Author Topic: Matias Tactile Pro fn key  (Read 131049 times)
Offline apastuszak
« on: Tue, 19 May 2020, 22:02:41 »
Is there some way to use AutoHotKey to remap the fn key on a Tactile Pro 4 keyboard?  I'm on a PC and would really like to map it to the Insert key if possible.
Offline funkmon
Re: Matias Tactile Pro fn key
« Reply #1 on: Tue, 19 May 2020, 22:13:14 »
I actually asked Matias this and they said, basically, probably not. Weird that there wasn't a for sure response, but hey. It's not outputting scan codes for me into Windows so I've left it a dead key. If I need it, which is so rare that I have literally never had to do this, I turn off numlock and use 0.
Offline apastuszak
« Reply #2 on: Tue, 19 May 2020, 22:34:39 »
I need to use Shift+Insert quite a bit for paste in a terminal.  I may need to remap F13 to be the insert key.
Thanks for the info!
