Author Topic: [IC] Elongate (Mini 1800) (GB DONE, ORDER PLACED)  (Read 43835 times)
Offline fcoury
« on: Thu, 21 May 2020, 14:08:19 »
Elongate
UPDATE 09/24: So the GB was a major success. We sold around 250 units so wanted to thank you all for playing. The order has been placed and as soon as I learn more or have any progress I'll post another update. Also, for everyone that asked on the past weeks: there will be extras!
UPDATE 07/06: GB Live at ProjectKeyboard (US_) iLumKB (Asia), DailyClack (OC) and MyKeyboard.eu (EU).
UPDATE 05/25: We continue to hear your feedback. Moving to ARM processor to allow us to also add in-switch LEDs. So it's happening.
UPDATE 05/23: This Tuesday (05/26) Gondo will be streaming the PCB port to USB-C - https://www.twitch.tv/gondolindrim_
UPDATE 05/22: Due to the HUGE demand and overwhelming feedback requesting USB-C we're definitely committing to that change! <3
Hello GeekHack! MisterKeebs here to share a project I have been working on for a few years now. In partnership with the gifted and awesome Gondolindrim (or Gondogod), along with 159 from ProjectKeyboard, I'd like to present the Elongate board, that combines the versatility of a 40% with the aesthetic inspired on a 1800 layout.
Please provide your feedback here: https://docs.google.com/forms/d/1xOQJRbzpbH5Ga5q6eFHe2yqL55rzjZbdXeLaXQBPJl8
Introduction
The Elongate is a custom mechanical keyboard that falls in a random place of the 40-50% range. It was designed as a new take on the mini 1800 layout, combining the versatility and portability of a 40% with the ability to have that dedicated numpad cluster, with Home, Page Down/Up, End, Insert and Delete keys.
The main and unique features of the Elongate are:
  • The protruded arrow cluster, allowing for fast navigation;
  • The blocked split space, which helps accessing a second or third layer of the 40% layout -- making it more comfortable and quick to use;
  • A solid midlayer that can be either polycarbonate or brass, that improves the sound profile a lot.
  • On the spacebar blocker there are also a three-LED indicator cluster, which can be used for layer indication, Caps/Num/Scroll lock and every feature QMK allows. These indicators are fully programmable and, in conjunction with SIP sockets, allow you to hotswap LED colors.
  • As if that wasn't enough, there are three more indicators between the numpad and the alpha cluster to indicate whatever you want it to.
All of these characteristics really make for a very pleasant typing experience. The user is able to get the full utility of the 1800CP layout in a very compact form and have enough space in the sides to use the mouse.
What is included
  • Case: Top and Bottom Polycarbonate or Aluminium (vote for colors on the link below)
  • Middle layer: Brass or Polycarbonate
  • Plates: Brass or Polycarbonate
  • PCB: QMK and Via compatible (see above)
  • Extras: See below for more info
The PCB
The PCB was designed by my good friend Gondolindrim and features RGB underglow for those sweet lights with the polycarbonate version. It's powered by the ATMEGA32U4 microcontroller and uses a USB mini-B connector. It also features ESD protection, connector shielding, power rails filtering and a sweet, sweet Brazilian flag. All that we learned to expect from Gondo.
We have had until now many requests to port the PCB to USBC connector, since as it stands right now it has a mini-USB connector. Please give us a feedback on the IC form!
The PCB is QMK and VIA compatible. Since Gondo is also a big open-source hardware advocate, the ElongatePCB is also open-source! -- see the GitHub repo for the files.
Price and vendors
This GB will be run by ProjectKeyboard in US (big kudos to the awesome 159 for all the support along the way) and, depending on the interest, we will be considering EU/Asia proxies.
DISCLAIMER the prices below are tentative based and can change before GB opens. We'll try to be super transparent if they change.
The kit/pricing breakdown will be as follows (all prices excludes shipping and other PP/trasaction fees):
Base Kit:
Anodized Alu Top and Bottom, Brass Plate, Brass Midlayer and PCB - $325-350
Extras:
  • Brass Plate - $40
  • Anodized Alu Plate - $35
  • Polycarbonate Plate - $40
  • POM Plate - $35
  • Carbon Fiber Plate - $30
  • FR4 Plate - $20
  • PCB - $35
We also do not know if we are going to do a limited or unlimited run; all depends on the results of this IC, so please please give us your feedback on the IC form!
Streams, glamour shots and the likes
You can find the complete album on this Imgur post.
