Author Topic: [GB] KKINGKKONG 660 Keyboard | closed  (Read 174527 times)
Offline chanmin kang
Re: [GB] KKINGKKONG 660 Keyboard
« Reply #50 on: Thu, 04 June 2020, 09:34:15 »
I'm a bit confused on my invoice, there is a line item for an extra top case
660 Extra Top Case
+ Extra top case
1   $85.00   $85.00
Which I didn't order, and AFAICT there is no there is no extra top case option anyway.
We apologize for any problems. It may be a mistake. Could you send me your invoice number by email or PM?kkingkkongworks@gmail.com.
« Reply #51 on: Thu, 04 June 2020, 09:35:54 »
Hmm. My wrong. I did not see it yesterday. Any chance I could change my order and make it cerakote in black?
Yes you can modify. If you have received an unchanged invoice or have already paid, please send a brief description with your invoice number to kkingkkongworks@gmail.com.
« Reply #52 on: Thu, 04 June 2020, 09:52:14 »
Good morning. We had fewer inquiries than the first one, but we still had to spend a day to get everything done. Thank you very much for your support.
There are many invoice modifications and additional orders that require time to organize. For 20 people who can receive the keyboard for the first time, we will send an email as soon as possible.
We are also preparing things related to shipping. Many people have inquired about customs duties. To solve this, we are checking various things. We will let you know as new updates become available.
It's all manual until check your order and send the invoice.
During the process of writing invoice, there are often problems in which other products are selected due to typos, or other products are included due to misunderstanding the line. If you send me an email, I will take care of it as soon as possible. We apologize if this has caused any inconvenience.
Offline merlin64
    • MechMerlin
« Reply #53 on: Thu, 04 June 2020, 10:39:13 »
Hi chanming, do you know if the PCB has ESD protection on it?
Offline Poesjuh
« Reply #54 on: Thu, 04 June 2020, 11:47:24 »
@chanmin
We emailed with regards to the blue wkl one. Just a heads-up that I changed my order in the form accordingly to our communication :)
Also: could you provide a picture of how the plate is attached to the bottom?
Offline Mechtype
« Reply #55 on: Thu, 04 June 2020, 16:28:44 »
Will there be a weight included with the keyboard?
Offline ln8r
« Reply #56 on: Fri, 05 June 2020, 11:45:33 »
Have you chosen the exact Cerakote colors? Specifically I'm interested in which white was chosen.
Fingers crossed for Stormtrooper.
Offline Vaudevi77ain
« Reply #57 on: Fri, 05 June 2020, 15:58:42 »
Just checking if there's a sample for the rose gold yet.
Also, what is the pantone for the cerakote pink?
Offline Solertia
« Reply #58 on: Fri, 05 June 2020, 16:54:47 »
Can we expect to see samples/swatches of all the color options before the GB period ends? Really interested in this but I want to see before I commit.
Offline ele7087
« Reply #59 on: Fri, 05 June 2020, 20:34:36 »
Any better pics of the purple anodized keyboard? Thanks
« Reply #60 on: Fri, 05 June 2020, 21:07:31 »
No ESD protection.
« Reply #61 on: Fri, 05 June 2020, 21:12:42 »
No. Weights are not used.
Offline Cluet1
« Reply #62 on: Fri, 05 June 2020, 22:58:42 »
Can you tell us how much it weighs?
Offline shodid
« Reply #63 on: Fri, 05 June 2020, 23:05:44 »
I am really liking the navy blue cerakote. I'm also waiting to see the shade samples of grey and white cerakote and then I will decide which one or two to get.
I really hope I can see pictures of the bottom case, the prototype pcb, and the colors samples so I can have confidence to order.
Offline Poesjuh
« Reply #64 on: Sat, 06 June 2020, 05:45:21 »
Considering we’re at 1/3rd of the GB it’s somewhat concerning to me that there is a lot of info we don’t have yet. Hope you can share more of the colors and internal design before the gb is over.
« Reply #65 on: Sat, 06 June 2020, 06:20:32 »
All the pictures are keyboards we made earlier. we hope this helps in choosing a color.
Colors not listed here will be updated soon.
This is an example of blue anodizing. This keyboard worked without being sandblasted.
KKINGKKONG660 works with the same dye and process as the picture above. However, the keyboard is sandblast, so the surface roughness is different.
