Author Topic: [IC]KK75 Keyboard Kit +GB IS LIVE  (Read 19849 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Mon, 25 May 2020, 03:23:42 »
Edit: JUNE 12
Hi Everyone,
Good day! The GB for the KK75 KEYBOARD KIT is NOW LIVE on the Website here.
Musical rhythm (Another model, Just layout is different): https://imgur.com/ebBbCip
KK75 KEYBOARD KIT: https://imgur.com/a/4FVnEHa
Edit: May 28th
KK75 factory video update: https://imgur.com/xJwKO1S and  https://imgur.com/3Gj98pD
  :thumb:
Album: https://imgur.com/a/4FVnEHa
Case:
Angel White
Elegant Grey
Mysterious Black
Prussian Blue
Loli Pink
Passionate Red
The standard kit comes with:
Aluminum alloy case * 1 (top mount)
Non-hot-swap PCBA * 1
Aluminum Plate * 1
Necessary Plate Mounted Stabilizers
Custom Name Badge: can custom to the name you want or leave it blank. Name badge cannot be taken away
Spec:
Type-C
Wired
Single backlight (Need to purchase and install switch LED yourself)
Software to remap keys, backlight, Marco.
Keyboard Angle: 4 degrees
Keyboard size: 327 * 170 * 32mm
Price: EST.US$160 -170 +Paypal fee +Actual shipping
MOQ: Already met at this moment in a small GB, so it’s not a problem
Estimated GB:
if we get positive feedback from IC, we will open at the end of May or early June.
Estimated Delivery: GB ends in June, Delivery in August.
Add on
Brass plate: +US$15
If you would love to receive an update, please fill in this IC form, or join our discord server
Feel free to let us know your ideas :)
« Last Edit: Tue, 16 June 2020, 21:00:42 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline PureLuck
Re: [IC]KK75 Keyboard Kit
« Reply #1 on: Mon, 25 May 2020, 06:30:13 »
Hi! This looks very affordable which is a welcome sight!
Can i know what kind of software and what kind of aluminium grade?
« Last Edit: Mon, 25 May 2020, 06:33:25 by PureLuck »
Offline Hydroxide
« Reply #2 on: Mon, 25 May 2020, 07:46:01 »
If the listed price is anywhere near accurate I'd definitely scoop one of these up! Glwic!
Sent from my SM-G973U using Tapatalk
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #3 on: Mon, 25 May 2020, 08:58:24 »
custom name badge. Count me in. Can we get some more specifics like weight?
Do you have eu proxies in mind?
Offline rondg
« Reply #4 on: Mon, 25 May 2020, 09:16:49 »
Does this use the same PCB as the Idobao ID80 amd Polaris75 keybaord?
Offline rondg
« Reply #5 on: Mon, 25 May 2020, 09:32:35 »
I just realized that the spacing between the function row and the number row are different, so the answer is no.
Offline gwyn
  • ZType Professional
« Reply #6 on: Mon, 25 May 2020, 10:37:32 »
Nice. I dig this.
Offline CrazyAssMonkey
« Reply #7 on: Mon, 25 May 2020, 10:45:24 »
Out of curiosity is there QMK?
Offline CF73
« Reply #8 on: Mon, 25 May 2020, 17:40:33 »
lovely board at an affordable price. Not sure if qmk is supported tho
few questions:
-can we supply our own vector image for the badge instead of names?
-the plate looks like an integrated plate, can we get a full exploded view if it's a top mount?
-how is the bottom part held together? The image shows a flat piece with no screw holes.
Edit: Couldn't see those screw holes on the bottom piece til I zoomed in :<
« Last Edit: Tue, 26 May 2020, 11:27:33 by CF73 »
Offline john08099
  • Velocifire MK
« Reply #9 on: Mon, 25 May 2020, 21:11:43 »
Our software, we will share the UI with you. 6063 aluminum alloy
« Reply #10 on: Mon, 25 May 2020, 21:13:31 »
+1 for color names
Offline john08099
  • Velocifire MK
« Reply #11 on: Mon, 25 May 2020, 21:23:27 »
Currently no, maybe we can try it in the next IC
« Reply #12 on: Mon, 25 May 2020, 22:16:27 »
+1 for color names
That pink loli sounds mildly tempting  :p
Offline john08099
  • Velocifire MK
« Reply #13 on: Tue, 26 May 2020, 21:03:56 »
no
Offline djk6516
« Reply #14 on: Tue, 26 May 2020, 21:45:13 »
Very interested at projected price.
Sent from my SM-G955U using Tapatalk
Offline noorejji
« Reply #15 on: Wed, 27 May 2020, 00:14:53 »
Loli Pink
Interesting naming choice.
Offline Antvn84
« Reply #16 on: Wed, 27 May 2020, 12:30:44 »
So interested with the price  :thumb:
Offline john08099
  • Velocifire MK
« Reply #17 on: Thu, 28 May 2020, 04:55:37 »
;) Thanks.
Offline SxM Designs
    • Website
« Reply #18 on: Thu, 28 May 2020, 07:26:14 »
Regarding the name badge?
Any renders how we can expect it? Maybe with a custom name or something.
Offline kevchigga
« Reply #19 on: Thu, 28 May 2020, 09:30:06 »
DEFINITELY IN FOR ANGEL WHITE! What is this single backlight you're talking about? For the led indicator?
Offline john08099
  • Velocifire MK
« Reply #20 on: Thu, 28 May 2020, 21:03:11 »
name plate size is 45.2*23.6mm. font is very flexible. you can send us CAD, AI, PDF files
Offline Tainado
Re: [IC]KK75 Keyboard Kit +Factory video update
« Reply #21 on: Fri, 29 May 2020, 11:15:53 »
John , any upcoming renders for the Back side ?  Internal Weight ?
Very Impressive design so far !
Offline john08099
  • Velocifire MK
« Reply #22 on: Fri, 12 June 2020, 05:36:23 »
you can check it here: https://imgur.com/a/4FVnEHa, Weight of the kit: 1.6 kg
Offline niakulah
Re: [IC]KK75 Keyboard Kit +GB IS LIVE
« Reply #23 on: Fri, 12 June 2020, 20:25:08 »
Price is nice. The top part is too big IMO. I'd be more interested if it used PCB mounted stabs instead of plate.
I'd be VERY interested if it was your 1800 (other design PCB sample in your album)
Offline john08099
  • Velocifire MK
« Reply #24 on: Fri, 12 June 2020, 23:24:59 »
Thanks, we can consider this version next time.
Offline john08099
  • Velocifire MK
« Reply #25 on: Tue, 16 June 2020, 20:55:44 »
You can only install single backlit of the switch LED