Build Stream
Elongate Alu Sound Test
Elongate Polycarbonate Sound Test
« Last Edit: Thu, 24 September 2020, 17:41:53 by fcoury »
Offline brtleonardo
Re: [IC] Elongate (Mini 1800)
« Reply #1 on: Thu, 21 May 2020, 14:09:42 »
YESSSS FINALLY
Sent from my SM-G970F using Tapatalk
Offline PotatoTM
« Reply #2 on: Thu, 21 May 2020, 14:11:48 »
I have been waiting for this IC, looks great, I'm looking forward to the GB!
Offline victorpre
« Reply #3 on: Thu, 21 May 2020, 14:12:07 »
come on, just make the GB post already  :cool:
Offline sandragm
« Reply #4 on: Thu, 21 May 2020, 14:13:01 »
I’m so into this and have been since I first saw it. Great job, guys!
Offline NOLA
« Reply #5 on: Thu, 21 May 2020, 14:15:24 »
This looks like garbage truck.
Sent from my Pixel 4 XL using Tapatalk
Offline donut_sauce
« Reply #6 on: Thu, 21 May 2020, 14:15:41 »
this is a super fun keyboard!
Offline demonahz
« Reply #7 on: Thu, 21 May 2020, 14:22:19 »
I am ready for this.
Offline neojonathan
« Reply #8 on: Thu, 21 May 2020, 14:23:26 »
Interested definitely !
Offline TheArcticFox_27
« Reply #9 on: Thu, 21 May 2020, 14:26:29 »
H Y P E
Offline mrpetrov
« Reply #10 on: Thu, 21 May 2020, 14:27:02 »
hell yeah, it's coming baby! in!
Offline eyedrop
« Reply #11 on: Thu, 21 May 2020, 14:28:11 »
Honest question, what does people who use 40% without " ' { } : or ; map it to on their layout?
« Reply #12 on: Thu, 21 May 2020, 14:30:57 »
Garbage Truck looks like an Elongate*
Offline CrazyAssMonkey
« Reply #13 on: Thu, 21 May 2020, 14:37:48 »
No way, the layout!!!!!
This is it chief this is it!
Offline donut_sauce
« Reply #14 on: Thu, 21 May 2020, 14:38:38 »
i use my spacebar as an LT layer and on that layer i have it mapped to KC_Z,KC_X.
Offline jani80k
  • In the hobby for a good time.
« Reply #15 on: Thu, 21 May 2020, 14:41:57 »
Hey... I watched the stream when you received the dirst prototype. This board has come a long way and coming from you, we can be sure, it is well thought through.
Could you give us non 40% users some sample layer configs so we can get an idea how to use the board?
It looks and sounds insane, that's for sure!
« Last Edit: Thu, 21 May 2020, 15:52:17 by jani80k »
Offline czyrix
« Reply #16 on: Thu, 21 May 2020, 14:43:41 »
I've been waiting for this!
Offline synthtastic
« Reply #17 on: Thu, 21 May 2020, 14:44:54 »
Very very cool. Glad to see you’re finally getting this out there!
Expensive plastic makes me sigh.
Offline Im
« Reply #18 on: Thu, 21 May 2020, 14:52:04 »
omg its happening :O
Offline Yakbats
« Reply #19 on: Thu, 21 May 2020, 14:52:35 »
Looks soo good!
Offline oldcat
  • 65% is Life
« Reply #20 on: Thu, 21 May 2020, 14:53:12 »
very interesting!
Offline Visionaire
« Reply #21 on: Thu, 21 May 2020, 14:56:05 »
ITS HAPPENING!!!
Offline of_sam
« Reply #22 on: Thu, 21 May 2020, 14:59:54 »
Yes. Just Yes.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Visionaire
« Reply #23 on: Thu, 21 May 2020, 15:02:41 »
With split space, I map the left bar to be a fn key to access these.
Offline Ulliam
  • Formerly Papithered
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #24 on: Thu, 21 May 2020, 15:04:53 »
Yeeeeeessss please.
Offline 1391401
  • MX CLEAR
« Reply #25 on: Thu, 21 May 2020, 15:08:44 »
As a programmer this is what stops me from using 40% - I can handle a lot of functions being hidden behind a layer but not " ' { } ; :
Regardless this keyboard looks amazing!  Nice work.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline i luv chuletas
« Reply #26 on: Thu, 21 May 2020, 15:36:35 »
Homerow mapping for these, software engineer myself rocking 40% :)
Offline NICOTINE
« Reply #27 on: Thu, 21 May 2020, 15:59:46 »
In on this 100%!! Grats on going into GB phase!