This is an example of orange gold.
KKINGKKONG660 will be made in the same color as this one.
Here's an example of purple. This is also the color of the other keyboards that we have made before, and they are made in the same process.
Finally, an example of Red and silver
Like the first picture, this is Anodized without sandblast.
it may be slightly different from the actual keyboard.
We are sorry that we cannot show you all the samples for the colors this keyboard
we offer 17 color options, and it is impossible to produce all samples on one type of keyboard.
Instead of a rendered keyboard, we wanted to show the color applied to the actual keyboard if possible.
we hope this helps.
Offline Poesjuh
« Reply #66 on: Sat, 06 June 2020, 06:44:49 »
Thanks for those pictures! Edited my form accordingly.
Offline marshskitow
« Reply #67 on: Sat, 06 June 2020, 10:04:13 »
Thank a lot for the new pictures!
I am right if i say the purple here is a anodysing color only ?
regards
« Reply #68 on: Sat, 06 June 2020, 10:20:55 »
regards
Purple is an anodizing color. It's just that picture right now. There is no cerakote option.
« Reply #69 on: Sat, 06 June 2020, 10:40:13 »
I brought the rendering.
It will help a little in your decision.
However, since this is a rendering, it may be different from the actual one.
« Last Edit: Sat, 06 June 2020, 11:03:00 by chanmin kang »
Offline marshskitow
« Reply #70 on: Sat, 06 June 2020, 16:38:05 »
omg thats perfect ! Thank you chanmin kang for all of this.
However i still need help from someone. Can someone name all the color ? I'm sorry guys but im colorblind and i can't figure out if its cerakote or not. I would really apreciate.
Also we can have the bottom different color than the top ? Is it a good idea ?
ty
Offline shodid
« Reply #71 on: Sat, 06 June 2020, 17:51:24 »
Seconding MechMerlin, I wish ESD on the PCB also.
Offline Poesjuh
« Reply #72 on: Sat, 06 June 2020, 18:30:28 »
Agree on that.
Offline aloevera
« Reply #73 on: Sat, 06 June 2020, 19:00:05 »
Hello, I ordered an additional base kit (two total). The additional base kit totaled to $270 USD instead of $240 as stated. Is this correct or was I charged incorrectly?
Offline jasonex64
« Reply #74 on: Sat, 06 June 2020, 19:36:26 »
ty
from the top down (what i see):
navy blue ano
orange gold ano
champagne gold ano
rose gold ano
rose gold ano
champagne gold ano
navy cerakote
silver ano
white cerakote
last one is yellow cerakote
i could be wrong but this is what I think
Offline Furitsu
« Reply #75 on: Sat, 06 June 2020, 22:54:11 »
Hi!
If possible, would you be able to provide some renders or pictures with keycaps on the board? Also, just to clarify the board has a centre USB port?
Offline pamorama
« Reply #76 on: Sat, 06 June 2020, 23:17:03 »
The champagne gold has a more cold tone to it than I expected (based on other versions of the colour that I've seen). Will there be a sample of it at some point?  :blank:
« Reply #77 on: Sun, 07 June 2020, 00:54:30 »
Probably wrong. Could you send your invoice number to PM or kkingkkongworks@gmail.com?
Offline shodid
« Reply #78 on: Sun, 07 June 2020, 01:09:17 »
What is this color ? I want this one.
Looks like a purple cerakote, but I don't see this offered.
Was this a prototype or can I order it?
244513-0
« Reply #79 on: Sun, 07 June 2020, 01:50:27 »
This is the color that was specially ordered in Korea.
You can also order this color if you like. However, we need to mix the cerakote
so you need to leave this color selection on the remark.
It is important to consider that the same color as the picture may not come out.
Offline buumb
« Reply #80 on: Sun, 07 June 2020, 02:36:08 »
Hello,
Is it possible to do this pastel yellow color as well?
Thank you!
244519-0
« Reply #81 on: Sun, 07 June 2020, 03:20:35 »
Hello,
Thank you!
This is a beige cerakote. It's a pretty good color. Don't you think so?
