
« Reply #38 on: Sun, 02 August 2020, 03:08:23 »
Can we have a new discord link? the once thats in the thread has expired.. ):
Offline The.Ryan.Gamer
« Reply #39 on: Sun, 02 August 2020, 06:25:20 »
OMFG! This is crazy design! I'm IN! When is the ETA for GB?
Filled up IC Form. Suggesting that Aside from the Blocker (between control and arrow keys) I'm suggesting a numpad variant of this as well (a separate numpad).  :thumb:
« Reply #40 on: Sun, 02 August 2020, 23:33:26 »
Just checked it, should be working, no expiration on that link. Let me know if you're still having issues.
GB is coming up soon, probably in about a week. Wrapping up on PCB and Polycarb pricing/finishing. I have the aluminum proto in hand and there are no changes needed. Jigs are all figured out, everything is good to go.
Would love to do a numpad. Want to get a single version out for my first GB though. Unfortunately that probably means no blocker for now as well, especially since the colors would have to be batched. Would be a giant QC/inventory mess.
« Last Edit: Sun, 02 August 2020, 23:40:26 by MechMountain »
« Reply #41 on: Mon, 03 August 2020, 00:58:41 »
I see, i'll have to think about it, however the design make it's very hard to resist. I hope the Asia Vendor accepts credit card payment, as i'm not feeling safe using PayPal (my PayPal was hacked 2months ago, i have $1,350 there, still haven't heard how PayPal can reimburse the lost balance)
[/quote]
« Reply #42 on: Mon, 03 August 2020, 01:44:56 »
I'm handling all production and shipping, no vendors. Will be using an online store so cc/debit will be OK. I also don't trust Paypal at all.
« Last Edit: Mon, 03 August 2020, 01:47:35 by MechMountain »
« Reply #43 on: Mon, 03 August 2020, 02:17:42 »
Great news. I forgot i'm on Discord.  :))
3 week GB is amazing. Can't wait to see the data of which color is the most popular.
« Reply #44 on: Mon, 03 August 2020, 16:22:38 »
So from the IC form I'm likely going to tweak the colors to:
Black
Dark Grey
Powdercoat White
Dark Blue
Dark Green
Polycarb
Any thoughts on anything I'm missing?
« Reply #45 on: Mon, 03 August 2020, 23:31:10 »
Question. What's the possibility of the wrist rest color fading to fast?
Offline Laneware
    • Laneware Peripherals
« Reply #46 on: Tue, 04 August 2020, 00:28:29 »
Interesting design, thought on a chamfered/filleted edge on the wrist rest?
« Reply #47 on: Tue, 04 August 2020, 15:44:27 »
Low, anodizing is extremely tough stuff. About ~3 as hard as aluminum. The polycarb version may show shiny spots after years of use but I doubt it.
I played around with this in CAD and could never get it to look quite right. The rest is extremely long though. I'm 6'3" and have giant hands and my wrist doesn't touch the front edge.
« Reply #48 on: Tue, 11 August 2020, 22:28:53 »
Getting pretty close to GB... just wrapping up all the details and ordering system. Should have a date soon.
I will be also offering three options for top plates, POM and ISO weren't huge requests but enough to warrant offering them for those who want them.
Top Plate Options:
ANSI 65% in matching aluminum color
ANSI 65% in black POM
ISO 65% in black POM
Re: [IC] HATCHET-01 | 65% | Group Buy This Saturday
« Reply #49 on: Thu, 13 August 2020, 22:13:58 »
Group buy will go live on Saturday, the 15th at noon EST (4pm GMT).
Thanks everybody, really looking forward to start production on this thing!
GB will be located at www.hatchet-01.com