Offline Lulluberllu
« Reply #28 on: Thu, 21 May 2020, 16:07:20 »
Oh yes, looks so good!
Offline DERBS
  • N E 3u bars avail?
« Reply #29 on: Thu, 21 May 2020, 16:10:37 »
My body is ready :p
+1 for USB-C and FR4 plate.
Offline Nvr_Smile
« Reply #30 on: Thu, 21 May 2020, 17:44:07 »
Can't wait for this. Instant buy once the GB opens up.
Offline sygo_
« Reply #31 on: Thu, 21 May 2020, 19:34:37 »
looking good, really cool layout
Sent from my SM-G985F using Tapatalk
Offline low_key_keyboards
  • I like to make custom keyboard cases.
    • Low Key Keyboards
« Reply #32 on: Thu, 21 May 2020, 19:40:14 »
Super duper keen on this!
Offline Auxo
  • Formerly CJD_Anthony
« Reply #33 on: Thu, 21 May 2020, 19:59:46 »
yeah im gonna need this
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #34 on: Thu, 21 May 2020, 20:04:41 »
Is it still possible to not have indicator LEDs on both spacebar blocker and above arrow cluster? Seems a tad unnecessary. Granted one could just not install LEDs in either places, but the “holes” will still be present.
Not sure if anything can be done about that at this stage though.
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline bakerozee
« Reply #35 on: Thu, 21 May 2020, 21:13:26 »
Can't wait for this one, checked out the build stream.  :p :eek:
"more the knowledge lesser the ego, lesser the knowledge more the ego..." Albert Einstein
Offline endjy
« Reply #36 on: Fri, 22 May 2020, 03:37:03 »
My wallet is ready
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #37 on: Fri, 22 May 2020, 09:44:20 »
Really neat and cool looking!
so happy seeing more boards like this!
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #38 on: Fri, 22 May 2020, 12:43:57 »
Was never super into the 40%-type boards, but this is something different.  I’m totally down. Great Job!
Offline fcoury
Re: [IC] Elongate (Mini 1800) (moving to USB-C)
« Reply #39 on: Fri, 22 May 2020, 16:28:17 »
We heard you: we're moving to USB-C! <3 Thanks for the overwhelming response so far!
Offline Dior
« Reply #40 on: Fri, 22 May 2020, 21:50:40 »
I will definitely be looking forward to this !
Offline hottrout
  • I'd Hit Dat Key
« Reply #41 on: Sat, 23 May 2020, 05:18:18 »
It would look even better with ISO but either way I am in for this.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
« Reply #42 on: Sat, 23 May 2020, 12:05:05 »
Amazing news! Any ideas as far as the timeline goes for the actual GB?
Offline fcoury
« Reply #43 on: Sat, 23 May 2020, 13:41:11 »
Yes, I was talking to 159 yesterday and there's really no reason to not push this soon. So even though no concrete TLs yet, we expect it to be happening pretty soon. For real this time :)
« Reply #44 on: Sat, 23 May 2020, 13:57:50 »
What are the dimensions of the keeb?
Offline KetchyKech
« Reply #45 on: Sat, 23 May 2020, 14:59:41 »
No inswitch LED? :x
Offline fcoury
« Reply #46 on: Mon, 25 May 2020, 11:58:17 »
Basically 31x9.5cm. Hope those two pictures help:
And sorry for the terrible drawing :)
Offline fcoury
« Reply #47 on: Mon, 25 May 2020, 12:00:27 »
No inswitch LED? :x
We are evaluating that possibility. I'll update you if we can sneak that in while we add the USB-C case.
Offline Gondolindrim
    • My GitHub
Re: [IC] Elongate (Mini 1800) (moving to USB-C/ARM/In Switch LED)
« Reply #48 on: Mon, 25 May 2020, 12:11:27 »
Ok guys so we've been hearing you and we took some feedback into consideration. I was going to host a rather short stream tomorrow porting our PCB to a USBC connector, but since we are doing this why not go the whole nine yards? So tomorrow in stream I'll re-design the PCB from scratch doing:
  • ARM processor
  • USB-C connector
  • Adding more underglow
  • Adding in-switch LEDs
See you guys tomorrow!
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
« Reply #49 on: Mon, 25 May 2020, 12:19:38 »
Oh man Oh man Oh man! It's the perfect size O_o, I'm so hyped!