(Although it's a different keyboard) I brought a photos
Offline buumb
« Reply #82 on: Sun, 07 June 2020, 03:33:21 »
Thank you for the quick reply chanmin kang. yes that is a great color. i modified my order form to cerakote beige top and bottom case
Offline Sabin
« Reply #83 on: Sun, 07 June 2020, 03:44:14 »
Hello,
Thank you!
Does the PCB support 3 and 5 pin switches and screw in stabilisers?
Offline marshskitow
« Reply #84 on: Sun, 07 June 2020, 05:08:27 »
ty
navy blue ano
orange gold ano
champagne gold ano
rose gold ano
rose gold ano
champagne gold ano
navy cerakote
silver ano
white cerakote
Thnak you so much !
So we can mix color bottom and top right ? But it's gonna look weird or what ?
Offline pamorama
« Reply #85 on: Sun, 07 June 2020, 07:12:25 »
Do you have the colour swatches that the renders were based off of? Also, are those colours final?
Note: Thank you for posting some renders - I really appreciate it! I don't mean to keep harping on it, but I ordered a champagne gold keyboard the other day, and just based off of the renders, I think the colour would look great with a drop of a warmer colour (maybe red?) added to it. Right now, it looks very lemony... like a yellow. Of course it's all a matter of personal taste, but if there is any chance of adjusting the colour, that would be wonderful.
« Last Edit: Mon, 08 June 2020, 08:55:22 by pamorama »
Offline Kings
« Reply #86 on: Mon, 08 June 2020, 08:26:27 »
Would it be possible to get a copper plate? Maybe for the same upcharge as a brass plate.
Offline Solertia
« Reply #87 on: Mon, 08 June 2020, 10:11:57 »
Can we get an example of Gray (ano and cera)?
« Reply #88 on: Mon, 08 June 2020, 10:48:17 »
Hello,
Thank you!
Yes.
The PCB supports 3 and 5 pin switch, and a screw-in stabilizer can be used.
« Reply #89 on: Mon, 08 June 2020, 10:48:51 »
Unfortunately, this is not possible.
« Reply #90 on: Mon, 08 June 2020, 10:52:40 »
Here is an example photo. (It's another keyboard we made. The color will be the same.)
The weight of the middle keyboard is gray cerakote
example of a gray anodizing top.
Offline Melkemannen
« Reply #91 on: Mon, 08 June 2020, 14:15:34 »
On the supported layout image it doesn’t show support for 1.25U + 1U on the left shift, but looking at the latest renders posted here it looks like there are holes in the PCB to support that. Could you confirm if it does indeed support 1.25U + 1U on left shift?
Offline marshskitow
« Reply #92 on: Mon, 08 June 2020, 18:10:59 »
I was still really interested but i realized that there is no ISO on this keyboard (left shift)
Offline noorejji
« Reply #93 on: Mon, 08 June 2020, 18:25:23 »
There is. It’s universal.
Offline FunBox
    • Null
« Reply #94 on: Mon, 08 June 2020, 23:22:38 »
WOW, that red and silver combination is absolutely gorgeous
Sent from my SM-N975U1 using Tapatalk
Offline marshskitow
« Reply #95 on: Tue, 09 June 2020, 03:59:15 »
What do you mean ? So i can solder a small left shift key and my <> key instead ? Why the layout don't show this option then ?
Oh ok now i see it. Missed it because it was on the right of the picture. Sorry.
And of course i assign Fn key to Menu key on the layout picture right ?
« Last Edit: Tue, 09 June 2020, 04:03:55 by marshskitow »
Offline Kingjunguhn
« Reply #96 on: Tue, 09 June 2020, 04:50:21 »
Cant wait already, Paid my invoice today
url=https://geekhack.org/index.php?topic=107845.0][/url
Offline noorejji
« Reply #97 on: Tue, 09 June 2020, 08:41:53 »
Yes. PCB supports QMK, so you can program whatever you like.
Offline marshskitow
« Reply #98 on: Tue, 09 June 2020, 12:05:30 »
Perfect. Enough questions ! I'm probably gonna "order"  :thumb:
Offline Melkemannen
« Reply #99 on: Tue, 09 June 2020, 12:45:14 »
I found the link to their Discord, where they have posted an image of the PCB, and it does not have support ISO left shift (with <> next to it as I need aswell). Check for yourself: https://discord.gg/dRQcZZ9
I really want this, but the lack of ISO shift is kind of a dealbreaker for me...
